Home » Eclipse Projects » Plugin Development Environment (PDE) » P2 and source feature
P2 and source feature [message #29457] Mon, 27 October 2008 04:20 Go to next message
A source features which has been generated via generate.feature has the
same label as the containing feature. With the old update-site mechanism
this did not come to my attention since the old (3.3.) update manager does
not show the source feature. It is automatically installed with its
containing feature but it does not show up in the list of installable
features.
Now, with Eclipse 3.4, when I generate the p2 repository with the PDE
build and then update via this repository, the update manager also shows
included features which includes the source feature. This is quite
confusing because the source feature can not be discriminated from its
containing feature. Both have the same label and version.
How could this situation be handled? Is there a way to modify the label of
the source feature? Or could the p2 generation be modified so that the
update manager does not display included features? So far I have used the
following properties: generate.p2.metadata, p2.metadata.repo,
p2.artifact.repo, p2.metadata.repo.name,p2.artifact.repo.name, p2.flavor,
p2.publish.artifacts
Markus
Re: P2 and source feature [message #29607 is a reply to message #29457] Tue, 28 October 2008 11:23 Go to previous messageGo to next message
Markus,
You need to get the source feature generated with a different label.
The way to do this is for your normal feature to have its label
externalized: <feature id="foo" label="%label" >
The feature must include a "feature.properties" file that would have
"label=My Feature Label".
Then, you can contribute a different feature.properties (label=My
Source) to the generated source feature. Do this by having a directory
"sourceTemplateFeature" in the normal feature, the contents of this
directory will be copied into the generated source feature.
org.foo.feature/sourceTemplateFeature/feature.properties
/feature.xml
/feature.properties
-Andrew
Markus Barchfeld wrote:
> Hello,
> does not show the source feature. It is automatically installed with its
> features.
> of the source feature? Or could the p2 generation be modified so that
> the update manager does not display included features? So far I have
> used the following properties: generate.p2.metadata, p2.metadata.repo,
> p2.flavor, p2.publish.artifacts
> Thanks
> Markus
Re: P2 and source feature [message #30169 is a reply to message #29607] Wed, 29 October 2008 15:18 Go to previous message
Andrew, thanks for the detailed answer. It is exactly what I needed. There
was not much left for me to do wrong, but I found it: Make sure that
org.foo.feature/feature.properties is part of bin.includes in
build.properties
> Markus,
> /feature.xml
> /feature.properties
> -Andrew
>> Hello,
>> features.
>> Thanks
>> Markus
Re: P2 and source feature [message #583735 is a reply to message #29457] Tue, 28 October 2008 11:23 Go to previous message
Markus,
/feature.xml
/feature.properties
-Andrew
> Hello,
> features.
> Thanks
> Markus
Re: P2 and source feature [message #583823 is a reply to message #29607] Wed, 29 October 2008 15:18 Go to previous message
build.properties
> Markus,
> /feature.xml
> /feature.properties
> -Andrew
>> Hello,
>> features.
>> Thanks
>> Markus
Previous Topic:Why would pde build fail to jar sign 1 out of 6 plug-ins
Next Topic:Installed plugin application is unable to display icons and images
Current Time: Thu Jul 17 20:27:51 EDT 2025
Powered by FUDForum. Page generated in 0.05139 seconds
