Home » Eclipse Projects » Eclipse Platform » Problems with Eclipse 3.2 (x64)
Problems with Eclipse 3.2 (x64) [message #299513] |
Mon, 20 February 2006 02:48  |
--------------070707090408090405040200
Hello All,
I am running Fedora Core 4 (x64), I have SUN's jdk 1.5 revision 6 (x64)
installed. I am continuously facing problems while running eclipse.
At times eclipse crashes without warning, on a better day it works for a
while before crashing.
If I run eclipse and JBoss both on my machine, the whole machine locks
up after a few deployments, and I have to reset my system.
Anyone else facing similar problems? Is this an issue with 64 bit
Eclipse or 64 bit JDK?
I am attaching the log file I received while running eclipse 3.2 m5. I
only opened a java file and pressed CTRL-SPACE to invoke code complete
and it crashed.
Muhammad Momin Rashid.
Content-Type: text/x-log;
name="hs_err_pid12485.log"
Content-Disposition: inline;
filename="hs_err_pid12485.log"
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00000034e5f0ce6a, pid=12485, tid=46912496295872
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_06-b05 mixed mode)
# Problematic frame:
# C [libgobject-2.0.so.0+0xce6a]
--------------- T H R E A D ---------------
Current thread (0x0000000040115c10): JavaThread "main" [_thread_in_native, id=12485]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x0000000014f51600
Registers:
RAX=0x0000000000000001, RBX=0x00007fffffa38560, RCX=0x0000000000000000, RDX=0x00007fffffa38500
RSP=0x00007fffffa38410, RBP=0x0000000014f51600, RSI=0x0000000000000001, RDI=0x00007fffffa38560
R8 =0x00007fffffa38500, R9 =0x3a3a3a3a3a3a3a3a, R10=0x00002aaaab328070, R11=0x00002aaaab328070
R12=0x00002aab1404aec0, R13=0x00002aab0b8bc6f0, R14=0x00002aab1ccd8f38, R15=0x00007fffffa385c0
RIP=0x00000034e5f0ce6a, EFL=0x0000000000010206, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007fffffa38410)
0x00007fffffa38410: 00002aab0a7fcc40 00002aab13623700
0x00007fffffa38420: 00002aab0a7fcc40 00000034e5f0faf9
0x00007fffffa38430: 00000034e5f13f78 00002aab0a7fd228
0x00007fffffa38440: 0000000040116500 00007fffffa38500
0x00007fffffa38450: 00007fffffa384e0 00007fffffa38560
0x00007fffffa38460: 00000000401164c0 00002aab0a7fcc50
0x00007fffffa38470: 00000000401164e0 00002aab0b8bc730
0x00007fffffa38480: 00002aab13647430 00000034e573f4ce
0x00007fffffa38490: 00007fffffa38f70 00002aab0b8bc6f0
0x00007fffffa384a0: 00002aab13623700 0000000000000000
0x00007fffffa384b0: 00007fffffa38f70 00002aab14f51600
0x00007fffffa384c0: 00002aab14f51600 00002aab14f51600
0x00007fffffa384d0: 00007fffffa38590 00000034e5f0b82c
0x00007fffffa384e0: 00007fffffa38540 00000034e5f27b49
0x00007fffffa384f0: 0000000000000000 00000032c0b973b7
0x00007fffffa38500: 0000000014f51600 0000000000000000
0x00007fffffa38510: 0000000000000000 0000000000000000
0x00007fffffa38520: 0000000000000000 0000000000000000
0x00007fffffa38530: 0000000000000000 0000000000000000
0x00007fffffa38540: 0000000000000000 0000000000000000
0x00007fffffa38550: 0000000000000000 0000000000000001
0x00007fffffa38560: 00002aab13623700 0000000000000000
0x00007fffffa38570: 0000000000000000 0000000000000005
0x00007fffffa38580: 0000000000000007 00002aab0a7fcc40
0x00007fffffa38590: 00002aab14f50e10 0000000040115d60
0x00007fffffa385a0: 0000000000000000 0000000014f51600
0x00007fffffa385b0: 00002aab0a7fcc40 00000034e5f0fefe
0x00007fffffa385c0: 0000003000000018 00007fffffa386b0
0x00007fffffa385d0: 00007fffffa385e0 00002aaaab3247c0
0x00007fffffa385e0: 00002aaaab328070 00002aab07b00020
0x00007fffffa385f0: 0000000014f51600 0000000000000000
0x00007fffffa38600: 00002aaaab3247c0 00002aaaab3247b8
Instructions: (pc=0x00000034e5f0ce6a)
0x00000034e5f0ce5a: 08 48 89 fb 48 8b 2a 48 85 ed 0f 84 97 00 00 00
0x00000034e5f0ce6a: 48 8b 45 00 48 85 c0 74 51 48 8b 37 48 8b 38 e8
Stack: [0x00007fffff842000,0x00007fffffa42000), sp=0x00007fffffa38410, free space=2009k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting, step 120, id 0xb]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.gtk.OS._g_object_set(J[BIJ)V+0
j org.eclipse.swt.internal.gtk.OS.g_object_set(J[BIJ)V+12
j org.eclipse.swt.widgets.Table.cellDataProc(JJJJJ)J+382
j org.eclipse.swt.widgets.Display.cellDataProc(JJJJJ)J+25
v ~StubRoutines::call_stub
j org.eclipse.swt.internal.gtk.OS._gtk_tree_view_set_cursor(JJ JZ)V+0
j org.eclipse.swt.internal.gtk.OS.gtk_tree_view_set_cursor(JJJ Z)V+13
j org.eclipse.swt.widgets.Table.selectFocusIndex(I)V+62
j org.eclipse.swt.widgets.Table.setSelection(I)V+15
j org.eclipse.jface.text.contentassist.CompletionProposalPopup .selectProposal(IZ)V+102
j org.eclipse.jface.text.contentassist.CompletionProposalPopup .setProposals([Lorg/eclipse/jface/text/contentassist/IComple tionProposal;Z)V+313
j org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$7(Lorg/eclipse/jface/text/contentassist/CompletionPr oposalPopup;[Lorg/eclipse/jface/text/contentassist/ICompleti onProposal;Z)V+3
j org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run()V+196
j org.eclipse.swt.custom.BusyIndicator.showWhile(Lorg/eclipse/ swt/widgets/Display;Ljava/lang/Runnable;)V+116
j org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(Z)Ljava/lang/String;+72
j org.eclipse.jface.text.contentassist.ContentAssistant.showPo ssibleCompletions()Ljava/lang/String;+28
j org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor $AdaptedSourceViewer.doOperation(I)V+70
j org.eclipse.ui.texteditor.ContentAssistAction$1.run()V+9
j org.eclipse.ui.texteditor.ContentAssistAction.run()V+68
j org.eclipse.jface.action.Action.runWithEvent(Lorg/eclipse/sw t/widgets/Event;)V+1
j org.eclipse.ui.commands.ActionHandler.execute(Ljava/util/Map ;)Ljava/lang/Object;+64
j org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(Lorg/eclipse/core/commands/ExecutionEvent;)Ljava/lang/Obje ct;+79
j org.eclipse.core.commands.Command.executeWithChecks(Lorg/ecl ipse/core/commands/ExecutionEvent;)Ljava/lang/Object;+73
j org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(Ljava/lang/Object;Ljava/lang/Object;)Ljava/lang/Object; +21
j org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(Lorg/eclipse/core/commands/ParameterizedCommand;Lorg/ecli pse/swt/widgets/Event;)Ljava/lang/Object;+6
j org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(Lorg/eclipse/jface/bindings/Binding;Lorg/eclipse/swt/widge ts/Event;)Z+198
