Home » Eclipse Projects » Eclipse Platform » webdav on 3.1?
webdav on 3.1? [message #296962] Thu, 05 January 2006 14:22 Go to next message
Is WebDav dead? I tried running it on 3.1.1, but got errors about failing to
load classes, etc. (probably apis out of date)
Re: webdav on 3.1? [message #296995 is a reply to message #296962] Fri, 06 January 2006 09:03 Go to previous messageGo to next message
Originally posted by: mvalenta.ca.ibm.com
Are you referring to the org.eclipse.webdav plugin or the FTP/WebDAV
feature? If it is the later, make sure you have the proper version.
There was a problem with the update site so you may need to get the
3.1.1 version of the feature from the downloads page.
Michael
Re: webdav on 3.1? [message #297043 is a reply to message #296995] Fri, 06 January 2006 13:29 Go to previous message
That worked. Maybe somebody could fix the update site?
"Michael Valenta" <mvalenta@ca.ibm.com> wrote in message
news:dplte4$fp6$1@utils.eclipse.org...
> feature? If it is the later, make sure you have the proper version. There
> was a problem with the update site so you may need to get the 3.1.1
> Michael
>> to load classes, etc. (probably apis out of date)
Previous Topic:Deleting a project version on CVS
Next Topic:3 different plugins with 3 toolbars but without separator in between
Current Time: Wed Jul 09 09:26:34 EDT 2025
Powered by FUDForum. Page generated in 0.04548 seconds
