Home » Language IDEs » Java Development Tools (JDT) » ANT and JDK classpath for ANT based compilations
ANT and JDK classpath for ANT based compilations [message #30060] Mon, 19 May 2003 15:27 Go to next message
Hi there,
I just recognized a problem with the JDK classpath used during ANT based
compilations. I'm running eclipse itself with jdk 1.4.1 (the IDE startup)
but have jdk 1.3.1 based application projects (using the preferences from
Java/Installed JREs). Despite having set ANTs runtime classpath explicitly
to the jdk1.3.1 jars, compilation runs seem to mix with classes from the jdk
1.4.1 (the JRE under which the eclipse IDE itself is running). Application
classes with direct reference to jdk classes/interfaces (i.e. through
inheritance) get a different serial version UID when compiled from within
eclipse (where the preferences configured JRE with jdk 1.3.1 is used)
compared to the class files which are created when I compile through ANT
scripts (invoked with the eclipse ANT runner, of course with the
JDTCompilerAdapter correctly set).
When I start the Eclipse IDE with a 1.3.1 JRE as well, the "normal" eclipse
compile and the compile with ANT scripts through the eclipse ANT runner
produce identical class results with identical serial version UID (which is
what we need). For other reasons, I normally need to run the Eclipse IDE
with jdk 1.4.1 but still have to work on application projects under jdk
1.3.1.
This currently prevents using the eclipse ANT runner when the eclipse IDE
and the application projects have to be based on different jdk's.
The problem is new since eclipse 2.1. - we did the same things (mixing IDE
used jdk 1.4.1 and "Installed JREs "settings jdk 1.3.1) with eclipse 2.0 and
the related ANT runner without any problem (always had identical classes
from compilations with both compilation methods)!
Have I overlooked a 2.1. parameter or preferences setting or any other idea?
Thanks for feedback.
Andreas
Re: ANT and JDK classpath for ANT based compilations [message #31113 is a reply to message #30060] Tue, 20 May 2003 09:35 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Zimmer wrote:
> Hi there,
> 1.3.1.
> Regards
> Andreas
Do you have a reproducable test case. You mention that this occurs for
classes that are derived from JDK classes. Are there any JDK classes in
particular you are using?
Re: ANT and JDK classpath for ANT based compilations [message #33246 is a reply to message #31113] Wed, 21 May 2003 08:29 Go to previous messageGo to next message
"Dave Wegener" <wegener@cboenospam.com> schrieb im Newsbeitrag
news:badav4$8vg$1@rogue.oti.com...
The original test scenario is a little complex, because it happens within a
large application which is based on a similarly large framework and
corresponding ANT build scripts. We've observed the problem actually on two
classes (I'm sure we'll find more) which have an inheritance relation with
the jdk:
One class is just using marker interface java.io.Serializable,
the other is extending java.util.ArrayList
Re: ANT and JDK classpath for ANT based compilations [message #33807 is a reply to message #33246] Wed, 21 May 2003 10:43 Go to previous messageGo to next message
> the jdk:
You can only serialize classes that implement the java.io.Serializable
interface. Are you able to compile the class that is implementing the
marker interface seperately from the rest of your project. If not, you
can try to strip it down so that it doesn't depend on any other classes.
The serialVersionUID is computed at run time based on the characteristics
of the .class file. Different compilers will produce different .class
files. The algorythm used by the runtime VM to calculate the
serialVersionUID uses elements of the class file that are likely to be
different for different compilers. This produces the incompatible
serialVersionUIDs. This is a known limitation of using the runtime VM to
calculate serialVersionUIDs. The best solution is to explicitly add the
serialVersionUID field to each of your serializable classes.
However, a given compiler should always produce compatible class files.
If the classes compiled within Eclipse produce different IDs than classes
compiled with and ant script using the JDTCompilerAdapter, it would be a
bug and you should submit a bug report with a reproducable test case.
You can use the command line tool serialver to compute the
serialVersionUID for a given class. You can use this to compare the IDs
obtained when compiling using different JDKs to start Eclipse.
Start Eclipse up with a 1.3.1 VM and use the internal compiler to compile
the class. Run serialver against the class. Run the ant build script to
compile the file. Re-run serialver to compare results. Stop Eclipse and
restart it. Repeat the steps.
Are you sure that the ant script is using the JDTCompilerAdapter. If you
look at the output in the Debug view, the JDTCompilerAdapter produces
different messages than the standard javac compiler.
On my system the javac compiler only displays the number of classes being
compiled. The adapter displays additional lines indicating how many lines
were compiled and how long the compile took.
Re: ANT and JDK classpath for ANT based compilations [message #34366 is a reply to message #33807] Wed, 21 May 2003 15:01 Go to previous messageGo to next message
news:bag3a9$k60$1@rogue.oti.com...
Well, we're just implementing java.io.Serializable for the purpose to make
the class serializable. Because the problem class is only one example and I
still believe the underlying Problem belongs to any class with references
into the jdk, explicitly setting serialVersionUID is not a solution. I've
isolated the problem to the one sample problem class which implements
Serializable and the problem can now be easily reproduced by compilng just
this one class. See my additional comments later on ...
I most probably have to do so - the reproducable test case is now
available - the problem persists.
Done. The serialVersionUIDs differ when I compile with the Eclipse internal
compiler compared to the class from the compile run through ANT.
JDTCompilerAdapter correctly set and used (also according to your
explanation below). The different serialVerionUIDs only happen, if I start
eclipse IDE with jdk1.4.1 and have an application project JRE setting in the
eclipse preferences to JRE 1.3.1. If eclipse startup and preferences JRE
setting is both on jdk1.3.1 everything's fine and serialVersionUIDs are
identical.
Checked again and definitely OK.
Re: ANT and JDK classpath for ANT based compilations [message #34945 is a reply to message #34366] Thu, 22 May 2003 05:02 Go to previous messageGo to next message
Did you enter a bug report for further investigation ?
"Zimmer" <zitecs@t-online.de> wrote in message
news:bagici$1vf$1@rogue.oti.com...
characteristics
to
I
classes
compile
to
internal
the
> identical.
you
being
lines
Re: ANT and JDK classpath for ANT based compilations [message #35948 is a reply to message #34945] Thu, 22 May 2003 17:19 Go to previous message
You found it meanwhile as I've seen on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37940
For all others who may be interested in this case, please look at the above
bug link - there is a solution through setting the javac target parameter to
"1.1" or adapting the eclipse preferences as explained in comments No. 6/7
within above bug link.
Many thanks to all who helped!
Andreas
"Philippe Mulet" <philippe_mulet@fr.ibm.com> schrieb im Newsbeitrag
news:bai3np$4dh$1@rogue.oti.com...
you
classes.
> characteristics
> to
the
make
and
> I
references
I've
just
files.
> classes
a
IDs
> compile
> to
and
> internal
start
> the
> > identical.
> you
> being
> lines
Previous Topic:How to open single Java file
Next Topic:How do I add properties to property sheet?
Current Time: Fri Jul 18 00:45:16 EDT 2025
Powered by FUDForum. Page generated in 0.04235 seconds
