Home » Eclipse Projects » Eclipse Platform » Class Loader
Class Loader [message #295225] Fri, 25 November 2005 19:28 Go to next message
Originally posted by: raghavendra.vaidya.ps.ge.com
I am developing a plug-in the targett of which is a JAva Project. The plu-in
tries to load some of the class files belonging to the java project during
the processing and falis with a ClassNotFound Exception. The Java project
references this plugin as a required project in the build path - The plug in
will be imported into the workspace with a link .
This problem, I guess, happens due to the class loader architecture of the
Eclipse platform. Does any one know how to get around this problem??
Vaidya
Re: Class Loader [message #295343 is a reply to message #295225] Mon, 28 November 2005 12:45 Go to previous message
Are you having this problem when launching a runtime in PDE? If so... is
your java project in the workspace of the PDE? Are you making sure you
are passing the classpath of the java project to your plug-in?
just some thoughts.
-H
Raghavendra wrote:
> Regards
> Vaidya
Previous Topic:Add a toolbar item to the global toolbar (programmatically)
Next Topic:Update: Site is not Updateable
Current Time: Mon Jul 21 21:30:20 EDT 2025
Powered by FUDForum. Page generated in 0.05160 seconds
