Home » Newcomers » Newcomers » Eclipse on Gentoo
Eclipse on Gentoo [message #29815] Wed, 02 March 2005 14:20
Originally posted by: edward.born-digital.co.uk
After much poking around, it seems that there is a problem with running
Eclipse using JVMs compiled from source on Gentoo as these systems do
not appear to support file-locking.
The solution is to use a binary jvm from Sun, and use portage and one of
the ebuilds in /usr/portage/dev-java/sun-jdk to install it (not the
source ebuilds in /usr/portage/dev-java/sun-j2sdk!!)
emerge sync to update your portage tree.
Download the sun binary jvm, e.g. j2sdk_1_4_2_07-linux-i586.bin
cp j2sdk_1_4_2_07-linux-i586.bin /usr/portage/distfiles
emerge =sun-jdk-1.4.2.07
/usr/sbin/env-update && source /etc/profile
emerge -C eclipse-sdk
echo "dev-util/eclipse-sdk ~x86" >> /etc/portage/package.keywords
emerge eclipse-sdk
[with thanks to inode77 on the gentoo forums for this advice]
Unless this is the only jvm on the machine, you still need to force
eclipse to use it, because for some reason the eclipse executable seems
to ignore the settings for the system jvm that you might have set using
java-config, so for example:
eclipse-3 -vm /opt/sun-jdk-1.4.2.07/bin/java
on the command line or in your menu file.
Anyway this now works for me...
Previous Topic:Connection timed out:connect
Next Topic:Extending the debugger?
Current Time: Thu Aug 07 02:09:40 EDT 2025
Powered by FUDForum. Page generated in 0.08772 seconds
