[ANN] Jetty Launcher plugin 1.0.3 [message #29642] |
Fri, 09 May 2003 07:33 |
Originally posted by: glongman.intelligentworks.nospam.com
More improvements based on user feeback.
Update site: http://spindle.sourceforge.net/updates.
Quick Start Guide at http://spindle.sourceforge.net/jettylauncher
Geoff
"G Longman" <glongman@intelligentworks.nospam.com> wrote in message news:...
> Much, much improved. Classpath entries are regulated now. If you want JMX,
> SSL, or JSP support at runtime, there are check boxes on a tab. Users
> familliar with launching Jetty from $JETTY_HOME$ get more help now as the
VM
> directive -Djetty.home is now automatically set. Plus the Quick Start
guide
> installs itself in Eclipse Help.
> Thanks to all who tried it out and sent feedback, particularly Dolf and
> Piotr.
> Full details are available in the Quick Start guide at the link below
> Follows is the orginal announcement...
> Install the plugin, select your project, click Run->Run, New Jetty Web.
> Select the place on your drive where a Jetty dstro has been extracted,
enter
> the port and the folder in your project that will be context root, hit
> "Run". That's it.
> Or you can specify an xml file that Jetty understands, so you stay in
> complete control.
> Jetty Launcher was built by the Spindle team.
> ~240k download, Update site: http://spindle.sourceforge.net/updates.
> Cheers,
> Geoff
> Geoffrey Longman
> Intelligent Works Inc.
FUDForum. Page generated in 0.24488 seconds
