Home » Eclipse Projects » Eclipse Platform » Plugin project referencing to Java project
Plugin project referencing to Java project [message #302345] Wed, 19 April 2006 10:47 Go to next message
Originally posted by: k.wigboldus.wisdom.nl
I have 2 Eclipse projects:
Project 1 is a normal Java project and should have a jar file as output
Project 2 is a Plugin project and should use the jar file (as library?)
I added a project reference from project 2 to project 1. I can compile
project 2.
However when running or debugging project 2 it can't find the classes of
project 1.
How can I solve this? I prefer a solution without making a jar file
manually each time. Within the team have installed eclipse on different
locations, so I can use only relative paths
Re: Plugin project referencing to Java project [message #302355 is a reply to message #302345] Wed, 19 April 2006 11:19 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
It doesn't work that way with plugins. You only reference other plugins,
not jars in another project.
> project 2.
> project 1.
Rich Kulp
Re: Plugin project referencing to Java project [message #302370 is a reply to message #302345] Wed, 19 April 2006 13:29 Go to previous message
Like Rich mentioned, if you want it on the classpath you gotta be in a
plugin.
So turn it from a java project into a plugin project (it would still be
a java project). Then you can use it in your workspace for plugins, but
when you export it as a jar for a java app it'll work fine like that as
well.
Later,
PW
Previous Topic:possible to have view with multiple categories in 3.2?
Next Topic:Automate Build Process
Current Time: Sat Jul 26 10:04:54 EDT 2025
Powered by FUDForum. Page generated in 0.05773 seconds
