Home » Newcomers » Newcomers » Eclipse 3.1M5a does not start on Mac OS X
Eclipse 3.1M5a does not start on Mac OS X [message #29888] Fri, 04 March 2005 11:46 Go to next message
Originally posted by: markus.haack.de.ibm.com
I am having problem starting up Eclipse 3.1M5a on Mac OS X box. After
downloading the packadge I unpacked it and copied the director to the
Applications folder.
The splash screen shows up and after that I got a messagebox "An error
has occured. See the log file ..."
Please help... Thanks in advance...
Here is the complete log:
!SESSION 2005-03-04 17:28:57.39
eclipse.buildId=I20050219-1500
java.version=1.4.2_05
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=de_DE
Framework arguments: -keyring /Users/Markus/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch ppc -keyring
/Users/Markus/.eclipse_keyring -consoleLog -showlocation
!ENTRY org.eclipse.osgi 2005-03-04 17:28:57.56
!MESSAGE Bundle org.eclipse.update.configurator@3:start not found.
!ENTRY org.eclipse.core.runtime 2005-03-04 17:28:57.388
!MESSAGE Product org.eclipse.platform.ide could not be found.
!ENTRY org.eclipse.osgi 2005-03-04 17:28:57.408
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:206)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Re: Eclipse 3.1M5a does not start on Mac OS X [message #29907 is a reply to message #29888] Fri, 04 March 2005 21:18 Go to previous messageGo to next message
What package did you download? I am using 3.1M5a on several OS X machine
with no problems.
On 3/4/05 9:46 AM, in article d0a3di$bdh$1@www.eclipse.org, "Markus Haack"
<markus.haack@de.ibm.com> wrote:
> Hello,
> !STACK 1
> at
> va:206)
> at
> at
> at
> at
> ava:25)
Re: Eclipse 3.1M5a does not start on Mac OS X [message #29925 is a reply to message #29907] Sun, 06 March 2005 06:35 Go to previous messageGo to next message
I have download eclipse-SDK-3.1M5a-macosx-carbon.tar.gz from eclipse.org
it contains 3005 files.
> with no problems.
>>Hello,
>>!STACK 1
>>at
>>va:206)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at
>>at
>>ava:25)
Re: Eclipse 3.1M5a does not start on Mac OS X [message #33380 is a reply to message #29925] Sat, 12 March 2005 11:01 Go to previous message
Originally posted by: markus.haack.gmail.com
I have found the problem. I extracted the package on an external disk
which ist formated with FAT32.
If I copy it to the internal drive and extract Eclipse here. It works.
>> with no problems.
>> Haack"
>>> Hello,
>>> -showlocation
>>> !STACK 1
>>> at
>>> va:206)
>>> at
>>> at
>>> at
>>> at
>>> ava:25)
Previous Topic:Plug-Ins Installation
Next Topic:How to search the archive of the eclipse newsgroups?
Current Time: Thu Jul 17 21:24:24 EDT 2025
Powered by FUDForum. Page generated in 0.29661 seconds