j org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Ljava/u til/List;Lorg/eclipse/swt/widgets/Event;)Z+300
j org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(Ljava/util/List;Lorg/eclipse/swt/widgets/Event;)V+14
j org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(Lorg/eclipse/swt/widgets/Event;)V+158
j org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Lorg /eclipse/ui/internal/keys/WorkbenchKeyboard;Lorg/eclipse/swt /widgets/Event;)V+2
j org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(Lorg/eclipse/swt/widgets/Event;)V+177
v ~C2IAdapter
J org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
v ~I2CAdapter
j org.eclipse.swt.widgets.Display.filterEvent(Lorg/eclipse/swt /widgets/Event;)Z+12
j org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/wi dgets/Event;)V+7
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;Z)V+73
j org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/w idgets/Event;)V+4
j org.eclipse.swt.widgets.Widget.sendKeyEvent(ILorg/eclipse/sw t/internal/gtk/GdkEventKey;)Z+62
j org.eclipse.swt.widgets.Widget.gtk_key_press_event(JJ)J+23
j org.eclipse.swt.widgets.Control.gtk_key_press_event(JJ)J+100
j org.eclipse.swt.widgets.Composite.gtk_key_press_event(JJ)J+3
j org.eclipse.swt.widgets.Widget.windowProc(JJJ)J+392
j org.eclipse.swt.widgets.Display.windowProc(JJJ)J+20
J org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(J)V
J org.eclipse.swt.widgets.Display.eventProc(JJ)J
v ~I2CAdapter
J org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(JZ )Z
J org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(JZ) Z
J org.eclipse.swt.widgets.Display.readAndDispatch()Z
J org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/ jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widge ts/Display;)V
v ~OSRAdapter
j org.eclipse.ui.internal.Workbench.runUI()I+226
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg /eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/Wor kbenchAdvisor;)I+11
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse /swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAd visor;)I+2
j org.eclipse.ui.internal.ide.IDEApplication.run(Ljava/lang/Ob ject;)Ljava/lang/Object;+98
j org.eclipse.core.internal.runtime.PlatformActivator$1.run(Lj ava/lang/Object;)Ljava/lang/Object;+219
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/la ng/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/l ang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+64
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Objec t;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/O bject;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lan g/Object;)Ljava/lang/Object;+111
j org.eclipse.core.launcher.Main.invokeFramework([Ljava/lang/S tring;[Ljava/net/URL;)V+181
j org.eclipse.core.launcher.Main.basicRun([Ljava/lang/String;) V+107
j org.eclipse.core.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.core.launcher.Main.main([Ljava/lang/String;)V+10
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00002aab1a124400 JavaThread "Worker-14" daemon [_thread_blocked, id=13033]
0x00002aab14d25890 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=13032]
0x00002aab19058510 JavaThread "Worker-13" daemon [_thread_blocked, id=13000]
0x00002aab086f78b0 JavaThread "Worker-6" daemon [_thread_blocked, id=12586]
0x00002aab085e25f0 JavaThread "Java indexing" daemon [_thread_blocked, id=12509]
0x00002aab085611c0 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=12499]
0x00002aab0803df20 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=12497]
0x00002aab07b027f0 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=12493]
0x00002aab07b00d10 JavaThread "CompilerThread1" daemon [_thread_in_native, id=12492]
0x00002aab07cb3310 JavaThread "CompilerThread0" daemon [_thread_blocked, id=12491]
0x00000000401c1e60 JavaThread "AdapterThread" daemon [_thread_blocked, id=12490]
0x00000000401c09d0 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=12489]
0x00000000401aef30 JavaThread "Finalizer" daemon [_thread_blocked, id=12488]
0x00000000401ac590 JavaThread "Reference Handler" daemon [_thread_blocked, id=12487]
=>0x0000000040115c10 JavaThread "main" [_thread_in_native, id=12485]
Other Threads:
0x00000000401a8180 VMThread [id=12486]
0x00002aab07b045c0 WatcherThread [id=12494]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 48192K, used 37625K [0x00002aaaef810000, 0x00002aaaf2c50000, 0x00002aaaf4d60000)
eden space 42880K, 87% used [0x00002aaaef810000, 0x00002aaaf1cce490, 0x00002aaaf21f0000)
from space 5312K, 0% used [0x00002aaaf2720000, 0x00002aaaf2720000, 0x00002aaaf2c50000)
to space 5312K, 0% used [0x00002aaaf21f0000, 0x00002aaaf21f0000, 0x00002aaaf2720000)
tenured generation total 106876K, used 42036K [0x00002aaaf4d60000, 0x00002aaafb5bf000, 0x00002aaaff810000)
the space 106876K, 39% used [0x00002aaaf4d60000, 0x00002aaaf766d1e8, 0x00002aaaf766d200, 0x00002aaafb5bf000)
compacting perm gen total 71680K, used 71568K [0x00002aaaff810000, 0x00002aab03e10000, 0x00002aab04a10000)
the space 71680K, 99% used [0x00002aaaff810000, 0x00002aab03df4048, 0x00002aab03df4200, 0x00002aab03e10000)
No shared spaces configured.
Dynamic libraries:
40000000-4000e000 r-xp 00000000 08:06 5369196 /usr/java/jdk1.5.0_06/bin/java
4010d000-40110000 rwxp 0000d000 08:06 5369196 /usr/java/jdk1.5.0_06/bin/java
40110000-401c3000 rwxp 40110000 00:00 0 [heap]
401c3000-401c4000 ---p 401c3000 00:00 0
401c4000-402c4000 rwxp 401c4000 00:00 0
402c4000-402c7000 ---p 402c4000 00:00 0
402c7000-403c5000 rwxp 402c7000 00:00 0
403c5000-403c8000 ---p 403c5000 00:00 0
403c8000-404c6000 rwxp 403c8000 00:00 0
404c6000-404c9000 ---p 404c6000 00:00 0
404c9000-405c7000 rwxp 404c9000 00:00 0
405c7000-405ca000 ---p 405c7000 00:00 0
405ca000-406c8000 rwxp 405ca000 00:00 0
406c8000-406cb000 ---p 406c8000 00:00 0
406cb000-407c9000 rwxp 406cb000 00:00 0
407c9000-407cc000 ---p 407c9000 00:00 0
407cc000-408ca000 rwxp 407cc000 00:00 0
408ca000-408cd000 ---p 408ca000 00:00 0
408cd000-409cb000 rwxp 408cd000 00:00 0
409cb000-409cc000 ---p 409cb000 00:00 0
409cc000-40acc000 rwxp 409cc000 00:00 0
40acc000-40acf000 rwxp 40acc000 00:00 0
40acf000-40bcd000 rwxp 40acf000 00:00 0
40bcd000-40bd0000 ---p 40bcd000 00:00 0
40bd0000-40cce000 rwxp 40bd0000 00:00 0
40cce000-40cd1000 rwxp 40cce000 00:00 0
