CVS Syntax Sensitivity Suggestion [message #29245] |
Fri, 27 January 2006 00:35  |
If this is the wrong newsgroup for this posting I apologize, and will
change as requested.
When editing and reformatting xml under eclipse, I find that instead of a
few small overlapping changes to be reconciled, there are huge segments
of the document identified as having overlapping changes, and it is almost
impossible to see what the significant, as opposed to formatting, changes
are.
It seems that reformatting overwhelms the line by line differencing of
CVS.
The net result of spurious differences is that I'm loosing work when I
make
bad synchronization choices.
I can see a fix for this problem, although not
a fast fix. The basic idea is to embed syntax sensitivity into the
CVS plugins and leave CVS as is.
Assume that the CVS plugins were modified to permit
syntax-specific handling of xml and java, such that text delivered to
CVS is normalized to 'white-space normal' form and automatically
re-formatted from 'ws-normal' to 'current coding-style' when retrieved
from CVS.
No changes would be made to CVS, which would only
ever see ws-normal form, so that trivial differences due to indents
and other white-space coding would no longer be detected by CVS.
Is this a feasible approach, or have I missed some huge conceptual
obstacle? Feedback requested,
Bill.
Re: CVS Syntax Sensitivity Suggestion [message #29286 is a reply to message #29245] |
Fri, 27 January 2006 07:03  |
--------------010105080304030507060205
Bill,
Auto reformatting of files is something that would make me personally
very unhappy. You might find that this preference setting will make you
happier:
> of a few small overlapping changes to be reconciled, there are huge
> segments of the document identified as having overlapping changes, and
> it is almost
> changes are.
> CVS. The net result of spurious differences is that I'm loosing work
> when I make bad synchronization choices.
> I can see a fix for this problem, although not a fast fix. The basic
> from CVS.
> Bill.
Content-Type: multipart/related;
boundary="------------070300060608050408090000"
--------------070300060608050408090000
<html>
<head>
http-equiv="Content-Type">
</head>
Bill,<br>
<br>
happier:<br>
<blockquote><img src="cid:part1.07070107.08050506@ca.ibm.com" alt=""><br>
</blockquote>
<br>
Bill Winspur wrote:
<blockquote cite="midabbecf231673a9046d0062285e0f524a$1@www.eclipse.org"
type="cite">If this is the wrong newsgroup for this posting I
apologize, and will
<br>
<br>
<br>
it is almost
<br>
changes are. <br>
when I make bad synchronization choices. <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
from CVS. <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Bill.
<br>
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-15.jpg"
Content-ID: <part1.07070107.08050506@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-15.jpg"
/9j/4AAQSkZJRgABAQIAJQAlAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CACrAdsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDq/F3j2Xw34kOlxaVBcL5P nmVnVAg3suMb
GJ6D86xx8Vrg9NIsf+//AP8AaapfECGO4+KUUM3+qktI1fnHBuTmpfEmqWUo S3MYtUgXYI0m
iUY+hIr0qVClyRbje67v/Mi71bYt58YLiyRXfQrZ1Y4yk44P4xCqg+OEn/Qv Rf8Af9f/AI3X
NWMVpdeKNAh2rPbS6pbo6SmORXBcAg7SQR2wa6ybR/C/iLxXH4WmNsL46zeY k0q1Fsbe1SNi
sTkxqrNvUc4fgN83PN1KGHi/h892Zuc76MhHxuk/6F+L/v8AL/8AG6d/wu2T /oX4v+/y/wDx
usPSvC/hGfQpNevdUv4tN/tCOxQy/unB8kPI+EjlySSdq8AAcvk10dnodnqv h/wZ4atNQuUs
dSu9Qae5t/3S3UcUhIZ4yOWIRNpYnZjo3aZUsOvs/n2uSp1H1IR8a5P+gBF/ 3+X/AON0o+NU
h/5gEX/f5f8A43WRY+FPCGqSXTWWsXkiWuk3N5cJCDIYXjZdpDPHFvUqx+XC kFfvc5p0PhXw
