Home » Eclipse Projects » Eclipse Platform » How do I make eclipse use CVS information already present on the filesystem.
How do I make eclipse use CVS information already present on the filesystem. [message #300341] Tue, 07 March 2006 16:11 Go to next message
Originally posted by: simon_philips_g.yahoo.com
I would like to use an external cvs client to check in and check out
files in my project. But I wan't to use the eclipse comparision editor for
cvs and also sometimes to check in and check out files. How can I make
eclipse recognise the cvs information written by the external cvs client?
thanks,
Simon PG
Re: How do I make eclipse use CVS information already present on the filesystem. [message #300524 is a reply to message #300341] Fri, 10 March 2006 10:01 Go to previous messageGo to next message
Simon,
You should be able to just perform a Team/Share on the project and it
will get mapped to CVS in Eclipse. The one caveat is that Eclipse does
not support the local connection method so you'll need to use ether ext
or pserver. If your using ext, you may want to configure ext to use the
internal Eclipse SSH connection method (extssh). This can be done on the
Team>CVS>EXT Connection Method preference page.
Michael
Simon Philips wrote:
> thanks,
> Simon PG
Re: How do I make eclipse use CVS information already present on the filesystem. [message #300530 is a reply to message #300524] Fri, 10 March 2006 11:34 Go to previous messageGo to next message
You would like to use :ext: method or :pserver: as this gives you the
integration with the external cvs client.
You would like to see in Preferences->Team->CVS->Automatically share
projects containing CVS meta information and be sure it is checked. The
Eclipse will automatically use the already present information from the
CVS directories.
Eclipse 3.2M5 here, I'm not sure is this is present before 3.2.
Michael Valenta wrote:
> Simon,
> Michael
>> check out
>> for
>> thanks,
>> Simon PG
Re: How do I make eclipse use CVS information already present on the filesystem. [message #301115 is a reply to message #300524] Thu, 23 March 2006 18:00 Go to previous messageGo to next message
Hi Michael,
The Team/Share is not working. It asks for a module name in cvs to
map the project folder (project root) to and commits the entire contents of
the project to that module. But I do not wan't the whole project mapped,
just some of the source folders.
thanks,
Simon PG
"Michael Valenta" <Michael_Valenta@ca.ibm.com> wrote in message
news:dus4df$4rr$1@utils.eclipse.org...
> Simon,
> You should be able to just perform a Team/Share on the project and it will
> get mapped to CVS in Eclipse. The one caveat is that Eclipse does not
> support the local connection method so you'll need to use ether ext or
> Michael
>> out
>> for
>> thanks,
>> Simon PG
Re: How do I make eclipse use CVS information already present on the filesystem. [message #301117 is a reply to message #300530] Thu, 23 March 2006 18:05 Go to previous messageGo to next message
Hi Danail,
I am using the :pserver: method. The automatically share feature
is present in 3.1.2 too, but I do not know how it works. I have it checked
but on right clicking a file or folder in the project which as cvs
information, it does not show up any Team menu options to commit, update
etc.
I tried 3.2M5 too but same thing there also.
Am I missing some setting?
thanks,
Simon PG
"Danail Nachev" <d_nachev@prosyst.bg> wrote in message
news:dus9rv$h72$1@utils.eclipse.org...
> CVS directories.
>> Simon,
>> Michael
>>> Hi,
>>> out
>>> for
>>> client?
>>> thanks,
>>> Simon PG
Re: How do I make eclipse use CVS information already present on the filesystem. [message #301129 is a reply to message #301115] Fri, 24 March 2006 00:31 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
That's not quite the original question, but the way that Eclipse works is to share a project by default if you right-click on a project. I don't believe that it's possible to share a subset of the folders, since you have to enable team-sharing for a project-wide system.
Of course, you could always create a subproject for the stuff that you do want to share, which might be an easier way to achieve what you want to do.
Alex.
Re: How do I make eclipse use CVS information already present on the filesystem. [message #301209 is a reply to message #301129] Fri, 24 March 2006 14:02 Go to previous message
Eclipse needs to have CVS information in all the folders in the path leading
up to actual folder in question. I created dummy CVS information in all the
folders and it works.
The content of the CVS/Repository file should be
CVSROOT/Emptydir
The contents of CVS/Entries and CVS/Root files are the usual.
--Simon PG
"Alex Blewitt" <automatic@javalobby.org> wrote in message
news:21214478.1143178301388.JavaMail.root@cp1.javalobby.org...
> do.
> Alex.
Previous Topic:When can we see "open project"
Next Topic:how to programmtically set selection in a FormText?
Current Time: Mon May 12 14:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.05083 seconds
