Home » Eclipse Projects » Eclipse Platform » Seeing builder output
Seeing builder output [message #294662] Tue, 15 November 2005 16:19 Go to next message
Originally posted by: berman.namreb.com
I have a project with multiple builders. When a build runs the console
is cleared after each builder so it is hard to see what happens in a
complete build. Is there a way to see the output from all the builders.
Thanks.
--Len
Re: Seeing builder output [message #294728 is a reply to message #294662] Wed, 16 November 2005 18:32 Go to previous message
Set the console preference to not remove terminated launches on completion:
Window>Preferences>Run/Debug>Launching>Remove terminated launches when a new
launch is created
Then you can use the console drop down menu or the debug view to pick the
console you wish to view.
HTH
Darins
"Len" <berman@namreb.com> wrote in message
news:dldjc2$gbn$1@news.eclipse.org...
> Thanks.
> --Len
Previous Topic:Problem with Help Plugin
Next Topic:All you Testers out there
Current Time: Wed Jul 16 01:32:17 EDT 2025
Powered by FUDForum. Page generated in 0.07520 seconds
