Upgrading from 3.1 to 3.11 caused fatal error [message #292638] |
Sun, 09 October 2005 16:35  |
Originally posted by: rtb_il.yahoo.com
I just upgraded Eclipse from 3.1 to 3.11 using the update manager according
to the instructions on the site. However, since the upgrade was compeleted,
Eclipse does not start. I get an error log (appended hereafter). Can anyone
help??
Thanks, Ram
!SESSION 2005-10-09
12:36:38.572 -----------------------------------------------
eclipse.buildId=I20050401-1645
java.version=1.5.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2005-10-09 12:36:39.894
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: Upgrading from 3.1 to 3.11 caused fatal error [message #292651 is a reply to message #292649] |
Mon, 10 October 2005 06:40  |
Originally posted by: arne.anka.ginguppin.de
> qualifier or a tag,
normally it's called a "command-line argument", i think ;-)
> "eclipse.exe -clean"?
if it means that you started your eclipse like that, then you are right
> If so, I tried and it didn't change anything.
sorry it didn't work out. the trouble i had after upgrading was gone after
that.
FUDForum. Page generated in 0.05772 seconds
