Home » Eclipse Projects » Eclipse Platform » org.eclipse.ui.menus extension point and IDynamicMenu interface
org.eclipse.ui.menus extension point and IDynamicMenu interface [message #298711] Thu, 02 February 2006 19:42 Go to next message
Originally posted by: sducas.sdmda.com
Where can I find some informations about org.eclipse.ui.menus EP and
IDynamicMenu...
Where can I find a basic exemple or any information: with eclipse3.2M4 I
can't even open the extension point schema..
THANKS
Re: org.eclipse.ui.menus extension point and IDynamicMenu interface [message #298762 is a reply to message #298711] Fri, 03 February 2006 12:51 Go to previous messageGo to next message
It's a new feature for 3.2 and it's still under construction. There
should be something concrete with more info in 3.2M5. If you want to
investigate, check out one of the latest I-builds (just don't overwrite
your 320M4 installation :-)
Later,
PW
Re: org.eclipse.ui.menus extension point and IDynamicMenu interface [message #298988 is a reply to message #298711] Wed, 08 February 2006 13:55 Go to previous message
Originally posted by: douglas.pollock.magma.ca
> IDynamicMenu...
IDynamicMenu has been pulled from 3.2 development. There was not enough
time to finish it before the API freeze.
cheers,
d.
Previous Topic:Programmatically determining font options
Next Topic:Can Eclipse be made to support OSGi Message Bundles for plain Java applications (not plugins)
Current Time: Tue Jul 22 06:33:58 EDT 2025
Powered by FUDForum. Page generated in 0.06086 seconds