hHoVjql/rF5Z2+qSXf2V5AS8SRttTciRsJGzgt86DnjOKPY4f+V/iLnqdzWH xok/6AMX/f5f
/jdO/wCFzyf9AGL/AL/L/wDG6zJPA+jnTwkMl8l7/wAI2uuGZ5UaPdxuj2BA cHnB3cZHBxyr
eCNH/wCFiW3g1JL4Sqym4vTKhWRfJ81gkez5CTwCWbHoaPZYbt+f+Y+ep3NP /hcsn/QBi/7+
r/8AG6UfGST/AKAUX/f1f/jdYlpoHgu91a0hi8ReXHJbzNLHLIyqJl+4vnvC gUMDnJjONhHJ
YVz/AIk0ltC8RXmmNA8BgYLsecTHBUEHeFXIIOR8oIBwRkVUcPQbty/mS6lR K9zvB8YpD/zA
ov8Av6v/AMbpR8YZP+gHF/39X/43Xlwp4q/qdHt+LF7afc9QHxfk/wCgHF/3 9X/43Sj4uyH/
AJgkX/fxf/jdeYinCj6nR7fiw9tPuem/8Lck/wCgJF/38X/43Tv+Ftyf9AWL /v4v/wAbrzMU
4UvqlHt+LD20+56WPizJ/wBAWL/v4v8A8bpR8WJP+gNF/wB/F/8AjdebCnCj 6pR7fiw9tPue
kf8AC1pP+gNF/wB/F/8AjdKPirJ/0Bov++1/+N15yKcKPqlHt+LD20+56MPi nJ/0B4v++1/+
IpR8UpP+gPF/32v/AMRXnYpwo+qUe34sPbT7noY+KEn/AECIv++1/wDiKcPi dIf+YRF/32v/
AMRXnopwpfVKPb8WHtp9z0EfE2T/AKBMX/fa/wDxFKPiXJ/0CYv++l/+IrgB TxR9Uo9vxYvb
T7nff8LKk/6BUX/fS/8AxFL/AMLIk/6BUX/fS/8AxFcEKcKPqlHt+LD20+53 n/Cx5P8AoFxf
99L/APEUo+I0n/QLi/76X/4iuFFOFL6rR7fmHtp9zuR8RJP+gXF+a/8AxFOH xCkP/MMi/Nf/
AIiuHFOFH1Wj2/MPbT7nb/8ACwZP+gZF+a//ABFKPH8h/wCYbF+a/wDxFcUK cKPqtLt+Ye2n
3O0Hj6T/AKBsX5r/APEU7/hPJP8AoHRfmv8A8RXGCnCl9VpdvzD20+52Q8dy f9A6L/x3/wCI
pR45k/6B8X/jv/xFceKcKPqtLt+Ye2n3Ov8A+E4k/wCgfF/47/8AEUo8bSf8 +EX/AI7/APEV
yQpwo+q0u35h7afc60eNZP8Anwi/8d/+JpR4zkP/AC4xfkv/AMTXKCnil9Vp dvzD20+51I8Z
Sf8APjF+S/8AxNOHjCT/AJ8YvyX/AOJrlhTxR9VpdvzD20+5048Xyf8APlF+ S/8AxNL/AMJb
J/z5Rfkv/wATXMinCj6tS7fmHtp9zpf+Esk/584vyX/4mlHiqT/nzi/75X/4 mucFOFH1al2/
MPbT7nRjxTJ/z6Rf98r/APE0v/CTyf8APpF/3yv/AMTXPCnCl9WpdvzD28+5 0A8TSf8APrF/
3yv/AMTTh4kkP/LrF/3yv/xNYAp4o+rUu35h7ep3N0eI5P8An2i/75X/AOJp R4hkP/LtF/3w
v/xNYYp4o+rUu35h7ep3NoeIJP8An2i/74X/AOJp39vSf8+8X/fC/wDxNYop wpfVqXb8w9vP
ubI12T/n3i/74X/4ml/tuT/nhF/3wv8A8TWQKdR9WpdvzD28+5hePvC3iDV/ Gb32l6VLeWv2
byHdJEXawlZsYYjPGPzrAvvBXjDUljF54euptgwGMkIbHuQ+T+Ne+2H/AC9f 9fD/ANKztS8Z
eHtHvnstQ1OO3uEALRsrZAIyOgrCnjKkIqKS08jr5fM8GuPAHjQLb/YdAure SCQSRyJPGpQj
oVIbg55zVeH4ffEW31E6jDp99HfFmc3KXaiUs2dx3B85OTk98mvdv+Fi+Ev+ g3B/3y/+FH/C
xfCX/Qbg/wC+X/wq3jqj1aX9fMh0k3ds8O07wL8SdI8z+zbTUbLzceZ9mvFj 34zjO1xnGT+d
Ok8DfEiaSCSW01GR7eRpoWe8UmJ2bczKd/DFuSRyTzXt/wDwsXwl/wBBuD/v l/8ACj/hYvhL
/oNwf98v/hS+uz3sv6+YvYx7s8Yn8J/FG6z9oXV5sxvCfMvw2UbG5eX+6cDI 6HApth4O+Jel
wGDT4NUtIWbeY7e9EalsAZwHHOAPyr2n/hYvhL/oNwf98v8A4Uf8LF8Jf9Bu D/vl/wDCl9cn
a1l93/BH7GPdnio8E/EX/n01H/j2+yf8fa/6j/nl9/7n+z09qlbwf8SXgtoH g1NorVle3jN6
CsLKMKUG/wCUgdMdK9l/4WL4S/6DcH/fL/4Uf8LF8Jf9BuD/AL5f/Cj65Psv 6+YvYx7s8hPh
v4pGdZmbWTKilFc6h8yqSCQDv6HaufoPSs6X4deNbieSafSLiSWRi7u8yMzM eSSS3JJr2/8A
4WL4S/6DcH/fL/4Uf8LF8Jf9BuD/AL5f/ChY2a2S/r5h7GPdnh4+GvjD/oCS /wDfyP8A+Kpw
+G3i/wD6Akv/AH8T/wCKr27/AIWL4S/6DcH/AHy/+FH/AAsXwl/0G4P++X/w p/XqnZf18w9h
E8THw38Xf9AWX/v4n/xVOHw58Xf9AWX/AL+J/wDFV7V/wsXwl/0G4P8Avl/8 K1tI17TNeill
0u7W5jiYK7qrAAntkjrR9eqdl/XzD2ETwEfDrxb/ANAWX/v4n/xVOHw78Wf9 AaX/AL+J/wDF
V9HUUfXanZf18w9hE+cx8PPFn/QGl/7+J/8AFU1/AfiaJgsmlsjEFgGljBIB AJ+97j8xX0dW
HrX/ACEIP+vSb/0ZDSeNqdl/XzD2ETw0eCfEX/QP/wDI0f8A8VSjwV4h/wCg f/5Gj/8Aiq9e
oqfr9Tsv6+Y/q8TyMeC/EH/QP/8AI0f/AMVTh4M8Qf8APh/5Gj/+Kr1qij6/ U7L+vmH1eJ5O
PBuv/wDPh/5Gj/8AiqcPB2vf8+H/AJGj/wDiq9Woo+v1Oy/r5h9XieVjwfr3 /Pj/AORk/wDi
qcPCGu/8+P8A5FT/AOKr1Kij6/U7L+vmH1aB5ePCOuf8+P8A5FT/AOKp3/CJ a5/z5f8AkVP8
a9OopfXqnZf18w+rQPMh4T1v/ny/8ip/jTh4U1r/AJ8v/Iqf416XRR9eqdl/ XzD6tA82HhbW
v+fP/wAip/jTh4X1n/nz/wDIqf416PRR9eqdl/XzD6tE86HhjWP+fP8A8ip/ jTh4Z1j/AJ8/
/Iif416HRR9eqdkH1aB58PDWr/8APp/5ET/GlHhvVv8An0/8iJ/jXoFFH16p 2QfVoHAjw5q3
/Pp/5ET/ABpw8O6r/wA+v/kRf8a7yij67U7IPq0DhR4e1T/n1/8AIi/404eH 9U/59f8AyIv+
NdxRR9dqdkH1aBxI0DU/+fb/AMiL/jThoOpf8+3/AI+v+NdpRS+u1OyD6tA4 0aFqX/Pt/wCP
r/jThomo/wDPv/4+v+NdhRR9dqdkH1aByI0XUP8An3/8fX/GlGjah/z7/wDj 6/411tFH12p2
