Home » Eclipse Projects » Eclipse Platform » how to watch the return value
how to watch the return value [message #292733] Tue, 11 October 2005 15:49 Go to next message
Originally posted by: jzhang.informatica.com
While debugging, I often find it necessary to check the return value. Does
ecplise debugger provides someway to check the return value immediately
before the function return? Thanks a lot
Re: how to watch the return value [message #292736 is a reply to message #292733] Tue, 11 October 2005 17:16 Go to previous message
Originally posted by: automatic.javalobby.org
You can evaluate any expression in the debugger by highlighting it and pressing 'Display' (or 'Inspect') if you need an inspector. However, since this evaluates the expression again, if there is any state change that occurs then you might get weird behaviour.
You can also use 'watch' expressions, which are the value of an expression that gets updated as the stack trace is stepped through. Again, watch out for methods that have side-effects if you're using this.
I don't believe there's any way of finding out what the return value specifically is, unless you're in the caller stack and do 'evaluate' on the expression called after return.
Previous Topic:Access Restriction on API
Next Topic:ClearCase plug-in Eclipse for Eclipse 3.1.X - Windows
Current Time: Fri Jul 18 00:48:44 EDT 2025
Powered by FUDForum. Page generated in 0.02603 seconds
