Home » Eclipse Projects » Eclipse Platform » [RCP]pb with org.eclipse.ui.forms dependency
[RCP]pb with org.eclipse.ui.forms dependency [message #297857] Sat, 21 January 2006 06:46
Originally posted by: david.vauquelin.gmail.com
Hi all,
I am an rcp application and in one of my view i am using forms, so i added
to my application the dependency org.eclipse.ui.forms but now i cannot
launch the application
This is the log i have each time i want to launch the appli after i added
the dependency :
!SESSION 2006-01-21 12:40:45.500
eclipse.buildId=unknown
java.version=1.5.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -application com.moviesoftrcp.logesco.application
-pdelaunch
Command-line arguments: -application com.moviesoftrcp.logesco.application
-data C:\runtime-EclipseApplication -dev
file:C:/newworkspace/.metadata/.plugins/org.eclipse.pde.core /logesco/dev.properties
-pdelaunch -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2006-01-21 12:40:46.125
!MESSAGE Bundle
initial@reference:file:../../../../../newworkspace/com.moviesoftrcp.logesco/
[11] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2006-01-21 12:40:46.125
!MESSAGE Missing required bundle org.eclipse.ui.forms_0.0.0.
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"com.moviesoftrcp.logesco.application" could not be found in the registry.
The applications available are: <NONE>.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!MESSAGE Bundle
why it doesnt work normally with forms dependency?
Previous Topic:Multiple sources for Eclipse plugins
Next Topic:CVSTeamProvider
Current Time: Sat Jul 12 19:48:29 EDT 2025
Powered by FUDForum. Page generated in 0.03556 seconds