QfVoHKDRr/8A54f+Pr/jThpF9/zw/wDH1/xrqaKPrtTsg+rQOYGk33/PD/x9 f8acNKvf+eP/
AI8v+NdLRR9dqdkH1aBzg0u8/wCeP/jw/wAacNMvP+eP/jw/xroaKPrlTsg+ rQMAabd/88v/
AB4f40o066/55f8Ajw/xreopfXKnZB9WgYY0+6/55f8Ajw/xpwsLn/nn/wCP Ctqij65Psg+r
QMcWNx/zz/8AHhS/Yrj/AJ5/+PCteij65Psg+rQOjsP+Xr/r4f8ApWHo3/JQ PFP/AFysv/QZ
K3LD/l6/6+H/AKVh6URD478TSykJG8dmqu3AYhHyAe5GR+YrBGpY8NeLbLxH p2mzJHPbXV9a
G5FvNBIuAojL7WZVDqDMgDDhs8ZwcFl410HUJ4ora6ndZfKCzGzmWEGVEeNT KUCKzLImFJBJ
dRjJArFu/DSSeHNJ8Oy3NteWdtcLAk6nymgs1geNg43/ALx3jLQll2487eFB SpF0a8u9e1hr
nUbODSJ9Vtr5IhGGmlMMVuVIk8zCr5kOCpQkhWwRuBDA6LTfEOmatcNBZzyM 4QyIXgkjWZAQ
C8TMoEqcr8yFh8y8/MM8ne+Prq20nXb5EgDW0t5b2sE1pOg328dy2fNxsm3G 33ELs2AkFi2N
17wp4S03wtcB4JtICRW/2aF7awjhnkTK8zy5Jkf5F5XYCSxKn5dseq+ELbU/ Dx0n+2Yos3eo
XPm+WG/4+kuV243fw/ac5zzs7Z4ANKy8aafPa3c1xFdwPbXs1n5a2s0hmZJZ EHlbU/ekrEzk
Ju2DOehNXLTxTo19qMOn2155l5LF5ywCJw6pl1JYEfJtaN0bdja2FbDMoODf +Era+s3s5NQ0
ye1i1CTULSG9sxOiySmUyCZfMAlXM7lANhXC5LYOdDw9oVnoF1LNHe2e2W0h tzDbwJBGhSWe
QlFU4CkzkAckBeWYkmgCZPFtkup61ZXUc8H9mSpGZRBI6Sho4mUKwXaZC0wU RAlzgYBzirEX
inRpIlke8+zqfMDfa4ntzGUUOyuJAuxth3hWwSgLAFQTWTqvhu21P+14G1Kz NjqUsV3JBPAJ
f9Ii8oLk7wGhIgQNHjJy3zjIAjtfCtrDpa6f/aOn2kBuPtcsel2UVqnnLsMT IuWwFZFcht5Z
gMnYDGQDW0fxNBrGrajp6Wt3E9m6bXktpVV0aGKTJZkAR/3uPLJ3Dbkgdtys HS7R9P1O8upN
Vs5Y77ZNcxrFtJuBHHGWRt52xlYh8hDEEk7yOK2Ptdt/z8Rf99igCaioftdt /wA/EX/fYo+1
23/PxF/32KAJqhX/AI/Jf+uafzaj7Xbf8/EX/fYpsUiS3crRurjYgypz3agC xRRRQAVh61/y
EIP+vSb/ANGQ1uVh61/yEIP+vSb/ANGQ0nsBmVhS+J4/7avdKsdMvtQubJY2 ufs/lKsRkBKj
MkiZJAzxkc9c8Vu1x1vZ6ponjfxFqa6Tc39rqi2rQtayQgoY0KMGEjpznBGM jB69qgo2n8U6
BFBbTT6zY263UC3EIuJ1iZ42GVbaxBwfpU8uvaPBqA0+bVrGO9LKgtnuUEhZ sbRtJzk5GPXI
riLrRPEUE/i15dL+2z69p0ESyWMsYijmWBo3BErqwXccjAPB9eKyLnwJ4gTw 74p0+OzSaa6t
NKgtmSZAszQIiyY3EYAKn72M07AenQ69o9xBHPBq1jLDJOLdJEuUZWlIyIwQ eWI7dafbaxpl
5Yy3trqNnPaQ582eKdWjTAydzA4GAcnPavKvGmjXdv4snv7vT/tFjqGvaUII 90bfaQkMium0
nA5OPmwDn0rbn0bxM+p6/rFnp/2caje2B+zytA9yIYVG90BLRB92Cu4/wk8H bRYDt4de0e4g
jng1axlhknFukiXKMrSkZEYIPLEdutMl8SaFDawXUutadHb3G7yZXukCSbTh tpzg4PBx0rzS
fwbr+peILi7u9NuZ7W41jTp3+3yWxd4Io5FlLrGdhA3AYA5B6Hmug1Pwzfaf 40ttT0W1ubfT
l0s2fl6QLVHjfzvM5WYBNp3E5XnI7dywHaTajZwaXJqb3CGyjgNwZk+dTGF3 bhjORjnjrWK/
ix4tUttHfRL6XVZLBb6W3t5IWWFS20rvd1BIbjjr1rP0TR0srTSPDEUc0drY /wDEwuUnlWSQ
Ays0CMVAG4uC5K5AMO0lgwJff+H9Uu/iWuqwXNzZWQ0f7Mbq3MJYyecW2bZF bjHOdvbr2pAa
9j4s0W98PWmuG/htbG64je7cRfNyCh3HG4FWHBPQ4yOah1LxroWlanpdldX0 K/2jG00U/moI
kQLkMzFhhW6KRkEg1iyeH9T8P3GlWGhw3n9jWllJGJLL7M135zSKzb2uPl2N jOEx8w5GAuMj
QvC2u6Pp/gm5m0x5ZtHa+W6tYpovMAm3bCpLBCOmfmzyODzhgeif2xpn9p/2 Z/aNn/aH/Pr5
6+b93d9zOenPTpzWR4W8Y2HiTSdPuZJLazvb1XeOxa5VpCqu65A4LD5CenY+ lZ/h/S9S0i+1
myutH+0wX2tSahFdGWPyFRijAkE796leAExuA5A+YYWmeDdXtPBHhKw/s1I7 2z1yO9vlWSPI
RXky5IOGO0oOCTjA7UgPUaKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFAHR2H/L1/18P/SrlU7D/l6/6+H/AKVNd3KWdnPdSBik MbSMF6kAZOPy
q0QTUVlz6vNbW8txNpF8sUSF3bdCcADJPElaE88Nrby3FxLHDBEheSSRgqoo GSSTwABzmmBJ
RWPa68Z/PmutKvtOsIomm+3XxhjjKDnJXzDInHzfOq4AO7B4om8WeG7eztry bxBpUdrdbvs8
z3sYSXacNtYnDYPBx0oA2KKpyatpsOqQ6XLqFomoTJvitGmUSuvPKpnJHyty B2PpVebxLoNt
ZC9n1vTYrQuqCd7pFQsyCRRuJxkoQwHcEHpQBqUVn6dqf2++1a28ny/7Pu1t t27PmZhil3Yx
x/rcY5+7nvgaFABRRRQAUUUUAFFFFABRRWHd3ckMuBlsljzI4/jYdiPSk3YD crD1r/kIQf8A
XpN/6MhrMudbd9Hmu7SVWVrdpIpo5WYEbcqwO4gjofSmWjtd6FoEly0kzy6M HkZpGDOxNuSS
wIOc+9F7oY+io/str/zxk/8AAqf/AOLo+y2v/PGT/wACp/8A4uoGSUVH9ltf +eMn/gVP/wDF
0fZbX/njJ/4FT/8AxdADbmztbzyvtVtDP5Mgmi81A2xx0Zc9GGeCOamqP7La /wDPGT/wKn/+
Lo+y2v8Azxk/8Cp//i6AJKKj+y2v/PGT/wACp/8A4uj7La/88ZP/AAKn/wDi 6AJKKj+y2v8A
zxk/8Cp//i6Pstr/AM8ZP/Aqf/4ugCSio/str/zxk/8AAqf/AOLo+y2v/PGT /wACp/8A4ugC
Sio/str/AM8ZP/Aqf/4uj7La/wDPGT/wKn/+LoAkoqP7La/88ZP/AAKn/wDi 6Pstr/zxk/8A
