[buckminster-dev] NoSuchMethodError while building using buckminster [message #30123] |
Thu, 15 January 2009 01:22  |
--0-91623979-1232000564=:15118
Content-Type: text/plain; charset=iso-8859-1
I am getting the following exception while building my project with buckmin=
ster
=A0=A0=A0=A0 [java] java.lang.NoSuchMethodError: org.eclipse.buckminster.ru=
ntime.IFileInfo.getRemoteName()Ljava/lang/String;
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.download.policy.Ar=
chivePolicy.readRemoteFile(ArchivePolicy.java:160)
chivePolicy.update(ArchivePolicy.java:119)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.download.internal.=
CacheImpl.open(CacheImpl.java:105)
CacheImpl.open(CacheImpl.java:113)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.pde.internal.Eclip=
seImportReaderType.localizeContents(EclipseImportReaderType. java:703)
seImportReader.localize(EclipseImportReader.java:231)
seImportReader.getPluginModel(EclipseImportReader.java:151)
seImportReader.<init>(EclipseImportReader.java:63)
seImportReaderType.getReader(EclipseImportReaderType.java:44 4)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.version.Provi=
derMatch.getReader(ProviderMatch.java:173)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.ctype.Abstrac=
tComponentType.getResolution(AbstractComponentType.java:212)
tComponentType.getResolution(AbstractComponentType.java:229)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.rmap.model.Re=
sourceMap.resolve(ResourceMap.java:245)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.buckminster.core.resolver.Reso=
urceMapResolver.innerResolve(ResourceMapResolver.java:165)
lverNodeWithJob.resolve(ResolverNodeWithJob.java:177)
lverNodeWithJob.run(ResolverNodeWithJob.java:187)
lverNodeWithJob$NodeResolutionJob.run(ResolverNodeWithJob.ja va:60)
=A0=A0=A0=A0 [java] =A0=A0=A0 at org.eclipse.core.internal.jobs.Worker.run(=
Worker.java:55)
Here is the part of rmap file:
=A0=A0=A0 <searchPath name=3D"mysource">
=A0=A0=A0=A0=A0=A0=A0 <provider readerType=3D"eclipse.import" componentType=
s=3D"osgi.bundle" mutable=3D"false" source=3D"false">
=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 <uri format=3D"http://localhost/build/=
test.map"/>
=A0=A0=A0=A0=A0=A0=A0 </provider>=A0=20
=A0=A0=A0 </searchPath>
However I found that even though it is able to work with many plugins, only=
three eclipse plugins are giving this exception.=20
The difference between these plugins with others is that:
1) It has only one file in META-INF - MANIFEST.MF, while all other plugins =
have eclipse.inf, ECLIPSE.RSA and ECLIPSE.SF
2) And some license files.
Please let me know if you want more information.
Suresh
=0A=0A=0A
Content-Type: text/html; charset=us-ascii
<table cellspacing="0" cellpadding="0" border="0" ><tr><td valign="top" style="font: inherit;">Hi,<br><br>I am getting the following exception while building my project with buckminster<br><br> [java] java.lang.NoSuchMethodError: org.eclipse.buckminster.runtime.IFileInfo.getRemoteName()Lja va/lang/String; <br> [java] at org.eclipse.buckminster.download.policy.ArchivePolicy.readRe moteFile(ArchivePolicy.java:160) <br> [java] at org.eclipse.buckminster.download.policy.ArchivePolicy.update (ArchivePolicy.java:119) <br> [java] at org.eclipse.buckminster.download.internal.CacheImpl.open(Cac heImpl.java:105) <br> [java] at org.eclipse.buckminster.download.internal.CacheImpl.open(Cac heImpl.java:113) <br> [java] at
org.eclipse.buckminster.pde.internal.EclipseImportReaderType .localizeContents(EclipseImportReaderType.java:703) <br> [java] at org.eclipse.buckminster.pde.internal.EclipseImportReader.loc alize(EclipseImportReader.java:231) <br> [java] at org.eclipse.buckminster.pde.internal.EclipseImportReader.get PluginModel(EclipseImportReader.java:151) <br> [java] at org.eclipse.buckminster.pde.internal.EclipseImportReader.&am p;lt;init>(EclipseImportReader.java:63) <br> [java] at org.eclipse.buckminster.pde.internal.EclipseImportReaderType .getReader(EclipseImportReaderType.java:444) <br> [java] at org.eclipse.buckminster.core.version.ProviderMatch.getReader (ProviderMatch.java:173) <br> [java] at
org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:212) <br> [java] at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:229) <br> [java] at org.eclipse.buckminster.core.rmap.model.ResourceMap.resolve( ResourceMap.java:245) <br> [java] at org.eclipse.buckminster.core.resolver.ResourceMapResolver.in nerResolve(ResourceMapResolver.java:165) <br> [java] at org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.re solve(ResolverNodeWithJob.java:177) <br> [java] at org.eclipse.buckminster.core.resolver.ResolverNodeWithJob.ru n(ResolverNodeWithJob.java:187) <br> [java] at
org.eclipse.buckminster.core.resolver.ResolverNodeWithJob$No deResolutionJob.run(ResolverNodeWithJob.java:60) <br> [java] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)<br ><br>Here is the part of rmap file:<br> <searchPath name="mysource"><br> <provider readerType="eclipse.import" componentTypes="osgi.bundle" mutable="false" source="false"><br> <uri format="http://localhost/build/test.map"/><br> </provider> <br> </searchPath><br><br>However I found that even though it is able to work with many plugins, only three eclipse plugins are giving this exception. <br><br>The difference between these plugins with others is that:<br>1) It has only one file in META-INF - MANIFEST.MF,
while all other plugins have eclipse.inf, ECLIPSE.RSA and ECLIPSE.SF<br>2) And some license files.<br><br>Please let me know if you want more information.<br><br>Thanks<br>Suresh<br><br></td></tr ></table><br>
--0-91623979-1232000564=:15118--
Re: [buckminster-dev] NoSuchMethodError while building using buckminster [message #30160 is a reply to message #30123] |
Thu, 15 January 2009 03:18  |
Hi Suresh,
The exception suggests that you use a Buckminster product that is too
old for the features that you then install into it. You will find the
latest product here:
http://www.eclipse.org/downloads/download.php?file=/tools/bu ckminster/products/buckminster.product-1.1.0.r09843.zip
Thomas Hallgren
suresh inavolu wrote:
> buckminster
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> org.eclipse.buckminster.pde.internal.EclipseImportReader.<init >(EclipseImportReader.java:63)
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> </provider>
> </searchPath>
> Thanks
> Suresh
FUDForum. Page generated in 0.03597 seconds
