Home » Eclipse Projects » Eclipse Platform » Unwanted Behavior: Eclipse Copying Files From Linked Resource
Unwanted Behavior: Eclipse Copying Files From Linked Resource [message #296532] Fri, 23 December 2005 11:20 Go to next message
Originally posted by: al.johnson.nagrastar.com
Greetings. I've read the documentation, searched Google and this forum and
haven't even remotely found the answer, so here it goes.
We are developing on Windows and using ClearCase served from a Unix box.
The mapped drive is very slow so to speed up my builds, I set the output
directory for class files (Java development) to an Eclipse folder linked to
a local drive folder. Works great until I restart Eclipse, at which time it
begins to copy all the files in the linked folder to a new folder of the
same name under the project directory which is on the slow mapped network
drive, thereby defeating the whole point of a linked resource. From this
point on, Eclipse ignores the linked folder as the default output folder and
uses this new one it created. In every way, the folder still looks like a
linked folder; even in the .project file. This has been EXTREMELY
aggravating. I've created the folder links both from the "create linked
folder" from the project Java Build Path properties dialog and from the
General/Workspace/Linked Resources dialog and the problem persists.
Is this a bug? By design? Is there a fix or workaround?
Al
PS, in every other way, Eclipse kicks major ass.
Re: Unwanted Behavior: Eclipse Copying Files From Linked Resource [message #296843 is a reply to message #296532] Tue, 03 January 2006 11:47 Go to previous messageGo to next message
Any comments or suggestions on this one?
"Al Johnson" <al.johnson@nagrastar.com> wrote in message
news:doh84a$tch$1@utils.eclipse.org...
> and haven't even remotely found the answer, so here it goes.
> to a local drive folder. Works great until I restart Eclipse, at which
> time it begins to copy all the files in the linked folder to a new folder
> of the same name under the project directory which is on the slow mapped
> network drive, thereby defeating the whole point of a linked resource.
> From this point on, Eclipse ignores the linked folder as the default
> output folder and uses this new one it created. In every way, the folder
> still looks like a linked folder; even in the .project file. This has
> been EXTREMELY aggravating. I've created the folder links both from the
> "create linked folder" from the project Java Build Path properties dialog
> and from the General/Workspace/Linked Resources dialog and the problem
> persists.
> Al
Re: Unwanted Behavior: Eclipse Copying Files From Linked Resource [message #296922 is a reply to message #296532] Wed, 04 January 2006 14:44 Go to previous message
Originally posted by: john.eclipsefaq.org
That sounds like a bug. The scenario you describe was one of the main
use cases for linked resources when they were introduced. The link
should still be there when you startup the next session.
Can you please enter a bug report against Eclipse > Platform >
Resources. Some of the details you can provide:
- What build of Eclipse you are using (found under Help > About)
- Is the failure repeatable every time, intermittent, etc.
- Are there any errors in your log file on startup after creating the
linked folder?
- Do links disappear for a linked folder in the same project that is
*not* the output folder. I.e., does it only "lose" the link when linking
the output folder.
- Also, attaching the .project and .classpath files to the bug would
help to verify your setup.
> Al
Previous Topic:configure process priority
Next Topic:Dropdown control in the Workbench toolbar
Current Time: Tue Jul 22 03:13:17 EDT 2025
Powered by FUDForum. Page generated in 0.05369 seconds