40cd1000-40dcf000 rwxp 40cd1000 00:00 0
40dcf000-40dd2000 ---p 40dcf000 00:00 0
40dd2000-40ed0000 rwxp 40dd2000 00:00 0
40ed0000-40ed3000 rwxp 40ed0000 00:00 0
40ed3000-40fd1000 rwxp 40ed3000 00:00 0
40fd1000-40fd4000 ---p 40fd1000 00:00 0
40fd4000-410d2000 rwxp 40fd4000 00:00 0
410d2000-410d5000 ---p 410d2000 00:00 0
410d5000-411d3000 rwxp 410d5000 00:00 0
411d3000-411d6000 rwxp 411d3000 00:00 0
411d6000-412d4000 rwxp 411d6000 00:00 0
412d4000-412d7000 rwxp 412d4000 00:00 0
412d7000-413d5000 rwxp 412d7000 00:00 0
413d5000-413d8000 rwxp 413d5000 00:00 0
413d8000-414d6000 rwxp 413d8000 00:00 0
414d6000-414d9000 rwxp 414d6000 00:00 0
414d9000-415d7000 rwxp 414d9000 00:00 0
415d7000-415da000 rwxp 415d7000 00:00 0
415da000-416d8000 rwxp 415da000 00:00 0
416d8000-416db000 ---p 416d8000 00:00 0
416db000-417d9000 rwxp 416db000 00:00 0
417d9000-417dc000 rwxp 417d9000 00:00 0
417dc000-418da000 rwxp 417dc000 00:00 0
418da000-418dd000 rwxp 418da000 00:00 0
418dd000-419db000 rwxp 418dd000 00:00 0
419db000-419de000 rwxp 419db000 00:00 0
419de000-41adc000 rwxp 419de000 00:00 0
41adc000-41adf000 ---p 41adc000 00:00 0
41adf000-41bdd000 rwxp 41adf000 00:00 0
41bdd000-41be0000 rwxp 41bdd000 00:00 0
41be0000-41cde000 rwxp 41be0000 00:00 0
41cde000-41ce1000 rwxp 41cde000 00:00 0
41ce1000-41ddf000 rwxp 41ce1000 00:00 0
41ddf000-41de2000 rwxp 41ddf000 00:00 0
41de2000-41ee0000 rwxp 41de2000 00:00 0
41ee0000-41ee3000 rwxp 41ee0000 00:00 0
41ee3000-41fe1000 rwxp 41ee3000 00:00 0
41fe1000-41fe4000 rwxp 41fe1000 00:00 0
41fe4000-420e2000 rwxp 41fe4000 00:00 0
420e2000-420e5000 rwxp 420e2000 00:00 0
420e5000-421e3000 rwxp 420e5000 00:00 0
421e3000-421e6000 rwxp 421e3000 00:00 0
421e6000-422e4000 rwxp 421e6000 00:00 0
422e4000-422e7000 ---p 422e4000 00:00 0
422e7000-423e5000 rwxp 422e7000 00:00 0
423e5000-423e8000 rwxp 423e5000 00:00 0
423e8000-424e6000 rwxp 423e8000 00:00 0
32bec00000-32bec14000 r-xp 00000000 08:06 4688142 /usr/lib64/libz.so.1.2.2.2
32bec14000-32bed13000 ---p 00014000 08:06 4688142 /usr/lib64/libz.so.1.2.2.2
32bed13000-32bed14000 rwxp 00013000 08:06 4688142 /usr/lib64/libz.so.1.2.2.2
32bee00000-32bee7f000 r-xp 00000000 08:06 4695638 /usr/lib64/libfreetype.so.6.3.7
32bee7f000-32bef7f000 ---p 0007f000 08:06 4695638 /usr/lib64/libfreetype.so.6.3.7
32bef7f000-32bef8c000 rwxp 0007f000 08:06 4695638 /usr/lib64/libfreetype.so.6.3.7
32bf000000-32bf112000 r-xp 00000000 08:06 4695646 /usr/lib64/libxml2.so.2.6.20
32bf112000-32bf211000 ---p 00112000 08:06 4695646 /usr/lib64/libxml2.so.2.6.20
32bf211000-32bf21e000 rwxp 00111000 08:06 4695646 /usr/lib64/libxml2.so.2.6.20
32bf21e000-32bf21f000 rwxp 32bf21e000 00:00 0
32bf300000-32bf314000 r-xp 00000000 08:06 4695640 /usr/X11R6/lib64/libXft.so.2.1.2
32bf314000-32bf413000 ---p 00014000 08:06 4695640 /usr/X11R6/lib64/libXft.so.2.1.2
32bf413000-32bf414000 rwxp 00013000 08:06 4695640 /usr/X11R6/lib64/libXft.so.2.1.2
32bf500000-32bf507000 r-xp 00000000 08:06 4695642 /usr/lib64/libpangoxft-1.0.so.0.800.1
32bf507000-32bf606000 ---p 00007000 08:06 4695642 /usr/lib64/libpangoxft-1.0.so.0.800.1
32bf606000-32bf607000 rwxp 00006000 08:06 4695642 /usr/lib64/libpangoxft-1.0.so.0.800.1
32bf700000-32bf760000 r-xp 00000000 08:06 4695649 /usr/lib64/libbonoboui-2.so.0.0.0
32bf760000-32bf860000 ---p 00060000 08:06 4695649 /usr/lib64/libbonoboui-2.so.0.0.0
32bf860000-32bf869000 rwxp 00060000 08:06 4695649 /usr/lib64/libbonoboui-2.so.0.0.0
32bf900000-32bf914000 r-xp 00000000 08:06 4695648 /usr/lib64/libgnome-2.so.0.1000.0
32bf914000-32bfa14000 ---p 00014000 08:06 4695648 /usr/lib64/libgnome-2.so.0.1000.0
32bfa14000-32bfa16000 rwxp 00014000 08:06 4695648 /usr/lib64/libgnome-2.so.0.1000.0
32bfb00000-32bfb28000 r-xp 00000000 08:06 4695641 /usr/lib64/libpangoft2-1.0.so.0.800.1
32bfb28000-32bfc28000 ---p 00028000 08:06 4695641 /usr/lib64/libpangoft2-1.0.so.0.800.1
32bfc28000-32bfc2a000 rwxp 00028000 08:06 4695641 /usr/lib64/libpangoft2-1.0.so.0.800.1
32bfd00000-32bfd35000 r-xp 00000000 08:06 11621297 /lib64/libssl.so.0.9.7f
32bfd35000-32bfe35000 ---p 00035000 08:06 11621297 /lib64/libssl.so.0.9.7f
32bfe35000-32bfe3a000 rwxp 00035000 08:06 11621297 /lib64/libssl.so.0.9.7f
32bfe3a000-32bfe3b000 rwxp 32bfe3a000 00:00 0
32bff00000-32c000a000 r-xp 00000000 08:06 11621296 /lib64/libcrypto.so.0.9.7f
32c000a000-32c010a000 ---p 0010a000 08:06 11621296 /lib64/libcrypto.so.0.9.7f
32c010a000-32c0128000 rwxp 0010a000 08:06 11621296 /lib64/libcrypto.so.0.9.7f
32c0128000-32c012c000 rwxp 32c0128000 00:00 0
32c0200000-32c022c000 r-xp 00000000 08:06 4695639 /usr/lib64/libfontconfig.so.1.0.4
32c022c000-32c032c000 ---p 0002c000 08:06 4695639 /usr/lib64/libfontconfig.so.1.0.4
32c032c000-32c0331000 rwxp 0002c000 08:06 4695639 /usr/lib64/libfontconfig.so.1.0.4
32c0331000-32c0333000 rwxp 32c0331000 00:00 0
32c0400000-32c042c000 r-xp 00000000 08:06 4695645 /usr/lib64/libgnomecanvas-2.so.0.1000.0
32c042c000-32c052b000 ---p 0002c000 08:06 4695645 /usr/lib64/libgnomecanvas-2.so.0.1000.0
32c052b000-32c052e000 rwxp 0002b000 08:06 4695645 /usr/lib64/libgnomecanvas-2.so.0.1000.0
32c0800000-32c0863000 r-xp 00000000 08:06 4695647 /usr/lib64/libgnomevfs-2.so.0.1000.0
32c0863000-32c0962000 ---p 00063000 08:06 4695647 /usr/lib64/libgnomevfs-2.so.0.1000.0
32c0962000-32c096e000 rwxp 00062000 08:06 4695647 /usr/lib64/libgnomevfs-2.so.0.1000.0
32c0a00000-32c0cae000 r-xp 00000000 08:06 4695644 /usr/lib64/libgtk-x11-2.0.so.0.600.10
32c0cae000-32c0dae000 ---p 002ae000 08:06 4695644 /usr/lib64/libgtk-x11-2.0.so.0.600.10
32c0dae000-32c0dde000 rwxp 002ae000 08:06 4695644 /usr/lib64/libgtk-x11-2.0.so.0.600.10
32c0dde000-32c0de2000 rwxp 32c0dde000 00:00 0
32c0e00000-32c0e89000 r-xp 00000000 08:06 4694695 /usr/lib64/libgnomeui-2.so.0.1000.0
32c0e89000-32c0f88000 ---p 00089000 08:06 4694695 /usr/lib64/libgnomeui-2.so.0.1000.0
32c0f88000-32c0f93000 rwxp 00088000 08:06 4694695 /usr/lib64/libgnomeui-2.so.0.1000.0
32c1000000-32c1080000 r-xp 00000000 08:06 4695643 /usr/lib64/libgdk-x11-2.0.so.0.600.10
32c1080000-32c117f000 ---p 00080000 08:06 4695643 /usr/lib64/libgdk-x11-2.0.so.0.600.10
32c117f000-32c1189000 rwxp 0007f000 08:06 4695643 /usr/lib64/libgdk-x11-2.0.so.0.600.10
34e3000000-34e301a000 r-xp 00000000 08:06 11621339 /lib64/ld-2.3.5.so
34e3119000-34e311a000 r-xp 00019000 08:06 11621339 /lib64/ld-2.3.5.so