Aqf/AOLoAkoqP7La/wDPGT/wKn/+Lo+y2v8Azxk/8Cp//i6AJKKj+y2v/PGT /wACp/8A4uj7
La/88ZP/AAKn/wDi6AJKKj+y2v8Azxk/8Cp//i6Pstr/AM8ZP/Aqf/4ugCSi o/str/zxk/8A
Aqf/AOLo+y2v/PGT/wACp/8A4ugCSio/str/AM8ZP/Aqf/4uj7La/wDPGT/w Kn/+LoAkoqP7
La/88ZP/AAKn/wDi6Pstr/zxk/8AAqf/AOLoAkoqP7La/wDPGT/wKn/+Lo+y 2v8Azxk/8Cp/
/i6AJKKj+y2v/PGT/wACp/8A4uj7La/88ZP/AAKn/wDi6AJKKj+y2v8Azxk/ 8Cp//i6Pstr/
AM8ZP/Aqf/4ugCSio/str/zxk/8AAqf/AOLo+y2v/PGT/wACp/8A4ugCSio/ str/AM8ZP/Aq
f/4uj7La/wDPGT/wKn/+LoAkoqP7La/88ZP/AAKn/wDi6Pstr/zxk/8AAqf/ AOLoA6ew/wCX
r/r4f+lGrQSXOjX1vCu6WW3kRFzjJKkAc0WH/L1/18P/AEq5Vok4+70tJpL5 7ew1w300Un7u
XV2eJTIrKCYjOUC5zgbcDHA4roNS0e31TSNQ02Z51hv7eS3lZZSWVXDAld2Q D85xx6DoAKsI
2dRmXd0ijO3d05fnG72/ujp1OMLYpgef6r4T8Ra3fzSXc0EMPlIWWDVboJdS xzwSRsIsYtci
FxujZ2Xzc5cjJ0PD/hW60zXIdTlSCLdFdCeMXs92++T7KFJlm+Z/ltjk4XGV UA4LHYv9XEbS
xC2n2w3EUTTeZGil2KFUG6RSS29VHqWxg9Desr0XgmBglgeGTy3SXbkHarfw kjow70AcDovw
9vtNbT4rgwXEafYZZ5BqVyiRyW8UKYW2XEcuTAGDuQRuGVYIA2hF4S1PT/CX h/SbLyCthaCK
6tYL+awSWbauZRNCu84YSfKQA3m7jyoroNQ8SWem65YaVLHO8l3ndNGoMVtn iPzmz8nmNlE4
+ZgQOakTxLoMlxd26a3prT2SO91Gt0haBUOHLjOVCngk4x3oAy/Avhu88MaP JZ3skEkjfZ8G
FiR+7tIIG6gfxQsR7Ed+B1FZcfiXQZtLm1SLW9NfT4X2S3a3SGJG44Z84B+Z eCe49akl13R4
fsPm6rYx/wBoY+xbrhB9pzjHl8/PncvTP3h60AaFFZ82u6PbwXE8+q2MUNtj z5HuEVYsu0Y3
En5fnRl5/iUjqDUb+JdBjuLS3fW9NWe9RHtY2ukDTq5whQZywY8AjOe1AGpR We+u6PHeXVnJ
qtil1aRGe5ha4QPDGACXdc5VcEHJ45FWLG/s9Ts47ywu4Lu1kzsmgkEiNgkH DDg4II/CgCxR
RRQAVwHjS0sNcs5tIudYksUk3LP9mnRJGXc3yHcDgEEZ6ZHHQkHv647UND0Q 3kksuh6dNLK7
u8kkALMxduSaTGjkdG0bSvCvhy902x1ue6t2jcxQ3NxG/lkg5CbVBGSc45Ge Rgk56zTf+Rd8
Of8AYEH/ALb1n3+j6JFp11JHoGlJIsTsrC2BwQDg88Voab/yLvhz/sCD/wBt 6S2AkqRIcqGe
RIwem7PP5A1HU03+qt/+uZ/9CapKDyY/+fmL8m/+Jo8mP/n5i/Jv/ia5XU9d ljuLoR6ppelW
1nOttJPqSFhLK0ayYX94gACsO5JO7gBctDcfEHRLe8vbZndmtFnJ2SRMztCr M6CPfvBAR+WV
VO3g8rkEdh5Mf/PzF+Tf/E0eTH/z8xfk3/xNcreeM7LTYJDqVrc2VyrIotri SFWYOHKnf5nl
gHypPvOD8mMZK5n0rxZYa1dxW9jFcy74BO0qqpjjXdIhy4JUkPEy/KTnIK7l DMADo/Jj/wCf
mL8m/wDiaguZbe1MAe5jLTyiGMANy5BwORjnGB6kgdTXJ2njK21rUdMg06TY Te+XdReZDNmM
287r80bOoy0XTcG+XkYIzo+J/wDUaZ/2E7b/ANDFAHRfZLn/AJ95f++DR9ku f+feX/vg1har
rj6XeWlsNJvrs3TeXE9u0IUvtdyvzyKQdqMc4x754q0+saZHdXFq+o2a3FtG Zp4jOoeJAASz
DOVXBByeORQBp/ZLn/n3l/74NH2S5/595f8Avg1jap4h0zRpreO/u4YPOkEZ aSRVEWUkZWck
jCnymAPc8euJtQ1JLHy41gmurqXPlW0G3zHAxuPzEKFGRksQMkDqyggGn9ku f+feX/vg0fZL
n/n3l/74NZI1m0iS0GoOmm3N2xSG1u5o1kdgcYG1iGPI6E/eHfiga9o7TvAN WsTMk627Ri5T
cspJAjIzwxKtgdeD6UAa32S5/wCfeX/vg0fZLn/n3l/74NZltrGmXl9LZWuo 2c93DnzYIp1a
RMHB3KDkYJwc96ZFr2jz2hu4dWsZLYMyGZLlCgZVLsNwOMhQWPoAT0oA1vsl z/z7y/8AfBqN
43ibbIjIeuGGKppqVhLqEunx3ts97Eu+S2WVTIi8clc5A+YfmPWs5mZfHEaB iFfTWLAHhiJF
xn1xubH1PrQBt0UUUDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigD
o7D/AJev+vh/6VcqnYf8vX/Xw/8ASrlWiCujZ1GZd3SKM7d3Tl+cbvb+6OnU 4wtiq6NnUZl3
dIozt3dOX5xu9v7o6dTjC2KYHF+JtA/tVp47mHUkj/tC3uIprW88pWCmDKlR MmWJi2qSCVJD
LzW5pFg0YuDLDdwL5q+Us1yXcqscS5Zg7bjmPqxJPOfvHOheNtgU7tv72MZ3 Y6uox94fz59G
6GxQBw+veC9W1e81zUIdentbqb7P/Z0UYi8lfs4EkPm7ombi4MjHBOVIHsMP VNB17UvB2sQP
p8cUFpca1dWoR3e4umk+1xonleWAoIn3BgzZAXA+bI7y+14295Ja2OlX2qzQ 4FwLMwgQEgFV
ZpZEG4g52gkgFSQAy5sPrujx3l1ZyarYpdWkRnuYWuEDwxgAl3XOVXBByeOR QByeqeE9Z1u/
/tm7jtILyJ4BHZWupTxq6xpcrk3KIroT9qJwEP8AqwM4c7aeseBdaufDkmlW bQGOe0nj8g6v
dwJbTSvI7uzAO11nzFB83A/dkgASFV7SPxLoM2lzapFremvp8L7JbtbpDEjc cM+cA/MvBPce
tUx4x0ceIV0mXULGLz7S2ubKVrtB9r855FCxj+L/AFanIJzvH4gGf/wi9/a6 DPa2TQJPPqt1
fXMcNzJa/a0klkZVaeNfMRgGiJKg58rZ905rL0/wLqtv4d8R2Mslos+q6ZLa xD7TJMI3ee8k
G+R1DMALlAWIJJDHHTOxeePLKwuNSWe1kMFjbtMzxzxMz7Td71C78EgWbcAl vm+ZV2tjUTxT
ojwTXQ1Sx+wRRRyte/a4jDh3eMfMG4+ZCMkAE8AkhgADDu/DGq3Gj3+iYtPs bXrahBcreSRS
yObsXXlMFTMQyWTzFdiMBguflGx4X0aXR7K5E8UcU91cGeRFvJrsg7EQbppj uc4QdlAGFwcb
