Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » problem line numbers are always 1
problem line numbers are always 1 [message #29252] Fri, 25 July 2008 15:12 Go to next message
The issue is that all problem line #s are always 1.
The problem is that
a) nobody calls DLTKToken.setLine (that can be fixed in a particular parser)
b) there is no method DLTKToken.getLine
c) There are line accessor methods in ASTNode, i.e. setLine and getLine
d) Therefore, there is no line number data available to call
IProblem.setSourceLineNumber and/or
to set the IMarker attribute LINE_NUMBER.
Chuck
Re: problem line numbers are always 1 [message #29290 is a reply to message #29252] Mon, 28 July 2008 00:28 Go to previous messageGo to next message
Hi Chuck,
- DLTKToken is deprecated and will be removed at some point.
- abstract ASTNode contains no line/column numbers, only offsets - since
offsets are the most essential information when parsing source code.
Additional fields would increase memory usage, but add only the minimal
utility value.
- line number can be easy calculated from offset using standard
org.eclipse.jface.text.DefaultLineTracker, also there is similar class
org.eclipse.dltk.tcl.core.TclParseUtil$CodeModel
Alex
> The problem is that
> Chuck
Re: problem line numbers are always 1 [message #29328 is a reply to message #29290] Mon, 28 July 2008 10:29 Go to previous messageGo to next message
Well - the problem is that in the default Problems view, every
problem/marker appears to be on line number 1. If you don't want to maintain
line numbers in the AST Node and/or DLTKToken, then perhaps the code that
creates the problem markers could be changed to recalculate the line
numbers.
Chuck
"Alex Panchenko" <alex@xored.com> wrote in message
news:g6jhq6$gff$1@build.eclipse.org...
> Hi Chuck,
> utility value.
> Alex
>> The problem is that
>> parser)
>> Chuck
Re: problem line numbers are always 1 [message #29366 is a reply to message #29328] Mon, 28 July 2008 12:39 Go to previous message
DLTK collects problems via IProblemReporter.
IProblemReporter accepts IProblem instances.
IProblem instance should be created by the language developer and should
contain offsets and correct line number. IMHO it is the language
developer responsibility to provide correct line numbers.
Please see how it is implemented in Ruby or TCL.
Alex
> numbers.
> Chuck
>> Hi Chuck,
>> utility value.
>> Regards,
>> Alex
>>> The problem is that
>>> parser)
>>> Chuck
Previous Topic:[BUILD] R1.0-I
Next Topic:[BUILD] R1.0-I
Current Time: Tue Jul 22 01:51:05 EDT 2025
Powered by FUDForum. Page generated in 0.08260 seconds
