Home » Eclipse Projects » Eclipse Platform » Cryptocraphic components in org.eclipse.runtime, and export restrictions
Cryptocraphic components in org.eclipse.runtime, and export restrictions [message #297285] Wed, 11 January 2006 05:07 Go to next message
Originally posted by: news.karsten-becker.de
To be honest I just want to focus your attention on the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=121997
PROBLEM:
We want to deliver Eclipse/RCP Applications via the Internet.
Unfortunately one of my colleagues noticed the Export Control Statement
in the org.eclipse.runtime plugin's about.html. This made us quite
nervous and we talked to our ECC-Department which did not allow us to
distribute our applications via Internet.
Albeit we know that the mentioned SHA-1 Encryption algorithm is NOT
implemented in the Eclipse plugin itself, it makes delivering
applications via Internet still a risk.
And the only reason this crypto part exists is the usage in some CVS
code, which is not vital for RCP applications..
SOLUTION:
My proposed solution for back-ward compatibility would be to create a
fragment that contains this crypto stuff, so that you can deliver this
fragment independent from the more vital org.eclipse.runtime plugin.
For future releases I would propose a new plugin that deals with crypto
related functions.
This way you could easily deliver a application via Internet without
making yourself a head about this Export Control Statement.
Karsten
Re: Cryptocraphic components in org.eclipse.runtime, and export restriction [message #297312 is a reply to message #297285] Wed, 11 January 2006 12:09 Go to previous messageGo to next message
> algorithm is NOT implemented in the Eclipse plugin
> itself, it makes delivering applications via Internet
> still a risk.
Just to be clear; you're talking about a legal risk, rather than a code/security risk, right?
> in some CVS code, which is not vital for RCP
> applications..
Actually, it's there to support AuthorisationHandler, and to make sure that passwords saved aren't easily readable by default. It's even part of the API; <a href=" http://help.eclipse.org/help31/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/runtime/Platform.html#a ddAuthorizationInfo (java.net.URL,%20java.lang.String,%20java.lang.String,%20jav a.util.Map) ">org.eclipse.core.runtime.Platform.addAuthorizationInfo()</a >
It certainly could be useful in applications; for example, a mail application could use this to store a username/password for a remote mail server. And having it built-in to the platform makes it much easier to have a standard place rather than everyone adding their own.
That said, there's no reason why this API method couldn't still exist but throw an Exception if the appropriate fragment wasn't supplied.
Alex.
Re: Cryptocraphic components in org.eclipse.runtime, and export restriction [message #297347 is a reply to message #297312] Thu, 12 January 2006 04:55 Go to previous messageGo to next message
>> still a risk.
That's correct.
>> applications..
Ahh, ok, I did not notice that it is a General Purpose API, because CVS
is explicitly mentioned in the about.html
This definitely sounds like a real use-case for me. So I would support
creating a more sounding plugin for it. Maybe with chooseable encryption
algorithm. So that you can choose the storage strategy.
Karsten
Re: Cryptocraphic components in org.eclipse.runtime, and export [message #297355 is a reply to message #297347] Thu, 12 January 2006 07:12 Go to previous messageGo to next message
Anyone for implementing a hook to allow it to be stored in the Mac OS X Keychain application?
Re: Cryptocraphic components in org.eclipse.runtime, and export [message #297358 is a reply to message #297355] Thu, 12 January 2006 08:10 Go to previous messageGo to next message
I have a vision :) And you a new goal ;)
I will try my very best to create some proposal patch for 3.1 and maybe
some basic thoughts for the security plugin..
But I guess that this would require native access right?
Re: Cryptocraphic components in org.eclipse.runtime, and export [message #297373 is a reply to message #297358] Thu, 12 January 2006 10:18 Go to previous messageGo to next message
Yeah, you need to be able to call C functions, which is going to require a bit of C DLL coding and/or native methods. But hey, they do it all the time for SWT/OSX :-)
The API for Mac keychain access is described at:
http://developer.apple.com/documentation/Security/Reference/ keychainservices/index.html
You'll have to use the Carbon APIs (C) rather than Cocoa APIs (Objective-C) since Eclipse.app is a Carbon API. Touch base with me at my Gmail address (alex.blewitt) if you want help moving forwards with this; I've got a Mac and a semi-recent version of Xcode at home too ...
Alex.
Re: Cryptocraphic components in org.eclipse.runtime, and export [message #297384 is a reply to message #297373] Thu, 12 January 2006 11:11 Go to previous message
Aehm, I for my self meant the platform independent part of it, as I
(unfortunately) have no Mac :)
Karsten
Previous Topic:editor plugin color preferences question
Next Topic:Eclipse Event Management
Current Time: Wed Nov 12 12:18:03 EST 2025
Powered by FUDForum. Page generated in 0.25173 seconds
