headless build "forgets" native swt plugins for linux [message #29232] |
Fri, 24 October 2008 04:54  |
Hi there,
I succeeded in getting a headless build of my software by following this
guide:
http://rcpquickstart.com/2007/06/06/getting-started-with-pde -build/
So the build succeeds, but when I start my application (gtk,linux,x86) I
get the error message:
"An error has occurred. See the log file
/home/tobias/emulator/configuration/1224837580357.log."
In the logfile I got this
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
... 71 more
and some more. So I copied the linux native swt plugins in the plugin
folder of the resulting build and added them in the config.ini and voilá,
it worked fine.
Since I am not willing to do that every time - since I actually wanted to
have a fully automatic build, I'd love to hear another opinion - or even
better - a solution to that. The funny thing is: the Windows build works
perfectly! Every plugin is copied right. I tried to build from both
platforms - windows and linux, but both showed the same behavior.
Please help! Cheers,
Tobias
Re: headless build "forgets" native swt plugins for linux [message #31209 is a reply to message #29232] |
Wed, 05 November 2008 06:29  |
I just got it working. In the preferences for the target platform in
Eclipse I unchecked the "Build target platform based on the target's
installed plug-ins" and then hit the "add required plug-ins" button in
the product-file on the configuration tab. After that everything
worked like a charm.
Re: headless build "forgets" native swt plugins for linux [message #584315 is a reply to message #29232] |
FUDForum. Page generated in 0.03651 seconds