34e311a000-34e311b000 rwxp 0001a000 08:06 11621339 /lib64/ld-2.3.5.so
34e3200000-34e332d000 r-xp 00000000 08:06 11621509 /lib64/libc-2.3.5.so
34e332d000-34e342c000 ---p 0012d000 08:06 11621509 /lib64/libc-2.3.5.so
34e342c000-34e3430000 r-xp 0012c000 08:06 11621509 /lib64/libc-2.3.5.so
34e3430000-34e3432000 rwxp 00130000 08:06 11621509 /lib64/libc-2.3.5.so
34e3432000-34e3436000 rwxp 34e3432000 00:00 0
34e3500000-34e3584000 r-xp 00000000 08:06 11621516 /lib64/libm-2.3.5.so
34e3584000-34e3684000 ---p 00084000 08:06 11621516 /lib64/libm-2.3.5.so
34e3684000-34e3685000 r-xp 00084000 08:06 11621516 /lib64/libm-2.3.5.so
34e3685000-34e3686000 rwxp 00085000 08:06 11621516 /lib64/libm-2.3.5.so
34e3700000-34e3702000 r-xp 00000000 08:06 11621520 /lib64/libdl-2.3.5.so
34e3702000-34e3802000 ---p 00002000 08:06 11621520 /lib64/libdl-2.3.5.so
34e3802000-34e3803000 r-xp 00002000 08:06 11621520 /lib64/libdl-2.3.5.so
34e3803000-34e3804000 rwxp 00003000 08:06 11621520 /lib64/libdl-2.3.5.so
34e3b00000-34e3bda000 r-xp 00000000 08:06 4682443 /usr/X11R6/lib64/libX11.so.6.2
34e3bda000-34e3cd9000 ---p 000da000 08:06 4682443 /usr/X11R6/lib64/libX11.so.6.2
34e3cd9000-34e3cdf000 rwxp 000d9000 08:06 4682443 /usr/X11R6/lib64/libX11.so.6.2
34e3d00000-34e3d10000 r-xp 00000000 08:06 4682498 /usr/X11R6/lib64/libXext.so.6.4
34e3d10000-34e3e10000 ---p 00010000 08:06 4682498 /usr/X11R6/lib64/libXext.so.6.4
34e3e10000-34e3e11000 rwxp 00010000 08:06 4682498 /usr/X11R6/lib64/libXext.so.6.4
34e3f00000-34e3f21000 r-xp 00000000 08:06 4682501 /usr/lib64/libexpat.so.0.5.0
34e3f21000-34e4020000 ---p 00021000 08:06 4682501 /usr/lib64/libexpat.so.0.5.0
34e4020000-34e4023000 rwxp 00020000 08:06 4682501 /usr/lib64/libexpat.so.0.5.0
34e4300000-34e430f000 r-xp 00000000 08:06 11621521 /lib64/libpthread-2.3.5.so
34e430f000-34e440f000 ---p 0000f000 08:06 11621521 /lib64/libpthread-2.3.5.so
34e440f000-34e4410000 r-xp 0000f000 08:06 11621521 /lib64/libpthread-2.3.5.so
34e4410000-34e4411000 rwxp 00010000 08:06 11621521 /lib64/libpthread-2.3.5.so
34e4411000-34e4415000 rwxp 34e4411000 00:00 0
34e4900000-34e4908000 r-xp 00000000 08:06 4682499 /usr/X11R6/lib64/libXrender.so.1.2.2
34e4908000-34e4a08000 ---p 00008000 08:06 4682499 /usr/X11R6/lib64/libXrender.so.1.2.2
34e4a08000-34e4a09000 rwxp 00008000 08:06 4682499 /usr/X11R6/lib64/libXrender.so.1.2.2
34e4b00000-34e4b02000 r-xp 00000000 08:06 4682685 /usr/X11R6/lib64/libXinerama.so.1.0
34e4b02000-34e4c01000 ---p 00002000 08:06 4682685 /usr/X11R6/lib64/libXinerama.so.1.0
34e4c01000-34e4c02000 rwxp 00001000 08:06 4682685 /usr/X11R6/lib64/libXinerama.so.1.0
34e4d00000-34e4d03000 r-xp 00000000 08:06 4682681 /usr/X11R6/lib64/libXrandr.so.2.0
34e4d03000-34e4e02000 ---p 00003000 08:06 4682681 /usr/X11R6/lib64/libXrandr.so.2.0
34e4e02000-34e4e03000 rwxp 00002000 08:06 4682681 /usr/X11R6/lib64/libXrandr.so.2.0
34e4f00000-34e4f09000 r-xp 00000000 08:06 4682694 /usr/X11R6/lib64/libXcursor.so.1.0.2
34e4f09000-34e5009000 ---p 00009000 08:06 4682694 /usr/X11R6/lib64/libXcursor.so.1.0.2
34e5009000-34e500a000 rwxp 00009000 08:06 4682694 /usr/X11R6/lib64/libXcursor.so.1.0.2
34e5100000-34e5111000 r-xp 00000000 08:06 11621355 /lib64/libresolv-2.3.5.so
34e5111000-34e5211000 ---p 00011000 08:06 11621355 /lib64/libresolv-2.3.5.so
34e5211000-34e5212000 r-xp 00011000 08:06 11621355 /lib64/libresolv-2.3.5.so
34e5212000-34e5213000 rwxp 00012000 08:06 11621355 /lib64/libresolv-2.3.5.so
34e5213000-34e5215000 rwxp 34e5213000 00:00 0
34e5300000-34e5317000 r-xp 00000000 08:06 4685816 /usr/X11R6/lib64/libICE.so.6.3
34e5317000-34e5416000 ---p 00017000 08:06 4685816 /usr/X11R6/lib64/libICE.so.6.3
34e5416000-34e5418000 rwxp 00016000 08:06 4685816 /usr/X11R6/lib64/libICE.so.6.3
34e5418000-34e541b000 rwxp 34e5418000 00:00 0
34e5500000-34e550a000 r-xp 00000000 08:06 4685824 /usr/X11R6/lib64/libSM.so.6.0
34e550a000-34e5609000 ---p 0000a000 08:06 4685824 /usr/X11R6/lib64/libSM.so.6.0
34e5609000-34e560a000 rwxp 00009000 08:06 4685824 /usr/X11R6/lib64/libSM.so.6.0
34e5700000-34e5784000 r-xp 00000000 08:06 4681406 /usr/lib64/libglib-2.0.so.0.600.6
34e5784000-34e5883000 ---p 00084000 08:06 4681406 /usr/lib64/libglib-2.0.so.0.600.6
34e5883000-34e5889000 rwxp 00083000 08:06 4681406 /usr/lib64/libglib-2.0.so.0.600.6
34e5889000-34e588a000 rwxp 34e5889000 00:00 0
34e5b00000-34e5b21000 r-xp 00000000 08:06 4686002 /usr/lib64/libjpeg.so.62.0.0
34e5b21000-34e5c21000 ---p 00021000 08:06 4686002 /usr/lib64/libjpeg.so.62.0.0
34e5c21000-34e5c22000 rwxp 00021000 08:06 4686002 /usr/lib64/libjpeg.so.62.0.0
34e5f00000-34e5f37000 r-xp 00000000 08:06 4681407 /usr/lib64/libgobject-2.0.so.0.600.6
34e5f37000-34e6037000 ---p 00037000 08:06 4681407 /usr/lib64/libgobject-2.0.so.0.600.6
34e6037000-34e603c000 rwxp 00037000 08:06 4681407 /usr/lib64/libgobject-2.0.so.0.600.6
34e6100000-34e6103000 r-xp 00000000 08:06 4681748 /usr/lib64/libgmodule-2.0.so.0.600.6
34e6103000-34e6202000 ---p 00003000 08:06 4681748 /usr/lib64/libgmodule-2.0.so.0.600.6
34e6202000-34e6203000 rwxp 00002000 08:06 4681748 /usr/lib64/libgmodule-2.0.so.0.600.6
34e6300000-34e6317000 r-xp 00000000 08:06 4682615 /usr/lib64/libart_lgpl_2.so.2.3.17
34e6317000-34e6416000 ---p 00017000 08:06 4682615 /usr/lib64/libart_lgpl_2.so.2.3.17
34e6416000-34e6417000 rwxp 00016000 08:06 4682615 /usr/lib64/libart_lgpl_2.so.2.3.17
34e6500000-34e653b000 r-xp 00000000 08:06 4682619 /usr/lib64/libpango-1.0.so.0.800.1
34e653b000-34e663b000 ---p 0003b000 08:06 4682619 /usr/lib64/libpango-1.0.so.0.800.1
34e663b000-34e6644000 rwxp 0003b000 08:06 4682619 /usr/lib64/libpango-1.0.so.0.800.1
34e6b00000-34e6b14000 r-xp 00000000 08:06 4682680 /usr/lib64/libgdk_pixbuf-2.0.so.0.600.10
34e6b14000-34e6c14000 ---p 00014000 08:06 4682680 /usr/lib64/libgdk_pixbuf-2.0.so.0.600.10
34e6c14000-34e6c16000 rwxp 00014000 08:06 4682680 /usr/lib64/libgdk_pixbuf-2.0.so.0.600.10
34e6d00000-34e6d0b000 r-xp 00000000 08:06 4682699 /usr/lib64/libpangox-1.0.so.0.800.1
34e6d0b000-34e6e0b000 ---p 0000b000 08:06 4682699 /usr/lib64/libpangox-1.0.so.0.800.1
34e6e0b000-34e6e0c000 rwxp 0000b000 08:06 4682699 /usr/lib64/libpangox-1.0.so.0.800.1
34e6f00000-34e6f05000 r-xp 00000000 08:06 4682689 /usr/X11R6/lib64/libXfixes.so.3.0
34e6f05000-34e7004000 ---p 00005000 08:06 4682689 /usr/X11R6/lib64/libXfixes.so.3.0
34e7004000-34e7005000 rwxp 00004000 08:06 4682689 /usr/X11R6/lib64/libXfixes.so.3.0
