Home » Eclipse Projects » Eclipse Platform » API to return <workspace>/.metadata/.plugins/<plugin_version> dir
API to return <workspace>/.metadata/.plugins/<plugin_version> dir [message #303437] Mon, 15 May 2006 14:23 Go to next message
Is there an API that returns the location of the
..metadata/.plugins/<myplugin_ver> directory?
Is this the correct location for log files generated by my plugin?
If no, where should logs be generated (by a well behaved plugin)?
Michael Giroux
Re: API to return <workspace>/.metadata/.plugins/<plugin_version> dir [message #303438 is a reply to message #303437] Mon, 15 May 2006 14:24 Go to previous messageGo to next message
Michael Giroux wrote:
AFAIK, any logs generated through the eclipse logger will go to
<workspace>/.metadata/.log
The location you are talking about is returned from
Plugin#getStateLocation(), I think.
Later,
PW
Re: API to return <workspace>/.metadata/.plugins/<plugin_version> dir [message #303439 is a reply to message #303438] Mon, 15 May 2006 14:40 Go to previous message
Paul,
Thanks for the getStateLocation() pointer.
Michael
Previous Topic:Build path cycle inconsistency
Next Topic:Problems with TableViewer.refresh()
Current Time: Fri Jul 18 08:54:00 EDT 2025
Powered by FUDForum. Page generated in 0.24788 seconds