muS67o8P2HzdVsY/7Qx9i3XCD7TnGPL5+fO5emfvD1rQoAKKKKACuc1H/Xj/ AIH/AOhtXR1z
mo/68f8AA/8A0NqmQ0ZOp/8AIKvP+uD/APoJqbTf+Rd8Of8AYEH/ALb1Dqf/ ACCrz/rg/wD6
Cam03/kXfDn/AGBB/wC29C2GySppv9Vb/wDXM/8AoTVDU03+qt/+uZ/9CapG c/q/huHVo7uN
b68skvYzFdra+XicFduWDo2G28blwSMAk7Vwy48LW9xBe2rX98tldrODao6q iNMG3uDt3Eku
5wxZQWyBwuN2igDIvvD9ve6g2oC5ube8CxLHNEVzEU80AqGUgkrPIp3AjBGA CM0J4dsyl4tz
Lc3YvbRbS58+TJkQGQk5GMEmZ+mABgKFAxWvRQBhW/hiOPVo9TudTvr26jZG Vp/KUAKkyAYS
NeMTufXOOeMUvif/AFGmf9hO2/8AQxW5UNxaQXfk+fGH8mVZkBJ4dTlT789j xQIq6jYS3d9p
E8bIFs7tp5AxOSpglj498yD8M1hWnhi7sdXe6SOGcRXNzeQPLqFxhnl8whfJ /wBXHjzSpcby
QCduW+Xs/tMn92L/AL9L/hR9pk/uxf8Afpf8KAOPh8OX+nxWwtBYzNZ3f2yI HdAJWaKSJozg
PtVA42EbsIqx4+XedfUrK6a+ttTsBDJd28ckIhncpHIkhQt8wBKsDGpBwRgE Y5DLs/aZP7sX
/fpf8KPtMn92L/v0v+FAHH6lo2sakl+WisYm1WwFhcgXLsLZQZcOh8seaSJi dp2YK4yc5EF3
4Tv57G7gWW2DTWmrQKSzYDXU4kjzx0AHzeh6Zrt/tMn92L/v0v8AhR9pk/ux f9+l/wAKAOFs
tI1q9h8v9zpyWuo6hcW1ySZJSzvcIhMTIFC/vt4O45Cjj5shll4QvT4gt9Qv YbZYIp4JfKk1
Ca9bMcdyAwaVQQQ00ZA6DaT16979pk/uxf8Afpf8KPtMn92L/v0v+FFwOP07 wvPZ68LmQI8E
d3cXcczX07HdKZDtFvkRoR5pG/LZAPALZW8//I9w/wDYMk/9GpXRfaZP7sX/ AH6X/Co96mcT
+Rb+cF2CTyE3bc5xnGcZA4oAbRU32mT+7F/36X/Cj7TJ/di/79L/AIUDIaKm +0yf3Yv+/S/4
UfaZP7sX/fpf8KAIaKm+0yf3Yv8Av0v+FH2mT+7F/wB+l/woAhoqb7TJ/di/ 79L/AIUfaZP7
sX/fpf8ACgCGipvtMn92L/v0v+FH2mT+7F/36X/CgCGipvtMn92L/v0v+FH2 mT+7F/36X/Cg
CGipvtMn92L/AL9L/hR9pk/uxf8Afpf8KAIaKm+0yf3Yv+/S/wCFH2mT+7F/ 36X/AAoAhoqb
7TJ/di/79L/hR9pk/uxf9+l/woAhoqb7TJ/di/79L/hR9pk/uxf9+l/woAho qb7TJ/di/wC/
S/4UfaZP7sX/AH6X/CgDdsP+Xr/r4f8ApVyqdh/y9f8AXw/9KuVaIK6NnUZl 3dIozt3dOX5x
u9v7o6dTjC2Kro2dRmXd0ijO3d05fnG72/ujp1OMLYpgV7xtsCndt/exjO7H V1GPvD+fPo3Q
i2cS7cPP8uMZnc9Nvvz90fXJ/vHJeNtgU7tv72MZ3Y6uox94fz59G6GxQBz8 tlrGl6nf3WjW
1jeR6jKtxPHeXT25ikWNI/lZY33KVjTggEEMcsGAXj/GnhLX7631K6/4/Fii v5Udb+dnlWS1
njjiS0C+UrL5qLuU7m2EnlyK8ks9Z8UT2qXN543vNNilz5Bur26JmAOCyiNX O0EYyQASCASV
bECaz49ktba6TUvErW91KIbeVZ5yk0hJAVDnDNkEYHPBru+pP+Yw9sux79ea D4h1C4u9Sk+y
W1xOlvA9ja6jMizRRGZhm5WNZIyWnDfKh/1QUkhztx7PwR4httO1XTtmm+Rr FlJZzytqE0r2
oe4u5NyloszkLcr95kLFTkjOa8cl1P4hQOEmvvFEbGdbYK8twCZWAZY+T94g ghepBFEmp/EK
LUYtOkvvFCX0q747ZpbgSuvPIXOSPlbn2PpR9Sf8yD23kex3nw21K/uLxZLy 0igunuQXXczI
sp1LB24AJAvouMj7r88DOhq/hPWda1RNYuI7SG4jS2ItLfUp4gzR/a0I+0Ii ug23KtkKclWU
jB3V4NJ4g8cQpM8mr+IUWBmSVmuZwI2UqrBueCC6Ag9Cy+oq7bX/AI4/4SCy 0rUtc8Q6a1wy
l3uZ51MUWTulKsw+VQGYngYU8jBo+pP+ZB7byPcLHwlqem3+ny6f5Fgwwb65 jv5pjInnyTNA
Y5VYS5MjDziyPl2YBR8h7ivlu9vfF9nYtcDxneTyx20N3PbRX9z5kMUoQqzF gFP+tjBCsTlv
QEggk+JE9xdWv9oeJY7yC2F19lkmuBLJGZFjyidTy2fTCt6UvqfXmQ/beR9S UV8t6Pc+PdXa
Jk1fxKtvPFO1vOss7JNJHFI4jQ5wzExleCT14OMVt/DnWfFP/C0dN0vWtS1j /lr5tpezy/8A
PF2G5GP0IyPQ0pYRxTfNsCrXtofRNc5qP+vH/A//AENq6Ouc1H/Xj/gf/obV wyN0ZOp/8gq8
/wCuD/8AoJqbTf8AkXfDn/YEH/tvUOp/8gq8/wCuD/8AoJqbTf8AkXfDn/YE H/tvQthskqab
/VW//XM/+hNUNTTf6q3/AOuZ/wDQmqRnLarNar4iVNT1u60rTY7LzJJoZAgD maONdxKkAZk5
PGOpIAqTSW0ybx/Nomn6trep/wBmRiS+mkmRraOUyKqwMVQbmwXJGRjZjn5g uhNoFhqmoXEu
qpb3NjPYtZyWsob59zq+7IHGNowRyDyCMCtLw3pejeFdCt9G0qKKG2iZXdyz NJK+QWdzsG5j
j2A4AwAAKTViTP1LUPsMcKxxeddXMnk20RbaHfazctg7VCqzE8nCnAJwDnnx NDZObbV4Xt78
Mi+RapJdBw4dlKFE3EYikzlQQUPGNpbQ1LT/ALdHC0cvk3VtJ51tKV3BH2sv K5G5SrMpHBwx
wQcEYV/oOqvfadfw3VtJqYuw09y1uRDHCsE6qBF5gJG6U/xk5cnO0BRIzTfx NpEaROblyrrv
ZlgkYQrkqTLhf3IBVgfM24KNn7rYktfEGm3l81pDLN5okkhDSW0iRu6EhlR2 UK7Da3CknCse
gNYM/gK3mlWaR7GeaRWW4e709ZyC0skrGAMcRndM/wB4SDATIO07teDQPJ+w /wCk5+y6jc3/
APq/veb5/wAnXjHn9e+3oM8ABrHiW00q3vyqTXFxZ20k7JHFIYwUjMmx5QpR GIAOGOcMpxyM
j+LNGi3iW4midLZrt45bWVJEhG/LlCoYL+7YZI6lR/GuaupeE11XUruaa5S3 trqB4ZVs4jFL
MGiMf759xWUKCSuUypxg4yGnbw9LepqY1O8SVtRsFsZjbQmIKoM3zKGZ8HE2 Oc8rnvgGgF28
