External references [message #30095] |
Fri, 24 July 2009 05:21 |
Originally posted by: paul.waleter.freemailhost.de
I have created an IDE for a small dedicated DSL.
The problem is that I need to allow that one project can
reference to another project (e.g. having depencencies to other projcts).
There is also a huge run-time library (much like the java lib) that is
referenced
from each project. The user wants to be able to click on a symbol and to
open
the defintion regardless where it was done (in this current project, in a
another project or
in the run-time files)
The problem I'm facing is things like *when* to parse the run-time libs and
the
referenced projects, how to keep the models up-to-date. Should I have a
workspace model instead of separate etc.
Regarding the run-time libs it seem enough to have this parsed once per
workspace
and not per project.
Has anybody done this kind of handling using IMP, or any other way?
BR
P
FUDForum. Page generated in 0.03563 seconds
