Home » Eclipse Projects » Eclipse Platform » RCP strange behavior with XMLDecoder
RCP strange behavior with XMLDecoder [message #303378] Sun, 14 May 2006 05:18 Go to next message
Originally posted by: sami.xxxxxxxx.com
I'm using java 1.5.0 beta 2. and eclipse 3.1.
I have developped a first plugin 1 that use XMLDecoder in a method called
load.
Next, I have developped a plugin 2 dependent on plugin 1 that make use of
plugin 1 load method and tested it with success.
Plugin 2 test is the main method that use basic SWT widget display, shell
button that call the load method from plugin 1.
Then I developped an RCP dependant on plugin 1 and call the same method
load from plugin 1 the same way I did for plugin 2.
In the RCP an exception ("ClassNotFoundException")
Here is a summary of the plugin 1 load method
load(... input){
// the following line give the decoder variable its good value
XMLDecoder decoder = new XMLDecoder(input, null, null) ;
// the following line throw an exception "ClassNotFoundException"
Object obj = decoder.readObject();
I have then developped others plugins and rcp that use plugin 1.
All plugin using SWT and plugin 1 run with success.
All RCP throw the same exception
Any idea.
Many thanks for your answers
sami
Re: RCP strange behavior with XMLDecoder [message #303410 is a reply to message #303378] Mon, 15 May 2006 09:14 Go to previous messageGo to next message
Sami wrote:
> called load.
> of plugin 1 load method and tested it with success. Plugin 2 test is the
> main method that use basic SWT widget display, shell button that call
If it has a main method, then it's not a plugin ... do you mean you've
developed projects? Or you've made plugins, but you're just running
them as java applications (i.e. main method calls classes and methods
from "plugin 1")?
> In the RCP an exception ("ClassNotFoundException") Here is a summary of
An RCP app will be using real plugins. That means that plugin classpath
restrictions apply.
Amongst other things, if you've included 3rd party jars you need to be
very specific about how (I use a list like
http://wiki.eclipse.org/index.php/PDE )
Also, if plugin 2 depends on plugin 1, then plugin 1 cannot instantiate
any objects from plugin 2. This problem often shows itself when you
have factory patterns, where plugin 1 contains the main engine and
plugin 2 is providing implementation objects.
Later,
PW
Re: RCP strange behavior with XMLDecoder [message #303423 is a reply to message #303410] Mon, 15 May 2006 11:01 Go to previous messageGo to next message
Originally posted by: sami.xxxxxxxxxx.com
I have first turned a 3rd party jar into a plugin 0 using option 1 method
as explained in http://wiki.eclipse.org/index.php/PDE )
This plugin 0 export all its pakages.This plugin does not contain a main
method.
The I have made a plugin 1 that uses plugin 0 (via its PED dependencies
tab) and export some of its packages. This is actualy in my workspace and
not exported for deployment. This plugin does not contain a main method.
It export a package that contain a class including a method named load
that in turn create and use XMLDecoder
Then I have made a plugin 2 that use pluging 1.
This project has 2 packages
say plugin2.package1 and say plugin2.package2
plugin2.package1 contains one classX including a method that need a
Display param. This class has methods that instanciates objects from
plugin 1 and display them in an SWT shell using gridlayout, button etc ...
This package is exported (runtime tab).
plugin2.package2 contains a main method (for test purposes) and is not
exported. I run the test using : selected class containing main method and
run as => SWT application
and the test is successful.
Finally, I have developped an RCP (or even genered one via existing
templates) and added plugin2.package1 (PDE dependencies tab).
Then, in the Application class, I create an object from the
plugin2.package2.classX and call its method giving it the display param.
Result : the SWT shell open well and when I click the button that call a
method in plugin 2 which in turn call the famous load method in plugin 1,
then the new XMLDecoder(...) inside the load method throw an exception and
return null ...
This worked well with my plugin2.package2 test using main.
Thanks for your answers.
sami
Re: RCP strange behavior with XMLDecoder [message #303434 is a reply to message #303423] Mon, 15 May 2006 13:42 Go to previous messageGo to next message
This is constrained by the runtime bundle classpath in the manifest.
