Home » Language IDEs » Java Development Tools (JDT) » Redirect Plugin-Output
Redirect Plugin-Output [message #30197] Mon, 19 May 2003 16:58 Go to next message
is it possible to redirect the output of a plugin to the normal JDT console
instead of the PDE ErrorLog?
Thanks for your help
Michael
Dipl. Ing. Michael T
Re: Redirect Plugin-Output [message #30345 is a reply to message #30197] Mon, 19 May 2003 17:47 Go to previous message
Originally posted by: richkulp.nos.pam.us.ibm.com
They are two very different concepts. The JDT console is for output from
a launched application. There is actually one JDT console page per
launched application, but you only see one at a time though. Using the
menu from the console you can switch to the outputs from other launched
applications. Since you want to be coming from a plugin, you are not
running within any launched applications, so the JDT console doesn't
apply to it.
Previous Topic:maintenance release?
Next Topic:Help with Mapped Drive change
Current Time: Sat Aug 02 04:16:29 EDT 2025
Powered by FUDForum. Page generated in 0.04076 seconds
