Home » Eclipse Projects » Eclipse Platform » How can I tell my update project to build the plugins as ZIP files NOT jar files
How can I tell my update project to build the plugins as ZIP files NOT jar files [message #300708] Wed, 15 March 2006 17:56 Go to next message
I have a feature.xml that has some plugins. One of the plugins does not
use a MANIFEST.MF file, that is, using Eclipse 3.0.0 plugin format.
This is my documentation plugin and I want it built as a zip file when
building my feature. How would I do that?
I specify my documentation plugin in my feature.xml as below:
<plugin id="MyDocPlugin" download-size="0" install-size="0"
version="1.0.0" unpack="false"/>
Still, the update site project builds my plugin and bundles it as a jar
file!
Please advice/help!
Remember that I am not trying export the plugin out manually but build
it via my update site project.
The second part of my question is: Can I simply put the zip file on my
update site and Eclipse will unzip it automatically when I do an update?
If not, what do I have to do?
Re: How can I tell my update project to build the plugins as ZIP files NOT jar files [message #300711 is a reply to message #300708] Wed, 15 March 2006 20:13 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
Plugins are always distributed as jars on an update site. When it's being downloaded via a feature, the update manager unpacks it on the local machine and moves it into the plugins/ folder unpacked.
Alex.
Re: How can I tell my update project to build the plugins as ZIP files NOT jar files [message #300741 is a reply to message #300711] Thu, 16 March 2006 12:56 Go to previous message
> Alex.
Thanks! You are correct...Also, I had to set 'unpack' to TRUE.
Previous Topic:Workspace in use
Next Topic:osgi.bundles property for different install location
Current Time: Sun Aug 31 18:28:11 EDT 2025
Powered by FUDForum. Page generated in 0.03494 seconds
