Home » Archived » Corona » Missing corona plugins
Missing corona plugins [message #2575] Mon, 03 March 2008 14:09 Go to next message
Originally posted by: canadianguy.gmail.com
Can someone tell me where the org.eclipse.corona.soa plugins were moved to?
I have been trying to provide the ability for my plugins to publish classes
as SOAP Services and the Corona plugins seemed to be my brightest hope...
now they've been removed from CVS and don't seem to be in the new SVN
repository.
If someone has a better idea for libraries to use, I'm open to suggestion
there too.... sooo close to getting the corona libraries working though!
I was using an updated Corona plugin after needing to upgrade SOAP libraries
used within Apache Muse. Specifically, I was building on version 0.9.0
-James
Re: Missing corona plugins [message #2604 is a reply to message #2575] Mon, 10 March 2008 08:16 Go to previous messageGo to next message
Corona's source repository was moved from CVS to SVN. Only the active
projects being used by Corona's server-side platform were migrated. At this
time the SOA plugin was deprecated and not migrated to SVN.
Corona's project plan is being revised to adopt COSMOS. This Eclipse
project contains libraries for web service enablement (via WSDM). You
should check with COSMOS to determine if they have the SOA libraries you are
looking for.
Re: Missing corona plugins [message #2632 is a reply to message #2604] Mon, 10 March 2008 09:09 Go to previous message
Figures, I was finally getting this stuff to work! I will check in with the
Cosmos people.
Thanks for the info.
-James
"Dennis O'Flynn" <dennis.oflynn@compuware.com> wrote in message
news:fr38qg$eja$1@build.eclipse.org...
this
are
> looking for.
Previous Topic:Corona Integration Build: I-v20080222
Next Topic:SOA under Corona
Current Time: Wed Jun 04 13:59:25 EDT 2025
Powered by FUDForum. Page generated in 0.03605 seconds
