Home » Eclipse Projects » Eclipse Platform » Hovers and Declaration in Windows
Hovers and Declaration in Windows [message #298142] Wed, 25 January 2006 13:14 Go to next message
Originally posted by: Crash1hd.shaw.ca
Hello everyone!
I was wondering why is it that when I run eclipse 3.1.1 in linux I get the
declarations of jdk stuff for example if I mouse over println in
System.out.println(); I get:
public void println(String x) {
synchronized (this) {
print(x);
newLine();
in the declarations window
yet when I do this in the same program running in windows I get nothing?
the same goes for hovers If I mouse over something it tells me about it
yet in windows nothing happens so for the same example of
Terminate the current line by writing the line separator string. The line
separator string is defined by the system property line.separator, and is
not necessarily a single newline character
and again in windows I get nothing???
what do I need to do to add this feature to the windows eclipse?
Re: Hovers and Declaration in Windows [message #298173 is a reply to message #298142] Thu, 26 January 2006 06:09 Go to previous messageGo to next message
Originally posted by: daniel.megert.eclipse.org
Adam wrote:
> Hello everyone!
> the declarations of jdk stuff for example if I mouse over println in
> print(x);
> newLine();
Looks like the installed JRE does not contain source under Windows.
Dani
> it yet in windows nothing happens so for the same example of
> line separator string is defined by the system property
> line.separator, and is not necessarily a single newline character
Re: Hovers and Declaration in Windows [message #298378 is a reply to message #298173] Mon, 30 January 2006 09:35 Go to previous message
Thankyou for the reply.
I ended up figuring out over the weekend that I had to jre's installed and
after removing the old jre and rebooting everything works fine now
Adam
Thanks again
Previous Topic:SDK Examples feature not found
Next Topic:Eclipse 3.1 Test Framwork : org.eclipse.ant.optional.junit\fragment.xml broken?
Current Time: Sun Nov 09 06:54:37 EST 2025
Powered by FUDForum. Page generated in 0.03326 seconds
