Home » Eclipse Projects » Subversive » binary libary
binary libary [message #2597] Mon, 31 July 2006 14:04 Go to next message
I would say the following are more important than an all Java solution.
Both of the these fall out from the realization that subversion's
client is not a thin client; its a 'rich client' (if I may), and much
work is performed on the local host.
1) Use of command-line and eclipse based subversion interchangably. I'd
like to use command-line commands sometimes. I wouldn't want to lose
the option of switching to command line mode.
2) Client-server interoperability. I don't want to be either of these
situations:
I can't upgrade my subversion server because I have eclipse users
running an incompatible subversion client implementation.
I can't use eclipse to interact with my repository because the
repository has been upgraded to a newer version of subversion.
Also, I'm less bothered by the dependence on a binary library because of
these other considerations:
1) Eclipse can leverage the binary library that I have already installed
on my system as part of my OS.
2) The svn proposal has an adapter plugin that will allow me to use a
different client library. Can Subversive include this feature in their
proposal?
John
Re: binary libary [message #3803 is a reply to message #2597] Tue, 01 August 2006 11:19 Go to previous messageGo to next message
Hello John,
Thank you for good points. Genarally all of them are already addressed in
Subversive. Let's go though them:
> like to use command-line commands sometimes. I wouldn't want to lose the
You can use Subversive together with other tools like command-line client,
TortoiseSVN, etc. It means that you can make some operations by one tool
then switch to another and continue without any complications. Till the
recent releases it was not so for all operations, but now we implemented
conflict editor, so you are able to handle temporary files, which are
created in case of conflict by standard SVN tools. Note that Subversive
avoid such files creation, but we included functionality to support then in
order to allow switch between Subversive and other tools.
> situations:
It's more or less the question about clients (or rather protocols)
compatibility. As far as I know SVN team aware about it, so described
situation shouldn't happen.
In case of pure Java library like JavaSVN this question doesn't actual. In
case of native JavaHL solution user should manage installation of
appropriate libraries by himself and it's a disadvanatge of this approach.
> proposal?
We already implemented this functionality, because it's pretty important. In
the Subversive 1.0.1 we improved interface between project parts and defined
Eclipse extension points, which allows us to switch between different client
libraries. Currently we support JavaSVN and JavaHL, but it's easy to add new
library if it will appear in future (personally hope to see stable pure Java
library with EPL license). Current JavaHL-based solution is not tested
enough, but we plan to make it stable in the near future. It also doesn't
have some extended features of Subversive, because JavaHL doesn't contain
not standard features, which we added to JavaSVN. We are evaluating ways how
to handle them on top of JavaHL. Cooperation with SVN team on JavaHL
improvement is one of the possible options.
Igor Vinnykov
Re: binary libary [message #3842 is a reply to message #3803] Wed, 02 August 2006 16:36 Go to previous messageGo to next message
Igor,
Thanks.
Regardless of your assertion, I'm not 100% confidant that different
implementations are compatible. My organization is converting from cvs
to svn now and are in a learning ramp. One of our guys uses IntelliJ
which is based on JavaSVN. He found a way to run JavaSVN from the
command line. His experience using the JavaSVN in a command line is
different from the experience I have using the subversion client command
line.
Here are some differences we have found after a couple of hours of
working with the two tools:
1) JavaSVN will do a commit without requiring a log message. subversion
insists on a log message; it won't even accept a blank line entered in
the editor.
2) We're not sure JavaSVN is succesful in committing a single file, as
in: svn commit myFile.txt, because it doesn't output "Committed revision
39." like the subversion client would.
These differences don't make subversion and JavaSVN client incompatible.
However, they are enough to unsettle me. I'm sure I would use the
subversion client implementation in Eclipse. I'm sorry I wouldn't be
able to make use of features that depend on JavaSVN extensions. I hope
that I would be productive anyway.
John
Re: binary libary [message #3849 is a reply to message #3842] Wed, 02 August 2006 18:12 Go to previous messageGo to next message
> line.
> the editor.
Huh? I did many times commits using this options: -m ""
i.e. with empty log message. And I did not see any complains from SVN
server.
Are you sure that write was successful when you write some
information in file and close it? This operation also does not output
anything to console.
I hope that you just joke. At least your reasons look so.