> and run as => SWT application
This has nothing to do with eclipse, it's pretending that it's just a
java app ... i.e. the fact that it runs means nothing.
So assuming the dependencies are RCP -> plugin2 -> plugin1 -> plugin0,
then you need to make sure that nothing tries to load a class "down" the
dependency chain.
i.e. plugin0 is not trying to do a
loadClass("class.in.plugin1.MyClass"). But plugin1 could load a class
from plugin0.
Also, when you "deploy" you have to ship all of the plugins. You said
"plugin1 ...and not exported for deployment." It must be deployed or it
won't run.
> 1, then the new XMLDecoder(...) inside the load method throw an
> exception and return null ...
Which line throws the ClassNotFoundException? What is the code on that
line, and which plugin is it in?
Like I said, this is using (more or less) vanilla java classloading, and
demonstrates nothing about your plugin problem.
Later,
PW
Re: RCP strange behavior with XMLDecoder [message #303497 is a reply to message #303434] Tue, 16 May 2006 12:43 Go to previous messageGo to next message
Note that my plugins 0,1 and 2 are just plugin "library type". They are
not intented to be extended.
I agree but the dependencies plugin2 -> plugin1 -> plugin0 work well.
> dependency chain.
> from plugin0.
Plugin 0 was made by turning the jar "apache.commons.codec" (last version
1.3) using option 1 method in http://wiki.eclipse.org/index.php/PDE
So I thinks there is no down class load
> won't run.
Note that I'm actually just testing my RCP project under eclipe ide.
Plugin 1 import java.beans.XMLDecoder which contain a XMLDecoder class
In my plugin 1, I have a class to persist xml object and a method (load)
with the following lines of code :
public Object load (InputStream xmlIn) throws PersistenceServiceException {
XMLDecoder decoder = null;
try {
decoder = new XMLDecoder(new BufferedInputStream(xmlIn, BUFFERSIZE),
null, null);
Object obj = decoder.readObject(); <=== here happen my exception
> Later,
> PW
Re: RCP strange behavior with XMLDecoder [message #303499 is a reply to message #303497] Tue, 16 May 2006 14:27 Go to previous messageGo to next message
>>> etc ...
bundle classpath and manifest are about running the plugin and loading
the classes. plugin.xml and extension points are about extending.
pretending they're java projects their dependencies work well ... I'm
just saying that is irrelevant as far as determining if their plugin
dependencies are working well.
>> from plugin0.
> version 1.3) using option 1 method in http://wiki.eclipse.org/index.php/PDE
> try {
> null, null);
> Object obj = decoder.readObject(); <=== here happen my exception }
OK, so plugin1 is calling decoder.readObject() ... what object is it
trying to read out of your xmlIn stream? Basically, readObject() is
causing plugin1 to call loadClass(*) somewhere. If the object it is
trying to read is in plugin0 or plugin1, then it should be OK, if it's
defined in plugin2, then it will fail.
From my first post:
Later,
PW
Re: RCP strange behavior with XMLDecoder [message #303521 is a reply to message #303499] Wed, 17 May 2006 04:02 Go to previous messageGo to next message
> From my first post:
> Later,
> PW
In some conditions, plugin 1 was trying to instantiate objects from plugin
2.
Thanks a lot Paul
sami
Re: RCP strange behavior with XMLDecoder [message #303546 is a reply to message #303521] Wed, 17 May 2006 07:11 Go to previous message
> plugin 2.
> Thanks a lot Paul
> sami
So the solution to this is to use buddy classloading. It allows plugin1
to search the classpath of dependent plugins without having to know
about them. Search the Help>Help contents for buddy classloading and/or
3rd party libraries.
Later,
PW
Previous Topic:Launch my own Eclipse View
Next Topic:Accessing field editors on a FieldEditorPreferencePage
Current Time: Wed Jul 16 02:32:47 EDT 2025
Powered by FUDForum. Page generated in 0.14476 seconds
