Home » Eclipse Projects » Eclipse Platform » Synchronize with external files
Synchronize with external files [message #300801] Fri, 17 March 2006 04:21 Go to next message
is it possible, to arrange a compare with external files, f.e.
- Project in workspace (not under source control, or other sourcecontrol as cvs) synchronize with moduls under source control (cvs)
or
- Project in workspace (not under source control, or other sourcecontrol as cvs) synchronize with files outside of workspace
with the same functions as the "Team Synchronize - View" (Override and Update ...) ?
Maybe an extension of the Team Synchronize View / Available synchronization types with something like other Files and File Chooser ...
Is there already an exisiting plugin with those features ?
Thanks for any hints !
Best Regards,
Christian
Re: Synchronize with external files [message #301353 is a reply to message #300801] Wed, 29 March 2006 08:03 Go to previous messageGo to next message
any one has a idea, or can help me?
BR
Christian H.
Re: Synchronize with external files [message #301358 is a reply to message #301353] Wed, 29 March 2006 09:15 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
No, not possible.
You could import the contents as a project if you wanted. Eclipse will create a .project file for a simple project at the root of the project itself. It doesn't need to be under the workspace though. If you're using CVS, and each of the folders under the project has a CVS directory, then you'll be able to see the contents on a remote CVS server trivially.
Alex.
Re: Synchronize with external files [message #301464 is a reply to message #301358] Fri, 31 March 2006 04:41 Go to previous message
Hi, Alex
OK, i could create a project with links to the filesystem
Sorry, i don't get it.
Sure, if i have to projects in workspace, i'm able to do a ' compare with each other ' , then
i get a Structure Compare - but i need a synchronize view.
what i really want to do is a compare of two projects, with all the features i have
in the synchronize view.
Normally i do a ' Compare with Branch or Version ' between a project in workspace
under cvs control, with another Version/Branch of that project in cvs.
I need a synchronize feature, where i normally only have a structure compare, f.e. =
Synchronize of a project in workspace under ClearCase control, with a
Branch/Version of that project in cvs.
Synchronize of a project in workspace under ClearCase control with
another project in workspace (after import) or a project in filesystem
outside workspace.
Christian
Previous Topic:Can ICellModifier.modify get a null value?
Next Topic:Add new encoding
Current Time: Fri Jul 18 19:14:35 EDT 2025
Powered by FUDForum. Page generated in 0.03549 seconds