1vT7CeSCeZ/PRUbyo4Xkdg5fbtVQSx/dyHABICknA5qlbeKrKa8vLeWO5gFv PDEsj28oV/NW
IpklAFbdMF2E7hjJAHSq3hvU5tTOq3Gq2bahH5X2cx2LLEuxZ1O9DKS2RcP0 ZcEKeeQZ5fDt
1N9r3X8I+1SQ3b4tjxdReVtYfP8A6r9yuU+9yfnHGAC7J4h0qLU1017r/TGk MSwiNiWYLGxA
wOcLKjHHQEk8K2H2Gt6fqU7Q2szs23eheF0WVMgb42YASLyvzISPmXn5hnP0 vw7dWmuy6veX
8NxcS+bvWG2MSfOtuowC7HgW4787u2OY/DnhG38OzhoVsQscH2eJoLFYpXTI 5mkyTI3yjkbQ
SWJU8bQDRfxBpqSXCGWbFvkPILaQxlgwXYrhdrvuO3YpLbsjGQRUDeLNGj8r zLiZDJvyr2sq
mIJt3GUFcxKA6HL7RhgehzUL+HbowXFml/CLNrk3kCm2JkSfzxOCzb8Mm/Py hVO0gbsjJq3H
g+W8GoS3Ooobq/tLq3meO3KoGmSGMMqlyQFWBeCxySTkdKNANBvFekr5Q33j yyb8Qx2E7yrs
27t8YQsn+sQ/MBkMpHBFWn1vT0ntozM5W5VWhnWF2gYMcL+9A2AscAAtk5GO ozi3Gg6rF4tO
pabdW0azrO8slxbmRYyyWqKm0SKST5DNu6DpjoagbwHEk9h5FxbNDZtalJLu 0E1yiwFMJHKG
XYrCPkbTy7n+LANANeLxZo1xYw3ltcTXMM+fK+z2ssrOAASQqqWKjcATjCsd pw3FaEuoW0Wn
i/VnntiqurW0bTl1bGCoQEsOQeAeOelc/c+C4ptL0W2LWNxNpdp9kU39iLiJ 12oC3l7hhsxr
g7uAWHOcjQ1Hw+l5olppsckOy12bUuLdZIJQqlQJIl2Ky87gBtAZVI6YoAnH iHSmtbq5F1+6
tbb7VOTG2Y48uDkYyGBikBX7wKkEA1VtfFVlNb3Ms8dzC0F3La7Ft5ZDKySO g8vCfvCRGWIT
dtGc9CayF8DXVvo13YWep2cH262ltrnFgfLCNJM4ESCQbNvnuOSwwF6YOdQ+ HbqPH2a/hTyL
2S9s/Mti+x5PN8wSYcb1/fPtxsIwuS2Dk0AmbxZoyyLH9omZjGJDstZW25Zl CsQvyuXRkCHD
Fhtxnip5fEGmw2sF08s32ebd+9W2kKRbThvNIXEW05B37cYbOMHGXD4Q8ozM b7c80ltNIRDg
b47uS5fA3cKzSFQOSoAyWqlqvgH+0bS4g+12b+f9oG68sfP8jzZZJN0Pzr5b /vcFud2xDgYo
0A1LbxZaTZ85fsoS9ntZHuBIkeIvOO5XKbG4hJPICgnJyAGu/wBv2f2H7X5O o+V5nlbf7NuP
MzjOdmzdt/2sYzxnNZd54Q+3W72M19jTzc3E6okOJR58c6yAuWIPM5KnaMBQ Duzmn6j4dv8A
VoIP7Qu9LupoWfEc+ms9sVYLyYjKf3gKnD7uA7DHOaAIYPFyv4kktJJLY6cW KwzxgsXJWz8v
BBIIZrojOMY29MEnpILuC5muYon3PbSCKYYI2sUV8e/yup49a5G28E/2Vp9x 8/8AaeNOltfs
mPJ+0Zgtotu/cdufs3Xt5n+zk9PpOn/2ZpkNqZfOlG55ptu3zZWYtI+Mnbud mbA4GcDigC7R
RRQMKKKKACiiigAooooAKKKKACiiigDo7D/l6/6+H/pVyqdh/wAvX/Xw/wDS rlWiCujZ1GZd
3SKM7d3Tl+cbvb+6OnU4wtiq6NnUZl3dIozt3dOX5xu9v7o6dTjC2KYFe8bb Ap3bf3sYzux1
dRj7w/nz6N0ItnEu3Dz/AC4xmdz02+/P3R9cn+8cl422BTu2/vYxndjq6jH3 h/Pn0bobFAHx
/FeaXqOn2Vtqs95avYxNDC9rbLOJIzI8nzBpE2sGduQSCCBgbSW3NK8W6Xp+ p2uqul41wYrG
2uLdYl2Rx27wMXR9+XZhbj5Sqgbz8x2/N7jfaX4Yt7yS1sfAtrqs0OBcCzsr UCAkAqrNKyDc
Qc7QSQCpIAZc2H0r4fR3l1ZyWHhhLq0iM9zC0NuHhjABLuuMquCDk8civQeL g+jOdUZLqeE+
E/EthbapocE5eIRwW9pJK+1URhqS3JYknhQnf17Y5qja61oVjBbafH9puIIW nmS8uLGJ2ikk
EQ/492dkkAWEj5mH+tyBlBn3S4k+GVva2l59j8MS2Nzdmz+2RRWzQxSCJpMO /ReEx65ZeOa0
H0r4fR3l1ZyWHhhLq0iM9zC0NuHhjABLuuMquCDk8cil9bhe9mP2Uu54Tqfj q3e/0eayW5kh
0/UIrx4njS3SYxwW0a/IhZUOYZMAAhQ4x1IpjeILOaOd4rvzEsrG6Mcb2NvY iWS4VLcqscWc
sqtvLEkkJjC4LH2m4k+GVva2l59j8MS2Nzdmz+2RRWzQxSCJpMO/ReEx65Ze OaseINL8MaBB
BMfAtrfRyypDm0srUbHd1jQHzGT7zOBxnHOcCj61TS0iHspdz59vvFYu7myi a2STTIoLOK4g
ESQy3KxRxq6NMg3lSyEjJOMKcAqMal34q0e40gaS0ty0MyzLNcw6Tb2pjDPb Ou2KN9rnNuQS
WU4cdduD71F4f8Gvb+bN4f0O3dXjimiltrfdDK4XbE+3IDnegABOdwxnIzXs 7H4cahb3VxZW
vhW5gtE33MkMdu6wrgnLkcKMKTk+h9Kf1unp7uwvZS7nz4uuaWbmPUma8F4d Nawe2ECmNf8A
Q2t1cSb8nJCMRsGATycDO/8ADO/ivPiF4PgjVw1laXEEhYDBY/aZMjnpiRfT kGvZJLH4cQ6X
Dqktr4VTT5n2RXbR24idueFfoT8rcA9j6VtWfhnQNPukurLQ9NtrhM7JYbSN HXIwcEDI4JH4
0p4uDi0kNUmne5q1zmo/68f8D/8AQ2ro65zUf9eP+B/+htXnSOhGTqf/ACCr z/rg/wD6Cam0
3/kXfDn/AGBB/wC29Q6n/wAgq8/64P8A+gmptN/5F3w5/wBgQf8AtvQthskq ab/VW/8A1zP/
AKE1Q1NN/qrf/rmf/QmqRmTqGu6ZpUqxX15HA7ruUPnkVFZeJNH1G8is7O/j muJW2pGgJJP5
Vb0j/ko6f9giX/0dHXZ3P+qX/ron/oQqraE3OWorM12zvb6xSOykwVkDSRfa Ht/OXBG3zUBe
PBKtlRzt2nhjXHW+pXdlc6xqdgUSHTtLRrq3u2kuXlaGe8DqkzOCBuRwGYNw VO0Y21Iz0Siu
OvvEmsQWkt7awW06yz3lpaWiwuZBLAs5Viwb5wxgPyBVPzjk7fmtWnia6vNZ t7WK1zbXNyzQ
ymM4e1Ecg8wHOD+9jU7h8uyaHu9AHT0VzGqeIb601uOO0t/tGnxXMFpdt5Sj y5ZWQD5zKDwJ
Y2wI2BzjcMnbitreptqGh6zI1mf7Q05vssKwMPs/nz2ajed58zb5ingJnaem eCwHoNFeY3d5