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: binary libary [message #3877 is a reply to message #3849] Fri, 04 August 2006 11:57 Go to previous messageGo to next message
Konstantin,
On my point, I do not joke. My point is that even at the most
superficial level, the JavaSVN client and the subversion client are
different in their behavior.
>> cvs to svn now and are in a learning ramp. One of our guys uses
>> IntelliJ which is based on JavaSVN. He found a way to run JavaSVN
>> from the command line. His experience using the JavaSVN in a command
>> line is different from the experience I have using the subversion
>> client command line.
>> subversion insists on a log message; it won't even accept a blank line
>> entered in the editor.
> server.
Thanks. I didn't think to try specifying an empty string using '-m'.
Still, there is a (superficial) difference between JavaSVN and
subversion client.
>> revision 39." like the subversion client would.
> Are you sure that write was successful when you write some information
> in file and close it? This operation also does not output anything to
> console.
My only point is that JavaSVN and subversion client are different on
reporting back the status of a commit. I'm not making a useability
judgement on any tool. Sorry if I came off that way.
>> incompatible. However, they are enough to unsettle me. I'm sure I
>> would use the subversion client implementation in Eclipse. I'm sorry
>> I wouldn't be able to make use of features that depend on JavaSVN
>> extensions. I hope that I would be productive anyway.
I am not joking around the point that I would feel more comforable using
the client library that is maintained by the originators of subversion.
If you don't see my point of view, then I hope I'm giving you a good laugh.
John
Re: binary libary [message #4228 is a reply to message #3877] Tue, 08 August 2006 05:43 Go to previous messageGo to next message
Originally posted by: michal.dobisek.polarion.com
"John J. Franey" <jjfraney@verizon.net> wrote
> Konstantin,
> On my point, I do not joke. My point is that even at the most superficial
> level, the JavaSVN client and the subversion client are different in their
> behavior.
I would say, that there is a little misunderstanding here. One thing is the
SVN protocol compatibility (which Igor Vinnykov refers to) - which is really
important during the Subversion development - you can in most cases use e.g.
old client with newer server and you will have no problem in most cases.
The other thing is the emulation of command line interface provided by
JavaSVN - differences in this have no impact on the client-server
compatibility. If I understood correctly, than all your points of difference
belonged to this category.
Michal
Re: binary libary [message #4506 is a reply to message #4228] Tue, 08 August 2006 12:51 Go to previous messageGo to next message
Yes. I agree. There are two categories of compatibility: 1)
client-server and 2) client-client. I have concerns in both categories.
I apologize if I have mixed them up in above responses.
>> Konstantin,
>> behavior.
Yes. In most cases, no problem. However, there is no guarentee from
subversion team that a client from one release will work with a server
from another release. But this is ok for me, because when the server
upgrades, I upgrade my client because a client and server of a given
release are always avaialable from subversion team at the same time. Is
the same said for JavaSVN (subversive client)? In other words, will a
compatible JavaSVN client be avaiable at the same time as a subversion
server? Always...going forward?
Correct, all my points of difference belong to this category.
I have stronger feelings about this category. Mainly because the client
side of the conversation does more than just talk with the server. More
than just emulation of command line interface, there is some important
functionality that is implemented only on the client side (e.g. status,
diff, revert). These should behave the same in all implementations of
the client side. Also, the client side data will be accessed and
modified by client side implementations and clients should be compatible
in terms of these data formats and semantics. Finally, the clients can
be compatible in terms of configuration (although not expressly
necessary). This would allow my .subversion/config file and my
authentication cache be used by any client implementation.
> Cheers,
> Michal
Re: binary libary [message #4782 is a reply to message #4228] Wed, 09 August 2006 13:42 Go to previous message
There are two other areas in which compatibility problems will arise,
sooner or later.
First, the workspace.
As simple example: You cannot use subversion 1.4 clients unless JavaSVN
has implemented all changes of the workspace.
Second, the repository.
With the implementation of the file protocol, JavaSVN accesses the
repository too.
Manfred
Previous Topic:Subclipse SVN proposal submitted to Eclipse
Next Topic:extension point to contribute custom decorators for comments in history views
Current Time: Mon Jul 14 05:08:10 EDT 2025
Powered by FUDForum. Page generated in 0.49386 seconds