34e7500000-34e751a000 r-xp 00000000 08:06 4682706 /usr/lib64/libatk-1.0.so.0.901.0
34e751a000-34e7619000 ---p 0001a000 08:06 4682706 /usr/lib64/libatk-1.0.so.0.901.0
34e7619000-34e761e000 rwxp 00019000 08:06 4682706 /usr/lib64/libatk-1.0.so.0.901.0
34e7700000-34e7708000 r-xp 00000000 08:06 4682683 /usr/X11R6/lib64/libXi.so.6.0
34e7708000-34e7807000 ---p 00008000 08:06 4682683 /usr/X11R6/lib64/libXi.so.6.0
34e7807000-34e7808000 rwxp 00007000 08:06 4682683 /usr/X11R6/lib64/libXi.so.6.0
34e7d00000-34e7d07000 r-xp 00000000 08:06 4682091 /usr/lib64/libpopt.so.0.0.0
34e7d07000-34e7e07000 ---p 00007000 08:06 4682091 /usr/lib64/libpopt.so.0.0.0
34e7e07000-34e7e08000 rwxp 00007000 08:06 4682091 /usr/lib64/libpopt.so.0.0.0
34e7f00000-34e7f09000 r-xp 00000000 08:06 11621527 /lib64/librt-2.3.5.so
34e7f09000-34e8008000 ---p 00009000 08:06 11621527 /lib64/librt-2.3.5.so
34e8008000-34e8009000 r-xp 00008000 08:06 11621527 /lib64/librt-2.3.5.so
34e8009000-34e800a000 rwxp 00009000 08:06 11621527 /lib64/librt-2.3.5.so
34e800a000-34e801a000 rwxp 34e800a000 00:00 0
34e8100000-34e8102000 r-xp 00000000 08:06 11621557 /lib64/libcom_err.so.2.1
34e8102000-34e8201000 ---p 00002000 08:06 11621557 /lib64/libcom_err.so.2.1
34e8201000-34e8202000 rwxp 00001000 08:06 11621557 /lib64/libcom_err.so.2.1
34e8500000-34e8570000 r-xp 00000000 08:06 4682534 /usr/lib64/libkrb5.so.3.2
34e8570000-34e866f000 ---p 00070000 08:06 4682534 /usr/lib64/libkrb5.so.3.2
34e866f000-34e8674000 rwxp 0006f000 08:06 4682534 /usr/lib64/libkrb5.so.3.2
34e8700000-34e8722000 r-xp 00000000 08:06 4682530 /usr/lib64/libk5crypto.so.3.0
34e8722000-34e8821000 ---p 00022000 08:06 4682530 /usr/lib64/libk5crypto.so.3.0
34e8821000-34e8823000 rwxp 00021000 08:06 4682530 /usr/lib64/libk5crypto.so.3.0
34e8900000-34e8902000 r-xp 00000000 08:06 4682528 /usr/lib64/libkrb5support.so.0.0
34e8902000-34e8a02000 ---p 00002000 08:06 4682528 /usr/lib64/libkrb5support.so.0.0
34e8a02000-34e8a03000 rwxp 00002000 08:06 4682528 /usr/lib64/libkrb5support.so.0.0
34e9000000-34e9016000 r-xp 00000000 08:06 4682589 /usr/lib64/libgssapi_krb5.so.2.2
34e9016000-34e9115000 ---p 00016000 08:06 4682589 /usr/lib64/libgssapi_krb5.so.2.2
34e9115000-34e9117000 rwxp 00015000 08:06 4682589 /usr/lib64/libgssapi_krb5.so.2.2
34e9200000-34e9204000 r-xp 00000000 08:06 4681408 /usr/lib64/libgthread-2.0.so.0.600.6
34e9204000-34e9303000 ---p 00004000 08:06 4681408 /usr/lib64/libgthread-2.0.so.0.600.6
34e9303000-34e9304000 rwxp 00003000 08:06 4681408 /usr/lib64/libgthread-2.0.so.0.600.6
34e9400000-34e940b000 r-xp 00000000 08:06 4685997 /usr/lib64/libgnome-keyring.so.0.0.1
34e940b000-34e950a000 ---p 0000b000 08:06 4685997 /usr/lib64/libgnome-keyring.so.0.0.1
34e950a000-34e950b000 rwxp 0000a000 08:06 4685997 /usr/lib64/libgnome-keyring.so.0.0.1
34e9800000-34e9856000 r-xp 00000000 08:06 4684323 /usr/lib64/libORBit-2.so.0.0.0
34e9856000-34e9956000 ---p 00056000 08:06 4684323 /usr/lib64/libORBit-2.so.0.0.0
34e9956000-34e9969000 rwxp 00056000 08:06 4684323 /usr/lib64/libORBit-2.so.0.0.0
34e9e00000-34e9e05000 r-xp 00000000 08:06 4685087 /usr/lib64/libORBitCosNaming-2.so.0.0.0
34e9e05000-34e9f04000 ---p 00005000 08:06 4685087 /usr/lib64/libORBitCosNaming-2.so.0.0.0
34e9f04000-34e9f06000 rwxp 00004000 08:06 4685087 /usr/lib64/libORBitCosNaming-2.so.0.0.0
34ea000000-34ea034000 r-xp 00000000 08:06 4684340 /usr/lib64/libgconf-2.so.4.1.0
34ea034000-34ea133000 ---p 00034000 08:06 4684340 /usr/lib64/libgconf-2.so.4.1.0
34ea133000-34ea13a000 rwxp 00033000 08:06 4684340 /usr/lib64/libgconf-2.so.4.1.0
34ea500000-34ea5c7000 r-xp 00000000 08:06 11621561 /lib64/libasound.so.2.0.0
34ea5c7000-34ea6c6000 ---p 000c7000 08:06 11621561 /lib64/libasound.so.2.0.0
34ea6c6000-34ea6ce000 rwxp 000c6000 08:06 11621561 /lib64/libasound.so.2.0.0
34ea700000-34ea716000 r-xp 00000000 08:06 4685104 /usr/lib64/libbonobo-activation.so.4.0.0
34ea716000-34ea816000 ---p 00016000 08:06 4685104 /usr/lib64/libbonobo-activation.so.4.0.0
34ea816000-34ea81a000 rwxp 00016000 08:06 4685104 /usr/lib64/libbonobo-activation.so.4.0.0
34ea900000-34ea909000 r-xp 00000000 08:06 4685812 /usr/lib64/libesd.so.0.2.36
34ea909000-34eaa09000 ---p 00009000 08:06 4685812 /usr/lib64/libesd.so.0.2.36
34eaa09000-34eaa0a000 rwxp 00009000 08:06 4685812 /usr/lib64/libesd.so.0.2.36
34eab00000-34eab27000 r-xp 00000000 08:06 4685607 /usr/lib64/libaudiofile.so.0.0.2
34eab27000-34eac27000 ---p 00027000 08:06 4685607 /usr/lib64/libaudiofile.so.0.0.2
34eac27000-34eac2b000 rwxp 00027000 08:06 4685607 /usr/lib64/libaudiofile.so.0.0.2
34eaf00000-34eaf1a000 r-xp 00000000 08:06 4685560 /usr/lib64/libhowl.so.0.0.0
34eaf1a000-34eb019000 ---p 0001a000 08:06 4685560 /usr/lib64/libhowl.so.0.0.0
34eb019000-34eb01b000 rwxp 00019000 08:06 4685560 /usr/lib64/libhowl.so.0.0.0
34eb01b000-34eb13a000 rwxp 34eb01b000 00:00 0
34eb200000-34eb262000 r-xp 00000000 08:06 4685163 /usr/lib64/libbonobo-2.so.0.0.0
34eb262000-34eb361000 ---p 00062000 08:06 4685163 /usr/lib64/libbonobo-2.so.0.0.0
34eb361000-34eb372000 rwxp 00061000 08:06 4685163 /usr/lib64/libbonobo-2.so.0.0.0
34eba00000-34eba14000 r-xp 00000000 08:06 11621360 /lib64/libnsl-2.3.5.so
34eba14000-34ebb13000 ---p 00014000 08:06 11621360 /lib64/libnsl-2.3.5.so
34ebb13000-34ebb14000 r-xp 00013000 08:06 11621360 /lib64/libnsl-2.3.5.so
34ebb14000-34ebb15000 rwxp 00014000 08:06 11621360 /lib64/libnsl-2.3.5.so
34ebb15000-34ebb17000 rwxp 34ebb15000 00:00 0
34ec000000-34ec005000 r-xp 00000000 08:06 4688560 /usr/X11R6/lib64/libXtst.so.6.1
34ec005000-34ec105000 ---p 00005000 08:06 4688560 /usr/X11R6/lib64/libXtst.so.6.1
34ec105000-34ec106000 rwxp 00005000 08:06 4688560 /usr/X11R6/lib64/libXtst.so.6.1
386bb00000-386bb26000 r-xp 00000000 08:06 4687806 /usr/lib64/libpng12.so.0.1.2.8
386bb26000-386bc26000 ---p 00026000 08:06 4687806 /usr/lib64/libpng12.so.0.1.2.8
386bc26000-386bc27000 rwxp 00026000 08:06 4687806 /usr/lib64/libpng12.so.0.1.2.8
2aaaaaaab000-2aaaaaaac000 rwxp 2aaaaaaab000 00:00 0
2aaaaaaac000-2aaaaaab5000 r-xs 00000000 08:06 2063058 /home.local/momin/eclipse-3.2.0.m5/startup.jar
2aaaaaab5000-2aaaaaac6000 r-xs 00000000 08:06 2062644 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.equin ox.common_1.0.0.v20060215a.jar
2aaaaaac6000-2aaaaaac8000 r-xs 00000000 08:06 2062383 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.core. runtime.compatibility.registry_3.2.0.v20060215a/runtime_regi stry_compatibility.jar