q1prd/aC8hF5NqMRNxDHJHHndpiAGPzDldshBBOSMgFQxB6GDVNWl1670aCa zjulkd2uZYZJ
IyI4LUkLH5o25afIw2AF6EsWosB1tFcXp3irU9Qtxquyzj083NlB9k8pjL/p Educ+bux8puO
mzkLjjORSvvEN9qEttbzW+dPvLm0u7C58pY98S3tsBwJXLZEqnLLGRj7vOFL Aeg0VkS3l/P4
ibT7SS2hhtoIbidpYWkaVZHkXauGXYQIjyd2dw44559/FOsCx02dfsIbV4Ib i2BgfFsrz28Z
V/n/AHpxcDkbOU6fNwAdvRXES+KdYjWOMfYTNcztbxP5D7Y2ivIrV2Zd/wAw YylwAV242kt9
6rU+v6uGn0y2WG41i3uWQ+Ta5SWJY4nZwjzoEwZ41/1jE9QME7SwHW0VxFt4 w1W80e71WGxt
hCGtIbaBSXkMlwluwySVUhDMe438DKYy12TWNTPgvX7m/tkhvbGCcbVcIWxC HBIilcxn5sYE
m7ADAjcACwHVUVwOt+IdYi8O6lcvPbLDO2o2duLeJ45YGhS4KyeZvO44g6BV 5bOeMG7Pe3/h
6zvLW0j0uOHR7D7fPHBZtEk6s0x2RqJP3RxEcsd+S+cDGCWA7GiuSXW9dufs 4ibTrf7Vq1xY
Qs8Dy4SL7Qd7DevzHyVGAcDBOTu2rBb+LdRubFFSKE317bWt1YxxQb+JhK/l MGkQMypC5Ll0
B7KCAGLAdpRXnf8Ab+sXdvr1+zJAtno7Ge0cPkyxyXke5GSX90SYgTgscYAb gNWhqnirU7DT
bnU0Sza3Ml7bwQGJt6PbpOwdn3YZWNuflCqRvHzHbyWA7SisjTLy/wD7UvNM 1CS2nmgghuBN
bwtEpWRpF27Sz8gxE5zzuxgYyec0LxJq0+k299IbM2cclhatb+XI0rGeK3Jb zWkPRp88qSQu
CcnILAd1RXEeLJL938UxR3SCyj8PB5IHRmJZhdDKHcAh+UZ+U5AA4xU2o+IN c028/sgRW19q
MrQmKW3t9ihXWdiPLeYbiBbNz5i/f6fLhiwHY0VhRapq8/hY3kOnpJqgZojb pJGQGWQozcSb
cgAsU8zggpuzzWRpmu3MurX2oz6tC+mWmnJLdj7DNFyst0rFY2ctGw8vDZDF to6cUWA7SiuB
OteI7rWLDS5wlherdxuJJIAEkjeC6+Voo533AGHOfMHOPl+XLa8niLURY2st vZw3FxNqN7aL
AG2bxCLnYAxOFYmFAScjk8ehYDp6K47UNQuL/wCH3ib7XMj3UFpcxTIto1uY W8jdsIZ33HDA
7lYqQRgnqayeJNWjTWZ4TZi10qOe6kiljkkknC3N0u1XMnyfLAMfKwBbgYAW iwHdUVyuneId
XvNeEclgiaXJd3FpHIxjU7ojINwbzSzkmI/J5S4BJyQuW6qgYUUUUAdHYf8A L1/18P8A0q5V
Ow/5ev8Ar4f+lXKtEFdGzqMy7ukUZ27unL843e390dOpxhbFV0bOozLu6RRn bu6cvzjd7f3R
06nGFsUwK9422BTu2/vYxndjq6jH3h/Pn0boRbOJduHn+XGMzuem335+6Prk /wB45z7/AFcR
tLELafbDcRRNN5kaKXYoVQbpFJLb1UepbGD0N6yvReCYGCWB4ZPLdJduQdqt /CSOjDvQBky2
WsaXqd/daNbWN5HqMq3E8d5dPbmKRY0j+VljfcpWNOCAQQxywYBef1jwXrGp aTd6PG9ilqsu
oXVtctM++SS6juFCPHswiqbo/MGYnyx8o3fL0i+IpJtbutNtdE1K4S0uEt57 tGgESMyJJnDS
hyAsik4U98ZqvN410pfEcWj21zaXcux/tHk3ce63cTwwhHUkYJaY8Eg/IQAx IFAFfV/DupTe
LE1+xNpI9ulsYbeeVoxIyLdo4ZwrbRtugwIDZKEEDOaw9Q+Ht9dRatbRmBln /tCW2uZtSuWA
kuVmAH2b/VR7fPILjeSFJ2gvleosPG/hu+8PW2uf2zY29jPsXfcXUaeXIyB/ Kc7sCQA8rnIr
Ul1bTYXnSXULSN7dHeZXmUGNUVWYtzwAsiEk9A6nuKAOf1fw7qU3ixNfsTaS PbpbGG3nlaMS
Mi3aOGcK20bboMCA2ShBAzmtjX9Nm1XToreBo1dL20uCXJA2xXEcrDgHnahA 98dOtXLG/s9T
s47ywu4Lu1kzsmgkEiNgkHDDg4II/CrFAHL3Gjfa/HPmhJ0sY4oby5QjENxc KXSEgYwzKMs+
eQY7Ug/LXL6b4R1vXPCGgJqMEGnyafpVvDBCt1KJJSJLaYiRgiNbt/owX5d5 UuSOUAb1CigD
z/8A4Q3VoYo7jTkgsNWkllY3w1a4uHtQ6xISfORhdZEKkq4jA2qFwR5legUU UAFc5qP+vH/A
/wD0Nq6Ouc1H/Xj/AIH/AOhtUyGjJ1P/AJBV5/1wf/0E1Npv/Iu+HP8AsCD/ ANt6h1P/AJBV
5/1wf/0E1Npv/Iu+HP8AsCD/ANt6FsNklTTf6q3/AOuZ/wDQmqGpLl1jt4Xd gqLESzMcADc3
JqR7jIBFBdG6WBDclPL83LBgmc7QQRxnn8B6CnS+IIoZfLZhJKhBMSGSRh3B Kgk46ckY6Vy5
fV9a18WFlFZsjQPPGtxPIiNGrhMnYPm3ZBwQRt+pzu2OieIraaCO6i0WGxDg OLV5CwBP8KlQ
Op9ffnpUpykrrY1lGnTdp3b8v89fy+ZRvzo2pwLDqlmk1urbwL2zby1bBAOX XaDyR+OO9W2s
NOitZI2tLVLcwCCRTGoQwqDhCMY2AM3HQZPrTdU1W00e1W5vDMImkWIGKCSU 7mOFGEUnk4A9
yB1Ip6aZp8bq6WNsrqcqyxKCD6jil74fuX3X3P8Ayt+JTR9DTUJdQt4rSS/l XZJPbRCSZl44
YoC2OF68cD2qSIKnki00cR+TGYoHcJGqR8fKMZZVO1eNvYZAxxpUUWl1Yc9N bR+9/wCVjGud
GW/vor+6sNJ+1w4EUstt58iYOQVc7SME5AA4POeaYvhLSRPczPbRu90rLcMI Y42lDHLB2jVW
YHuCSD3FblFHIuoe2kvhsvl+u/4mHB4O8P2sDwW+mxwwuro0cbMqsrgBwQDy GCrn12jPSiXw
d4fntBaTabHJbBlcQuzFAyqEU7ScZCgKPQADpV+y1SC+0iz1ONJhBdxxSRqY yzgSY25C5x94
ZPQcknAzU9ndwX9jb3lq/mW9xGssT4I3KwyDg8jg96OSPYPrFX+Z/eym2gac 3mbopT5kizPm
4k+Z127WPzcsNi4PUbR6CqqeDvD8V3Ldx6bGlzK2+SZWYO7bg+S2ck7lDfUA 9RW5RRyR7B9Y
q/zP72ZN14a0m9nt57u2a4mtm3wSSzO7RNkHKkn5TkDp6CmReGdPtZJ5LKKO B55Fmm/dI4lk
Vtyu5YFiQ3P3hg8jB5rZoo5I9EHt6nV39dfzMDUdChvbQW99Y2k9sJBK7QQh Wx5qysuwhtys
6AsM5bngnGbp0TRbnS4bI6Xp8unofMig+zo0Sk5O5VxgfePI9T61pVS011lF 1LEwa3ecmIqe
