Home » Eclipse Projects » Eclipse Platform » How do I get rid of unwanted and irrelevant menu items supplied by the platform by default?
How do I get rid of unwanted and irrelevant menu items supplied by the platform by default? [message #292639] Sun, 09 October 2005 17:44 Go to next message
Originally posted by: alextret.yahoo.com
While using GEF, I was quite successful in adding items to context menus
with minimal programming, by tweaking plugin.xml (added objectContribution
to
org.eclipse.ui.popupMenus extension point).
However, how do I get rid of unwanted and irrelevant menu items supplied by
the platform by default (in my case, it is "Run As", "Debug As", "Compare
With" and "Replace With")?
I should note that some of the menu items supplied by the platform, in my
case, are quite relevant and work just fine (specifically, Undo, Redo and
Delete).
Re: How do I get rid of unwanted and irrelevant menu items supplied by the platform by default? [message #292658 is a reply to message #292639] Mon, 10 October 2005 10:31 Go to previous message
Originally posted by: sunil_kamath.nohotspammail.com
> menus with minimal programming, by tweaking plugin.xml (added
> objectContribution to
> supplied by the platform by default (in my case, it is "Run As",
> "Debug As", "Compare With" and "Replace With")?
> in my case, are quite relevant and work just fine (specifically,
> Undo, Redo and Delete).
There is already a bug filed for this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=106007
Sunil
Previous Topic:Displaying detailed warning messages
Next Topic:Key Bindings
Current Time: Sat Jul 26 20:55:26 EDT 2025
Powered by FUDForum. Page generated in 0.04031 seconds