2aaaaaad4000-2aaaaaad7000 rwxp 2aaaaaad4000 00:00 0
2aaaaaad7000-2aaaab195000 r-xp 00000000 08:06 5370605 /usr/java/jdk1.5.0_06/jre/lib/amd64/server/libjvm.so
2aaaab195000-2aaaab297000 ---p 006be000 08:06 5370605 /usr/java/jdk1.5.0_06/jre/lib/amd64/server/libjvm.so
2aaaab297000-2aaaab410000 rwxp 006c0000 08:06 5370605 /usr/java/jdk1.5.0_06/jre/lib/amd64/server/libjvm.so
2aaaab410000-2aaaab43f000 rwxp 2aaaab410000 00:00 0
2aaaab43f000-2aaaab440000 r-xp 2aaaab43f000 00:00 0
2aaaab440000-2aaaab441000 rwxp 2aaaab440000 00:00 0
2aaaab441000-2aaaab44a000 r-xp 00000000 08:06 5370601 /usr/java/jdk1.5.0_06/jre/lib/amd64/native_threads/libhpi.so
2aaaab44a000-2aaaab549000 ---p 00009000 08:06 5370601 /usr/java/jdk1.5.0_06/jre/lib/amd64/native_threads/libhpi.so
2aaaab549000-2aaaab54d000 rwxp 00008000 08:06 5370601 /usr/java/jdk1.5.0_06/jre/lib/amd64/native_threads/libhpi.so
2aaaab54d000-2aaaab582000 r-xs 00000000 08:06 328029 /var/db/nscd/passwd
2aaaab582000-2aaaab58a000 rwxs 00000000 08:06 3633751 /tmp/hsperfdata_momin/12485
2aaaab58a000-2aaaab597000 r-xp 00000000 08:06 5370596 /usr/java/jdk1.5.0_06/jre/lib/amd64/libverify.so
2aaaab597000-2aaaab696000 ---p 0000d000 08:06 5370596 /usr/java/jdk1.5.0_06/jre/lib/amd64/libverify.so
2aaaab696000-2aaaab699000 rwxp 0000c000 08:06 5370596 /usr/java/jdk1.5.0_06/jre/lib/amd64/libverify.so
2aaaab699000-2aaaab6be000 r-xp 00000000 08:06 5370580 /usr/java/jdk1.5.0_06/jre/lib/amd64/libjava.so
2aaaab6be000-2aaaab7bd000 ---p 00025000 08:06 5370580 /usr/java/jdk1.5.0_06/jre/lib/amd64/libjava.so
2aaaab7bd000-2aaaab7c3000 rwxp 00024000 08:06 5370580 /usr/java/jdk1.5.0_06/jre/lib/amd64/libjava.so
2aaaab7c3000-2aaaab7d9000 r-xp 00000000 08:06 5370597 /usr/java/jdk1.5.0_06/jre/lib/amd64/libzip.so
2aaaab7d9000-2aaaab8db000 ---p 00016000 08:06 5370597 /usr/java/jdk1.5.0_06/jre/lib/amd64/libzip.so
2aaaab8db000-2aaaab8de000 rwxp 00018000 08:06 5370597 /usr/java/jdk1.5.0_06/jre/lib/amd64/libzip.so
2aaaab8de000-2aaaadec6000 r-xs 00000000 08:06 5370642 /usr/java/jdk1.5.0_06/jre/lib/rt.jar
2aaaadec6000-2aaaadf2f000 rwxp 2aaaadec6000 00:00 0
2aaaadf2f000-2aaaadfb4000 r-xs 00000000 08:06 5370639 /usr/java/jdk1.5.0_06/jre/lib/jsse.jar
2aaaadfb4000-2aaaadfc8000 r-xs 00000000 08:06 5370632 /usr/java/jdk1.5.0_06/jre/lib/jce.jar
2aaaadfc8000-2aaaae803000 r-xs 00000000 08:06 5370633 /usr/java/jdk1.5.0_06/jre/lib/charsets.jar
2aaaae803000-2aaaaf243000 rwxp 2aaaae803000 00:00 0
2aaaaf243000-2aaaee803000 rwxp 2aaaaf243000 00:00 0
2aaaee803000-2aaaee82c000 rwxp 2aaaee803000 00:00 0
2aaaee82c000-2aaaef803000 rwxp 2aaaee82c000 00:00 0
2aaaef803000-2aaaef804000 r-xp 2aaaef803000 00:00 0
2aaaef804000-2aaaef805000 r-xs 00000000 08:06 5338181 /usr/share/icons/Clearlooks/icon-theme.cache
2aaaef805000-2aaaef806000 r-xs 00000000 08:06 5338181 /usr/share/icons/Clearlooks/icon-theme.cache
2aaaef810000-2aaaf2c50000 rwxp 2aaaef810000 00:00 0
2aaaf2c50000-2aaaf4d60000 rwxp 2aaaf2c50000 00:00 0
2aaaf4d60000-2aaafb5bf000 rwxp 2aaaf4d60000 00:00 0
2aaafb5bf000-2aaaff810000 rwxp 2aaafb5bf000 00:00 0
2aaaff810000-2aab03e10000 rwxp 2aaaff810000 00:00 0
2aab03e10000-2aab04a10000 rwxp 2aab03e10000 00:00 0
2aab04a10000-2aab04a2b000 rwxp 2aab04a10000 00:00 0
2aab04a2b000-2aab04a3a000 rwxp 2aab04a2b000 00:00 0
2aab04a3a000-2aab04a6f000 rwxp 2aab04a3a000 00:00 0
2aab04a6f000-2aab04a90000 rwxp 2aab04a6f000 00:00 0
2aab04a90000-2aab04ab3000 rwxp 2aab04a90000 00:00 0
2aab04ab3000-2aab04ab9000 rwxp 2aab04ab3000 00:00 0
2aab04ab9000-2aab04aef000 rwxp 2aab04ab9000 00:00 0
2aab04aef000-2aab04b10000 rwxp 2aab04aef000 00:00 0
2aab04b10000-2aab04b34000 rwxp 2aab04b10000 00:00 0
2aab04b34000-2aab04b3a000 rwxp 2aab04b34000 00:00 0
2aab04b3a000-2aab04b62000 rwxp 2aab04b3a000 00:00 0
2aab04b62000-2aab07ab3000 r-xp 00000000 08:06 4700080 /usr/lib/locale/locale-archive
2aab07ab3000-2aab07ad9000 r-xs 00000000 08:06 5435517 /usr/java/jdk1.5.0_06/jre/lib/ext/sunjce_provider.jar
2aab07ad9000-2aab07adb000 r-xs 00000000 08:06 5435515 /usr/java/jdk1.5.0_06/jre/lib/ext/dnsns.jar
2aab07adb000-2aab07aee000 r-xs 00000000 08:06 2063027 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.core. jobs_3.2.0.v20060206.jar
2aab07aee000-2aab07afe000 r-xs 00000000 08:06 2095677 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.team. cvs.ssh2_3.2.0.I200602161600/cvsssh2.jar
2aab07afe000-2aab07b00000 r-xs 00000000 08:06 2062528 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-antlr.jar
2aab07b00000-2aab07bff000 rwxp 2aab07b00000 00:00 0
2aab07bff000-2aab07c00000 ---p 2aab07bff000 00:00 0
2aab07c00000-2aab07c23000 r-xs 00000000 08:06 2063048 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.equin ox.registry_3.2.0.v20060217.jar
2aab07c23000-2aab07c39000 r-xs 00000000 08:06 2062510 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.equin ox.preferences_1.0.0.v20060215a.jar
2aab07c39000-2aab07c4c000 r-xs 00000000 08:06 2063037 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.core. contenttype_3.2.0.v20060215a.jar
2aab07c4c000-2aab07c66000 r-xs 00000000 08:06 2063024 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.core. runtime_3.2.0.v20060216.jar
2aab07c66000-2aab07c7d000 r-xs 00000000 08:06 2062512 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.updat e.configurator_3.1.100.v20051214.jar
2aab07c7d000-2aab07c97000 r-xs 00000000 08:06 5180944 /usr/share/icons/Bluecurve/icon-theme.cache
2aab07c97000-2aab07c9c000 r-xs 00000000 08:06 5175240 /usr/share/icons/gnome/icon-theme.cache
2aab07c9c000-2aab07cae000 r-xs 00000000 08:06 4976810 /usr/share/icons/hicolor/icon-theme.cache
2aab07cae000-2aab07cb1000 r-xs 00000000 08:06 2062545 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-apache-bcel.jar
2aab07cb3000-2aab07db3000 rwxp 2aab07cb3000 00:00 0
2aab07db3000-2aab07e77000 r-xs 00000000 08:06 5435999 /usr/java/jdk1.5.0_06/jre/lib/ext/localedata.jar
2aab07e77000-2aab07e80000 r-xs 00000000 08:06 2063058 /home.local/momin/eclipse-3.2.0.m5/startup.jar
2aab07e80000-2aab08280000 rwxp 2aab07e80000 00:00 0
2aab08280000-2aab08344000 r-xs 00000000 08:06 2062655 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.osgi_ 3.2.0.v20060214.jar
2aab08344000-2aab08444000 rwxp 2aab08344000 00:00 0
2aab08444000-2aab084b9000 r-xs 00000000 08:06 1702302 /home.local/momin/eclipse.shared/GEF-SDK-3.2M4/eclipse/plugi ns/org.eclipse.draw2d_3.2.0.jar
