Home » Language IDEs » PHP Development Tools (PDT) » How to run latest nightly?
How to run latest nightly? [message #29278] Fri, 15 June 2007 16:18 Go to next message
I'm sure this is a dumb question, but I've downloaded the latest nightly and extracted it into my eclipse 3.2.2. It's complaining about needing WST 2.0.0. I've searched for it, but can't find it. Is this something that's only available in the 3.3 release of Eclipse? Is it safe to run the latest nightly on the 3.3 release?
Any pointers would be appreciated.
Adam.
Adam Randall adam@lockdownnetworks.com
Senior Software Engineer (866) 844-8080
Lockdown Networks, Inc.
Re: How to run latest nightly? [message #29317 is a reply to message #29278] Fri, 15 June 2007 18:17 Go to previous messageGo to next message
> Adam.
I'm having exactly the same problem and posted a question, but there has
been no reply so far.
Good to hear that you have the same problem - was wondering if it is
just something on my workstation.
Would be good to hear if you find out something.
Iavor
Re: How to run latest nightly? [message #29354 is a reply to message #29278] Fri, 15 June 2007 19:04 Go to previous messageGo to next message
> Adam.
Just tried Eclipse 3.3 RC4 and noticed something... do not know if in
3.2 it is the same way, but in 3.2 I used to add the PDT remote site and
check to install everything from it. It seems wrong. Now I clicked on
the + to expand it and saw that actually it contains many different
versions of PDT. It seems one can install specific version and could be
that if all are installed just the last works. Kind of tricky.
Iavor
Re: How to run latest nightly? [message #29391 is a reply to message #29317] Fri, 15 June 2007 19:28 Go to previous messageGo to next message
On Sat, 16 Jun 2007 00:17:07 +0200
> > Regards,
> > Adam.
> Iavor
I downloaded and installed Eclipse 3.3R4 and installed the WST 2.0.0 from the Europa repository. After that, I installed the latest nightly of the PDT, which was not from the remote site but from the .zip file. After that, everything came up correctly. Subclipse also worked after I installed it, so that was a plus.
All in all, it's working, though syntax checking seems to be busted (who needs that? we all write perfect code, right? :)
I believe the Remote Archive url will only install the 0.7 releases, and not the 1.0.0 releases. YMMV.
Eclipse 3.3R4 (from the .tar.gz)
PDT 1.0.0 (N20070614)
Ubuntu Linux 7.04
JRE 1.6
Adam.
Re: How to run latest nightly? [message #29428 is a reply to message #29391] Fri, 15 June 2007 19:45 Go to previous message
> Ubuntu Linux 7.04
> JRE 1.6
> Adam.
Yes - I found out as well that the Update Manager has some weird
internal logic... So when PDT complains about something - I just get the
..zip and unzip it in eclipse/.
All fine so far.
And yeah - I'm would be happy if the syntax checking is busted... Spent
many hours in the past to try to switch it off ;)
Iavor.
Previous Topic:xdebug - oordering of variables
Next Topic:latest pdt-all-in-one win incomplete
Current Time: Tue Jul 22 01:50:50 EDT 2025
Powered by FUDForum. Page generated in 0.33687 seconds