CMAMR/wMN9eT3zRs0htKcXK1rfj/AMH/ACY9NNsIrSW0jsrZLaVdkkKxKEdd oTBXGCNqhfoA
Ogoi02wg086fDZW0dkVZDbJEojKtncNoGMHJz65NWqKsxKsmm2E0HkS2Vs8O 538tolK7nDBz
jHVg759dxz1NF1pthez2893ZW1xNbNvgkliV2ibIOVJHynIHT0FWqKAIVs7V fL220I8uRpkw
g+V23bmHox3tk9TuPqagk0fTJbVrWTTrN7do0hMTQKUKISUXGMbVJJA6DPFX aKAM8aDo4ghg
Gk2PkwLIkUf2ZNsayDDhRjgMCc4655p76Ppkl1cXT6dZtcXMZhnlMCl5UIAK scZZcADB44FX
aKAGCGJZ3nEaCZ1VGkCjcygkgE9wCzY+p9agj02whg8iKytkh3I/lrEoXcgU IcY6qETHptGO
gq1RQBVu9NsL90e8sra4aNXRGmiVyquNrgZHAYcH1HWi602wvklS7sra4WZV SVZYlcOqksob
I5AJJGehJq1RQBVl02wn08afNZW0lkFVBbPEpjCrjaNpGMDAx6YFA02wV7R1 srYNZqUtmES5
gUjaQnHyjAA47VaooAzIvDehQ2s9rFounR29xt86JLVAkm05XcMYODyM9KfN oOj3F5JeT6TY
y3UilHne2RnZSu0gsRkgr8v04rQooAqxabYQaedPhsraOyKshtkiURlWzuG0 DGDk59cmj+zb
DZOn2K223ClJl8pcSqSzENxyCXc892b1NWqKAKqabYRahLqEdlbJeyrskuVi USOvHBbGSPlH
5D0q1RRQAUUUUAdHYf8AL1/18P8A0q5VOw/5ev8Ar4f+lXKtEFdGzqMy7ukU Z27unL843e39
0dOpxhbFV0bOozLu6RRnbu6cvzjd7f3R06nGFsUwOL8TaB/arTx3MOpJH/aF vcRTWt55SsFM
GVKiZMsTFtUkEqSGXmtzSLBoxcGWG7gXzV8pZrku5VY4lyzB23HMfViSec/e OdC8bbAp3bf3
sYzux1dRj7w/nz6N0NigDj4fDt5aeNr/AFldD0O6+1XccseoTTlLu3j8iOJl UeS39xyBvAO7
HGTWWng3XmGg2co01bTRLeC1inW5dnuFjubSTeyeWBGSlq3yhm5YDOOa6weJ LNtTn06OOeS8
iuxa+Uiglv3cUjSDniNVmTLHHPyjLMoaxDruj3EtzFDqtjJJayrBcIlwhMUj NsVGAPysW+UA
8k8daAOb0/QNe0i30RreHTbmfR7KTS40ku3iWeEiDExYRMUfMH+rww+b75xz X03wEdJ8Oalp
5gtNQnmeyEUn2iSzaRbaC3RC0sas6FXid1C7sZ68musvtd0fTIpJb/VbG0jj lEDvPcJGFkKh
whJPDFSGx1wc9K0KAM/RLfUbXR4IdWvftl8Nxkmwo6sSF+VVB2ghdwVd23O0 ZwNCiigAoooo
AKKKKACuc1H/AF4/4H/6G1dHXOaj/rx/wP8A9DapkNGTqf8AyCrz/rg//oJq bTf+Rd8Of9gQ
f+29Q6n/AMgq8/64P/6Cam03/kXfDn/YEH/tvQthskpuqQNc6UYEIDy2zopb pklhzTqmm/1V
v/1zP/oTVDV00VGTjJSXQz9DSWXxmNREEwto9Pe3kbYTslMiMEOM84BPHGMH oRnr5pllVVVZ
c70PMbDowPcVyc9nFO4kIKTAYWWM7WA9M9xnnByPaosahFwpt7kdi5MTD6kB gx+gX6c8HO1o
0X7OM9Yu3k/89vvsUfFEd3NpUKWdjNeSi9tpTHE8akLHMkjHLso6IQOepHbJ HCa7YLe6jcaR
b6dDc6+ZL95LuOSBpGilt7jykc7vNVQJIU+dQoIUA4259J+2yp/r7G4QD7zp tkX8Ap3Ef8B+
oFH9p2w+8LhB3Z7aRVHuSVwB7ml7SK6j+r1Hsr+mv5HL3/ho2+psLLRoZNDX yJJdNgWJI7lg
twr/ALtiqFgXt2JbGRGMElQKhtPCuoldTl8v7LcvpzQ6a5mwLRmkuiigKSFa OOWNMqDtG4IS
M567+1tN/wCghaf9/l/xo/tSyb/VTef6/Z1MuPrtBx+NHtI9w+r1f5X9zMTw hozaT9sItby0
gl2BYbn7MnzDdlhHbqEGQVG4ksduCAFGcyx8KarBDp0Uk2Ujkt7aUbV+WC1d XhfrzuaJzgcj
7VznyhnrvtdyeF024BPQu8YUfUhicfQH6UY1KTnfaQdtu1pc++cr+WPxo5+y D2LXxNL53/K7
OKtvCV3Y6d4eistMht3S2tv7SEJjTfNHcWr5fB+dgqTkHnq2PvcwnwjMmiaR ZHR5kgso3iuo
LSOzf7VPtiAuAs2UKkJINzYk+YcAFq7v7NdvzJqDofSCJVX8mDHP4/hR/Zls 3+vV7g9T57l1
z67T8oP0A9qOaXRB7Omt5fcv87HN6/An/CN2Gmzfab+8tvK8y1ieK6aZljP+ uSUp5yZwxwFY
nDDaRkYVhayNqtwsPh4f2ol7Zt9vs4Ejit0jht/NhVmIkRSqSKFIAIcZ4Y16 VFDHBGI4Y0jj
HRUUAD8BT6Pe7hekujfz/S36/M88PhfWPNe8W3xJdQGTUrVRBFHcS+bFIY12 AF1YLNHmYniQ
5PLZg1XwtqeoG0ktNNk06MQbLe1t47QLZSb3JbJLeUSWU+ZDljjJUFVB9Koo 5e7/AK+Qe1t8
MUvx/O5T+wCX/j8le5H/ADzcARj/AICOo9N27GOverlFFCilsRKpKe4UUUVR IUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAdHYf8AL1/18P8A0q5V Ow/5ev8Ar4f+
lXKtEFdGzqMy7ukUZ27unL843e390dOpxhbFNCASM+WyQARuOOM9ug69fp6C nUwK9422BTu2
/vYxndjq6jH3h/Pn0boRbOJduHn+XGMzuem335+6Prk/3jmZ0EigEsACD8rE dDnt9OnfpTqA
OXs/Dd5p3irWNetZIPM1K7h86J2OJLdIY0GTj5ZEYSsMZDBtrclWj5+y8Dto 2h3KX8E88dhp
T2sEtnf3F1dS7djB4IpP3dvJmFGVUDYbZhgE+b0iigDh7nwprH2Owns5YIdf bznutVS7dTBJ
MUMmyIxstxGNiqqS4ISKMBgQGXuKKKACiiigAooooAKKKKACuc1H/Xj/AIH/ AOhtXR1zmo/6
8f8AA/8A0NqmQ0ZOp/8AIKvP+uD/APoJqbTf+Rd8Of8AYEH/ALb1Dqf/ACCr z/rg/wD6Cam0
3/kXfDn/AGBB/wC29C2GySppv9Vb/wDXM/8AoTVDU03+qt/+uZ/9CapGQ0UU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAf/2Q==
--------------070300060608050408090000--
--------------010105080304030507060205--
FUDForum. Page generated in 0.05305 seconds
