Home » Newcomers » Newcomers » Keybinding:shortcut key
Keybinding:shortcut key [message #29793] Wed, 02 March 2005 00:56
Originally posted by: debashreeh.bsil.com
hi,
I need help regarding keybinding.
I just followed following code about keybinding and also registered the
action.(If it runs properly then the action would be evoked by pressing
Ctrl+A, where addSceneAction is the necesary action,the action is already
bound to a context menu)
In plugin.xml:
<extension
point="org.eclipse.ui.commands">
<command
name="AddScenes"
description="%AddScenes"
category="com.zipc.zipcone.sdd.viewCategory"
id="com.zipc.zipcone.sdd.ui.editors.add">
</command>
<keyBinding
string="Ctrl+A"
scope="org.eclipse.ui.globalScope"
commandId="com.zipc.zipcone.sdd.ui.editors.add"
configuration="org.eclipse.ui.defaultAcceleratorConfiguration "
keyConfigurationId="org.eclipse.ui.defaultAcceleratorConfiguration "/>
in .java file
addSceneAction.setActionDefinitionId("com.zipc.zipcone.sdd.ui.editors.add ");
ActionRegistry
actionReg=ei.getSDDProjectNature().getGrobalActionRegistry() ;
actionReg.registerAction(addSceneAction);
but when I run the prog. nothing happens upon pressing Ctrl+A key.I've
read previous posts regarding this keybinding...but nothing comes out (I
couldn't understand any fault in my code).
Can anyone help...It's urgent..I'm under clients pressure.
-Debashree
S/W Engg.
BlueStar Infotech
Bangalore
India
Previous Topic:Eclipse hangs on startup
Next Topic:Context menus for default editors
Current Time: Sun Sep 28 00:36:22 EDT 2025
Powered by FUDForum. Page generated in 0.07673 seconds
