fproj plugin? [message #2509] |
Thu, 04 December 2008 07:52  |
I have to develop kinda plugin which will have to keep some files up to
date.
I mean if i whant to put toto.xml and toto1.xml, each time toto1.xlm is
modified by the user, toto.xml will have to be automatically updated
(using toto1.xml. toto.xml depends on toto1.xml).
Someont told me fproj was a tool which could help me. but all what i have
seen about fproj is a project under construction.
I suppose facets can be useful for me, but apparently, facets are too much
near from WTP, and all what i want to do is just a little eclipse plugin.
Is there a way to do something like what i need?
thanks,
jb
Re: fproj plugin? [message #2540 is a reply to message #2509] |
Mon, 08 December 2008 23:19  |
The Faceted Project Framework right now is a component of WTP, but it
doesn't have any dependencies on WTP and can be easily used by code that
does not have a natural WTP dependency. You can download the builds from
[1]. Look for 3.1 integration build link. Once you follow the link, look
for Faceted Project Framework section.
The framework is in the process of being migrated into an independent
project to further stress independence from WTP, but that project has not
been created yet. The creation review is scheduled for December 10th, in
fact.
I couldn't tell from your brief description whether or how this framework
would help you out. Faceted Project Framework is a solution for letting
you to enable users to add functionality to projects in a modular fashion.
You can read the tutorial [2] to familiarize yourself with framework's
capabilities and don't hesitate to ask questions on this newsgroup if
something is not clear. More specific questions tends to produce the best
answers.
[1] http://build.eclipse.org/webtools/committers/
[2]
http://www.eclipse.org/articles/Article-BuildingProjectFacet s/tutorial.html
Re: fproj plugin? [message #571663 is a reply to message #2509] |
fact.
answers.
[2]
FUDForum. Page generated in 0.24916 seconds