2aab084b9000-2aab084ee000 r-xs 00000000 08:06 328031 /var/db/nscd/hosts
2aab084ee000-2aab08500000 r-xp 00000000 08:06 5208037 /usr/X11R6/lib/X11/fonts/Type1/l048016t.pfa
2aab08500000-2aab085f9000 rwxp 2aab08500000 00:00 0
2aab085f9000-2aab08600000 ---p 2aab085f9000 00:00 0
2aab08600000-2aab08700000 rwxp 2aab08600000 00:00 0
2aab08700000-2aab08715000 r-xp 00000000 08:06 5370591 /usr/java/jdk1.5.0_06/jre/lib/amd64/libnet.so
2aab08715000-2aab08814000 ---p 00015000 08:06 5370591 /usr/java/jdk1.5.0_06/jre/lib/amd64/libnet.so
2aab08814000-2aab08817000 rwxp 00014000 08:06 5370591 /usr/java/jdk1.5.0_06/jre/lib/amd64/libnet.so
2aab08817000-2aab0881e000 r-xp 00000000 08:06 5370592 /usr/java/jdk1.5.0_06/jre/lib/amd64/libnio.so
2aab0881e000-2aab0891d000 ---p 00007000 08:06 5370592 /usr/java/jdk1.5.0_06/jre/lib/amd64/libnio.so
2aab0891d000-2aab0891f000 rwxp 00006000 08:06 5370592 /usr/java/jdk1.5.0_06/jre/lib/amd64/libnio.so
2aab0891f000-2aab0892c000 r-xs 00000000 08:06 2062504 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.jdt.d ebug_3.2.0.v20060216d/jdi.jar
2aab0892c000-2aab08946000 r-xs 00000000 08:06 5180944 /usr/share/icons/Bluecurve/icon-theme.cache
2aab08946000-2aab0894b000 r-xs 00000000 08:06 5175240 /usr/share/icons/gnome/icon-theme.cache
2aab0894b000-2aab0894f000 r-xs 00000000 08:06 2062542 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-apache-bsf.jar
2aab0894f000-2aab08950000 r-xs 00000000 08:06 2062525 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-apache-log4j.jar
2aab08950000-2aab08a50000 rwxp 2aab08950000 00:00 0
2aab08a50000-2aab08a93000 r-xs 00000000 08:06 2161294 /home.local/momin/eclipse-3.2.0.m5/configuration/org.eclipse .osgi/bundles/287/1/.cp/aptcore.jar
2aab08a94000-2aab08b94000 rwxp 2aab08a94000 00:00 0
2aab08b94000-2aab08c49000 r-xs 00000000 08:06 1702314 /home.local/momin/eclipse.shared/GEF-SDK-3.2M4/eclipse/plugi ns/org.eclipse.gef_3.2.0.jar
2aab08c49000-2aab08c5b000 r-xs 00000000 08:06 4976810 /usr/share/icons/hicolor/icon-theme.cache
2aab08c5b000-2aab08c67000 r-xs 00000000 08:06 2062544 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-apache-oro.jar
2aab08c67000-2aab08c68000 r-xs 00000000 08:06 2062543 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-apache-regexp.jar
2aab08c68000-2aab08c69000 r-xs 00000000 08:06 2062535 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-apache-resolver.jar
2aab08c69000-2aab08c6a000 r-xs 00000000 08:06 2062524 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-commons-logging.jar
2aab08c6a000-2aab08c73000 r-xs 00000000 08:06 2062537 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-commons-net.jar
2aab08c73000-2aab08c76000 r-xs 00000000 08:06 2062519 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-icontract.jar
2aab08c76000-2aab08d76000 rwxp 2aab08c76000 00:00 0
2aab08d76000-2aab08dc7000 r-xs 00000000 08:06 2062404 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.jdt.j unit_3.2.0.v20060215-1200/junitsupport.jar
2aab08dc7000-2aab08dcd000 r-xs 00000000 08:06 2062520 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-jai.jar
2aab08dcd000-2aab08dcf000 r-xs 00000000 08:06 2062529 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-javamail.jar
2aab08dcf000-2aab08dd1000 r-xs 00000000 08:06 2062533 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-jdepend.jar
2aab08dd1000-2aab08dd3000 r-xs 00000000 08:06 2062521 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-jmf.jar
2aab08dd3000-2aab08dd9000 r-xs 00000000 08:06 2062540 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-jsch.jar
2aab08dd9000-2aab08dec000 r-xs 00000000 08:06 2062532 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-junit.jar
2aab08dec000-2aab08def000 r-xs 00000000 08:06 2062527 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-launcher.jar
2aab08def000-2aab08df2000 r-xs 00000000 08:06 2062538 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-netrexx.jar
2aab08e00000-2aab08efe000 rwxp 2aab08e00000 00:00 0
2aab08efe000-2aab08f00000 ---p 2aab08efe000 00:00 0
2aab08f00000-2aab090f6000 rwxp 2aab08f00000 00:00 0
2aab090f6000-2aab09100000 ---p 2aab090f6000 00:00 0
2aab09100000-2aab09400000 rwxp 2aab09100000 00:00 0
2aab09400000-2aab095cc000 r-xs 00000000 08:06 1702301 /home.local/momin/eclipse.shared/GEF-SDK-3.2M4/eclipse/plugi ns/org.eclipse.draw2d.doc.isv_3.2.0.jar
2aab095cc000-2aab095de000 r-xp 00000000 08:06 5208035 /usr/X11R6/lib/X11/fonts/Type1/l048013t.pfa
2aab095de000-2aab095f0000 r-xp 00000000 08:06 5208041 /usr/X11R6/lib/X11/fonts/Type1/l048036t.pfa
2aab09600000-2aab096fd000 rwxp 2aab09600000 00:00 0
2aab096fd000-2aab09700000 ---p 2aab096fd000 00:00 0
2aab09700000-2aab098fe000 rwxp 2aab09700000 00:00 0
2aab098fe000-2aab09900000 ---p 2aab098fe000 00:00 0
2aab09900000-2aab09927000 r-xs 00000000 08:06 1703668 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.models.dbdefinition_1.0.0.jar
2aab09927000-2aab09929000 r-xs 00000000 08:06 1703665 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.fe.ui.actions_1.0.0.jar
2aab09929000-2aab09939000 r-xs 00000000 08:06 1703450 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.ws.doc.user_1.0.0.jar
2aab09939000-2aab09940000 r-xs 00000000 08:06 1703452 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.ws.uddiregistry_1.0.0.jar
2aab09940000-2aab0996e000 r-xs 00000000 08:06 1703563 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.css.ui_1.0.100.v20060112_0325.jar
2aab0996e000-2aab09a32000 r-xs 00000000 08:06 1704340 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.wsi_1.0.0.jar
2aab09a32000-2aab09a8b000 r-xs 00000000 08:06 1703865 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.sse.core_1.0.0.v20060112_0325.jar
2aab09a8b000-2aab09ab3000 r-xs 00000000 08:06 1703870 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.validation_1.0.0.jar
2aab09ab3000-2aab09ab4000 r-xs 00000000 08:06 1703570 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.dtd.ui.infopop_1.0.0.jar
2aab09ab4000-2aab09ad5000 r-xs 00000000 08:06 1703275 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.server.generic.core_1.0.0.jar
2aab09ad5000-2aab09ad7000 r-xs 00000000 08:06 1703659 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.dbdefinition.mysql_1.0.0.jar
