IllegalArgument exception on eclipse startup (HP-UX) [message #29769] |
Tue, 01 March 2005 12:46  |
Originally posted by: basven.yahoo.com
I am trying to move my development environment from XP to HP-UX (11.11 to
be precise). I am using the 1.4.2.05 JDK and d/l the eclipse SDK 3.01
hpux motif package (do I need some swt/motif patch ?).
When I try to start eclipse I get the following exception:
!SESSION Mar 01, 2005 10:10:17.722
eclipse.buildId=M200409161125
java.version=1.4.2.05
java.vendor=Hewlett-Packard Co.
BootLoader constants: OS=hpux, ARCH=PA_RISC, WS=motif, NL=en
!ENTRY org.eclipse.osgi Mar 01, 2005 10:10:17.723
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:2677)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.graphics.Font.<init>(Font.java:106)
org.eclipse.jface.resource.FontRegistry.calculateDefaultFont (FontRegistry.java:412)
org.eclipse.jface.resource.FontRegistry.defaultFontRecord(Fo ntRegistry.java:430)
org.eclipse.jface.resource.FontRegistry.getFontRecord(FontRe gistry.java:519)
at org.eclipse.jface.resource.FontRegistry.get(FontRegistry.jav a:472)
org.eclipse.jface.resource.JFaceResources.getDialogFont(JFac eResources.java:182)
at org.eclipse.jface.dialogs.Dialog.initializeDialogUnits(Dialo g.java:778)
org.eclipse.jface.dialogs.TitleAreaDialog.createContents(Tit leAreaDialog.java:93)
at org.eclipse.jface.window.Window.create(Window.java:348)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:925)
at org.eclipse.jface.window.Window.open(Window.java:637)
org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(Cho oseWorkspaceDialog.java:65)
org.eclipse.ui.internal.ide.IDEApplication.promptForWorkspac e(IDEApplication.java:314)
org.eclipse.ui.internal.ide.IDEApplication.checkInstanceLoca tion(IDEApplication.java:219)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:83)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: IllegalArgument exception on eclipse startup (HP-UX) [message #29773 is a reply to message #29769] |
Tue, 01 March 2005 15:12  |
> !STACK 1
As an FYI, it this is related to using Reflection X to connect to my HP-UX
box. I started a font server on the hpux box that I am actually running
eclipse on and changed the ReflectionX options to make use of that
fontserver and it now seems to work......
Bas
FUDForum. Page generated in 0.31573 seconds
