Home » Eclipse Projects » Eclipse Platform » junit task doesn't work from eclipse IDE
junit task doesn't work from eclipse IDE [message #294258] Tue, 08 November 2005 06:43 Go to next message
Dear Members,
I don't know how to do in order to run junit ant task under eclipse IDE.
It works for me find invoking ant from command prompt. I have tried some
of the recomendation I have read on the Forum:
1. Adding junit.jar on the CLASSPATH.
2. Adding junit.jar on the ANT_HOME/lib location
Both solutions works for invoking junit task from command prompt, but I
have not found a solution for invoking junit task inside Eclipse IDE.
Please could you point me what to really do in order to invoke junit task
under Eclipse.
Thanks in advance,
David
P.D.: Invokation of other Ant task works
Re: junit task doesn't work from eclipse IDE [message #294271 is a reply to message #294258] Tue, 08 November 2005 12:00 Go to previous message
Window>Ant>Runtime>Classpath
Use Add JARs or Add External JARs depending on the location of your junit
JAR
HTH
Darins
"David" <achepati67@yahoo.es> wrote in message
news:78001f18af75986e01747c2997b45df0$1@www.eclipse.org...
> Dear Members,
> under Eclipse.
> Thanks in advance,
> David
Previous Topic:Formatting text in a TableViewer
Next Topic:Wrap long lines for Text Files?
Current Time: Thu Jul 17 22:34:37 EDT 2025
Powered by FUDForum. Page generated in 0.27726 seconds
