Home » Archived » DSDP - Real-Time Software Components (RTSC) » Creating a buffer in .cfg
Creating a buffer in .cfg [message #2609] Wed, 06 May 2009 19:35 Go to next message
I have a HeapFoo module that has an instance configuration parameter that
is an address (sharedAddr) and an Instance_State field attrs
HeapFoo.xdc
instance:
config Ptr sharedAddr = null;
internal
struct Instance_State {
Attrs *attrs;
I have the following line assignment in the instance$static$init:
HeapFoo.xs
instance$static$init() {
obj.attrs = $addr(params.sharedAddr);
I want to test this on multiple targets/platforms, so I have a Buffers
module:
Buffers.xdc
module Buffers
config Char buf[length];
I create a buffer and assign it to sharedAddr
testHeapFoo.cfg
Buffers = xdc.useModule('ti.sdo.ipc.testsHeaps.Buffers');
var buf = Buffers.buf;
buf.length = 1024;
heapParams.sharedAddr = buf;
The 1024 char buffer does get created (looked in the mapfile). But I'm
getting an build error. It is complaining about the obj.attrs =
$addr(params.sharedAddr); line
"js: "/ti/sdo/ipc/HeapFoo.xs", line 98: Cannot convert
ti.sdo.ipc.testsHeaps.Buffers/buf to java.lang.Long"
I also tried
heapParams.sharedAddr = buf.$addrof(0);
"js: "ti/sdo/ipc/HeapFoo.xs", line 98: Cannot convert
ti.sdo.ipc.testsHeaps.Buffers/buf/0.0 to java.lang.Long
I also tried changing the buf type in Buffers.xdc to Long...same thing.
Ideally, I'd like to just have a global variable in my testHeapFoo.c file
and reference that in the testHeapFoo.cfg file, but I don't think that is
possible.
Ideas? Did I just mess something up, or am I going down the wrong path.
Todd
Re: Creating a buffer in .cfg [message #2639 is a reply to message #2609] Wed, 06 May 2009 22:05 Go to previous messageGo to next message
Try removing the unnecessary (and undocumented) $adrr(). This function
is only used to create addresses from literal constants.
> that is an address (sharedAddr) and an Instance_State field attrs
> HeapFoo.xdc
> instance:
> internal
> Attrs *attrs;
> HeapFoo.xs
> module:
> Buffers.xdc ===========
> module Buffers
> testHeapFoo.cfg
> buf.length = 1024;
> I also tried heapParams.sharedAddr = buf.$addrof(0);
> file and reference that in the testHeapFoo.cfg file, but I don't think
> that is possible.
> Todd
Re: Creating a buffer in .cfg [message #2715 is a reply to message #2639] Thu, 07 May 2009 11:52 Go to previous messageGo to next message
I had tried that and was getting the following error:
js: "ti/sdo/ipc/HeapFoo.xs", line 98: XDC runtime error:
ti.sdo.ipc.HeapFoo.Instance_State#0: incompatible assignment to attrs
:xdc.services.intern.xsr.Value$Arr@192a848::ti.sdo.ipc.testsHeaps.Buffers/buf
gmake: *** [package/cfg/debug/testBufStatic1_x674.h] Error 1
I'm thinking I need to change my "Attrs *" to a Ptr in the Instance_state
and cast everywhere in the code.
I used $addr() because I do want to support supplying a constant (e.g.
0x20000) to sharedAddr.
Re: Creating a buffer in .cfg [message #3147 is a reply to message #2609] Thu, 07 May 2009 15:54 Go to previous message
Originally posted by: bob.biosbob.biz
assigning target pointer-values in the meta-domain attempts to mirror
the semantics of C in the following sense: "specific" pointer-values
(eg., of type 'Attr*') can be assigned to "generic" pointer-variables of
type 'Ptr' *without* a cast; but also, generic pointer-values of type
'Ptr' can be assigned to specific pointer-values *without* a cast as
well. [FYI -- C++ only allows specific => generic, which seems a little
more typesafe]. needless to say, direct assignment of one specific kind
of pointer to a *different* specific kind of is prohibited; some sort of
cast is required.
in this case, there are several different ways obj.attrs can be assigned
-- other than, of course, supplying a "specific" value of type 'Attrs*'.
as in C -- where you can write (Attrs*)(0x1234) -- you can use the
$addr(0x1234) operator to produce a "generic" pointer-value that can
then bev assigned to obj.attrs; the generated package/cfg/*.c file will
actually insert the (Attrs*) cast within the static initializer.
more elaborate, you can use the $addrof operator to obtain a "generic"
pointer to an element of an aggregate object -- either an element of an
array or else a field of a struct. this corresponds to static
initializers of the form '&arr[12]' or '&str.fld'. in the example here,
you can assign directly assign obj.attrs = Buffers.buf.$addror(0); note
that this value *could* have first assigned to 'sharedAddr', though this
step is really not necessary.
finally, you can use the $externPtr(symbol) operator to yield a
"generic" pointer value corresponding to this symbol....
here's a litte test Mod i put together....
module Mod {
struct Attrs {
Int x;
config Ptr sharedAddr;
config Attrs* attrs;
config Char buffer[length];
int main( int argc, char* argv[] );
in my .cfg script i then wrote....
var Mod = xdc.useModule('Mod');
Mod.buffer.length = 1024;
Mod.sharedAddr = Mod.buffer.$addrof(0);
Mod.attrs = Mod.sharedAddr;
Mod.attrs = Mod.buffer.$addrof(0); // same effect
Mod.attrs = $externPtr('myAttrs'); // global var
Mod.attrs = $addr(1234); // hard addr
> HeapFoo.xdc
> instance:
> internal
> Attrs *attrs;
> HeapFoo.xs
> module:
> module Buffers
> testHeapFoo.cfg
> buf.length = 1024;
> that is possible.
> Todd
Previous Topic:using specific version of gcc
Next Topic:Memory fill using configuration file
Current Time: Mon Jul 21 22:52:45 EDT 2025
Powered by FUDForum. Page generated in 0.03369 seconds
