| 3.1 Help stopped opening, HTTP 500 server error. Tomcat problem? [message #295358] |
Mon, 28 November 2005 16:22 |
My system:
Windows XP SP1
Java 1.4.2 (IBM variety)
Eclipse 3.1.x, Eclipse 3.0, Eclipse 2.1.3 and multiple other eclipse-based
products
Suddenly, all of my 3.1 builds (and my company's 3.1-based products) fail to
launch the Help on my system. When I launch Help from Eclipse 2.1.3 or 3.0,
everything works fine. These Eclipse 3.1 installations have successfully
launched Help in the past.
I get a HTTP 500 Internal Server Error when I open the Help. For the life of
me (and several others), we can't figure out what's going on.
- I am not using a proxy.
- Nothing is written to workspace log, though one time I got this exception
that occurred when starting the application server:
!ENTRY org.eclipse.help.base 4 0 2005-11-28 14:40:34.477
!MESSAGE The embedded application server could not run help web application.
!STACK 1
org.eclipse.core.runtime.CoreException: Exception occurred starting
application server.
org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:270)
org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(Appser
verPlugin.java:143)
org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPl
ugin.java:41)
org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:5
8)
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSy
stem.java:245)
org.eclipse.help.internal.base.HelpDisplay.displayHelpURL(He lpDisplay.java:1
64)
org.eclipse.help.internal.base.HelpDisplay.displayHelp(HelpD isplay.java:54)
org.eclipse.help.ui.internal.DefaultHelpUI.displayHelp(Defau ltHelpUI.java:12
6)
org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp (WorkbenchHelpSy
stem.java:822)
org.eclipse.ui.internal.actions.HelpContentsAction$1.run(Hel pContentsAction.
java:83)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.actions.HelpContentsAction.run(HelpC ontentsAction.ja
va:81)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContribu
tionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:60)
at java.lang.reflect.Method.invoke(Method.java:391)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!SUBENTRY 1 org.eclipse.tomcat 4 0 2005-11-28 14:40:34.477
!MESSAGE Exception occurred starting application server.
What would cause Tomcat server not to start on 3.1 but will start in 3.0?
Things I've tried:
- Turned off Zone Labs Integrity Client (firewall)
- Tried IE and Firefox
- Tried internal and external browser settings
- Specified the help server as 127.0.0.1 and localhost
- Specified a firewall friendly port of 80 for help server
- Rebooted
- Tried different and new workspaces
- Deleted configurations
- -clean option
- searched for related bugs
- followed the tip in the readme to check for proxy settings
- fresh install of JRE 1.4.2 and fresh install of Eclipse 3.1.1 with new
workspace
Any other ideas?
- Tomcat problem? Is there a way to make sure it is running right? Restart
it? Why would it not start with 3.1, but starts with 3.0?
- JRE? I have 1.4.2 as my system JRE.
- Uninstall and reinstall these guys? They are just unzips, not really
installations, per se.
Any ideas would be greatly appreciated. My work is hindered, since I'm
developing help content.
seth.
FUDForum. Page generated in 0.05505 seconds