2aab09ad7000-2aab09b14000 r-xs 00000000 08:06 1703669 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.models.sql.edit_1.0.0.jar
2aab09b14000-2aab09b1c000 r-xs 00000000 08:06 1703484 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.common.uriresolver_1.0.0.jar
2aab09b1c000-2aab09bd9000 r-xs 00000000 08:06 1703568 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.doc.user_1.0.0.jar
2aab09bd9000-2aab09be4000 r-xs 00000000 08:06 1703923 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.ws.parser_1.0.0.jar
2aab09be4000-2aab09bee000 r-xs 00000000 08:06 1703872 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.web_1.0.0.jar
2aab09bee000-2aab09bfb000 r-xs 00000000 08:06 1703153 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.common.frameworks_1.0.0.jar
2aab09bfb000-2aab09c09000 r-xs 00000000 08:06 1704445 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.xsd.core_1.0.0.jar
2aab09c09000-2aab09c33000 r-xs 00000000 08:06 1703297 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.server.tomcat.core_1.0.0.jar
2aab09c33000-2aab09c42000 r-xs 00000000 08:06 1703299 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.server.ui.doc.user_1.0.0.jar
2aab09c42000-2aab09c43000 r-xs 00000000 08:06 1703475 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.common.infopop_1.0.0.jar
2aab09c43000-2aab09c47000 r-xs 00000000 08:06 1703151 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.common.annotations.core_1.0.0.jar
2aab09c47000-2aab09c49000 r-xs 00000000 08:06 1703272 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.jsp.ui.infopop_1.0.0.jar
2aab09c49000-2aab09cc7000 r-xs 00000000 08:06 1703584 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.javascript.ui_1.0.0.v20060112_0325.jar
2aab09cc7000-2aab09ccb000 r-xs 00000000 08:06 1703864 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.sqleditor.doc.user_1.0.0.jar
2aab09ccb000-2aab09ceb000 r-xs 00000000 08:06 1703255 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.j2ee.doc.user_1.0.0.jar
2aab09ceb000-2aab09d2c000 r-xs 00000000 08:06 2095637 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.pde.b uild_3.2.0.v20060217/pdebuild.jar
2aab09d33000-2aab09d44000 r-xs 00000000 08:06 1703869 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.validation.ui_1.0.0.jar
2aab09d44000-2aab09d55000 r-xs 00000000 08:06 1703664 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.derby_1.0.0.jar
2aab09d55000-2aab09d5e000 r-xs 00000000 08:06 1703871 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.web.ui_1.0.0.jar
2aab09d5e000-2aab09d60000 r-xs 00000000 08:06 1703657 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.dbdefinition.derby_1.0.0.jar
2aab09d60000-2aab09e16000 r-xs 00000000 08:06 2062503 /home.local/momin/eclipse-3.2.0.m5/plugins/org.eclipse.jdt.d ebug_3.2.0.v20060216d/jdimodel.jar
2aab09e4e000-2aab09e78000 r-xs 00000000 08:06 1703576 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.html.ui_1.0.100.v20060112_0325.jar
2aab09e78000-2aab09e79000 r-xs 00000000 08:06 1703672 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.outputview.infopop_1.0.0.jar
2aab09e79000-2aab09ee0000 r-xs 00000000 08:06 2062518 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-nodeps.jar
2aab09ee0000-2aab09ee9000 r-xs 00000000 08:06 2062531 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-starteam.jar
2aab09ee9000-2aab09eea000 r-xs 00000000 08:06 2062523 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-stylebook.jar
2aab09eea000-2aab09eec000 r-xs 00000000 08:06 2062536 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-swing.jar
2aab09eec000-2aab09efd000 r-xs 00000000 08:06 2062522 /home.local/momin/eclipse-3.2.0.m5/plugins/org.apache.ant_1. 6.5/lib/ant-trax.jar
2aab09f00000-2aab09ff8000 rwxp 2aab09f00000 00:00 0
2aab09ff8000-2aab0a000000 ---p 2aab09ff8000 00:00 0
2aab0a000000-2aab0a100000 rwxp 2aab0a000000 00:00 0
2aab0a100000-2aab0a105000 r-xs 00000000 08:06 1703152 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.common.annotations.ui_1.0.0.jar
2aab0a105000-2aab0a111000 r-xs 00000000 08:06 1703652 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.data.core_1.0.0.jar
2aab0a111000-2aab0a113000 r-xs 00000000 08:06 1703813 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.server.ui.infopop_7.0.0.jar
2aab0a113000-2aab0a127000 r-xs 00000000 08:06 1703298 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.jst.server.tomcat.ui_1.0.0.jar
2aab0a127000-2aab0a1ea000 r-xs 00000000 08:06 1704335 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.wsdl.ui_1.0.0.jar
2aab0a1ea000-2aab0a1f1000 r-xs 00000000 08:06 1703812 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.server.ui.doc.user_1.0.0.jar
2aab0a1f1000-2aab0a200000 r-xs 00000000 08:06 1703578 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.internet.monitor.core_1.0.0.jar
2aab0a20b000-2aab0a21f000 r-xs 00000000 08:06 1703355 /home.local/momin/eclipse..shared/wtp-sdk-1.5M4/eclipse/plug ins/org.eclipse.jst.servlet.ui_1.0.0.jar
2aab0a21f000-2aab0a31f000 rwxp 2aab0a21f000 00:00 0
2aab0a31f000-2aab0a332000 r-xs 00000000 08:06 1703866 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.sse.doc.user_1.0.0.jar
2aab0a332000-2aab0a33b000 r-xs 00000000 08:06 1703577 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.internet.cache_1.0.0.jar
2aab0a33b000-2aab0a33d000 r-xs 00000000 08:06 1703654 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.dbdefinition.db2.iseries_1.0.0.jar
2aab0a33d000-2aab0a36c000 r-xs 00000000 08:06 1703925 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.ws_1.0.0.jar
2aab0a36c000-2aab0a399000 r-xs 00000000 08:06 1703470 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.common.emf_1.0.0.jar
2aab0a399000-2aab0a39e000 r-xs 00000000 08:06 1703656 /home.local/momin/eclipse.shared/wtp-sdk-1.5M4/eclipse/plugi ns/org.eclipse.wst.rdb.dbdefinition.db2.zseries_1.0.0.jar
2aab0a39e000-2aab0a3d3
Re: Problems with Eclipse 3.2 (x64) [message #299514 is a reply to message #299513] |
Mon, 20 February 2006 02:54  |
Hi, you may get more answers on the eclipse.platform.swt newsgroup.
-tmo
Muhammad Momin Rashid wrote:
> Hello All,
> and it crashed.
> Registers:
> v ~C2IAdapter
> v ~I2CAdapter
> v ~I2CAdapter
> v ~OSRAdapter
> Other Threads:
> Heap
> Dynamic libraries:
> 2a
Current Time: Sun Aug 31 18:28:08 EDT 2025
Powered by FUDForum. Page generated in 0.03620 seconds
