Home » Eclipse Projects » DSDP - Target Management » connect manually to subsistem ...
connect manually to subsistem ... [message #29230] |
Tue, 04 November 2008 10:09  |
Hi all,
Not sure what I'm going to write has a bit of meaning or not .
But .
I have created my own subsystem to interact with my database .
From the remote view it works . I still have to fix a few bugs but let's say
it works.
How difficult would it be to initialize manually the subsystem without the
use of the remote view . what I would like is to be able to manually connect
to the subsystem and get the root so I can populate my own view . (I did try
something but it comes out the login dialog and after that few error that
internal structure has not been initialized).
Kar
IRSESystemType systemType = RSECorePlugin.getDefault().getCoreRegistry()
.getSystemTypeById("mydb.files.Files");
Host myHost = (Host)
RSECorePlugin.getDefault().getSystemRegistry().createHost(
systemType, "linuxbox", " linuxbox", "this is a test");
myHost.setUserIdCaseSensitive(true);
myHost.setDefaultEncoding("UTF-8", true);
myhost.setDefaultUserId("Administrator");
FileServiceSubSystem subsystemX = (FileServiceSubSystem) configuration
.createSubSystemInternal(myHost);
EOMConnectorService connectorService = (EOMConnectorService) subsystemX
.getConnectorService();
Re: connect manually to subsistem ... [message #29418 is a reply to message #29268] |
Wed, 05 November 2008 10:03   |
Hi Kar,
creating and accessing the fileServiceSubSystem should work
fine even without the RSE SystemView, just via API.
Looking at your code, you shouldn't call createSubSystemInternal()
-- it's internal as its name suggests. The subsystems should be
created for you automatically when the systemRegistry creates your
host, and when you connect later on.
Given that your own systemType / subsystem implementation still appears
to be buggy, I'd suggest that you first try communicating with a remote
system via the existing SSH subsystem programmatically (without the RSE
systemView). Once that works, replace SSH with your own.
Look at the RSE Unittests to see how programmatically creating and using
connections is done. I haven't tried it yet, but the RSE Unittests
should work fine even if the RSE SystemView is never shown.
Team project set which includes the unittests:
http://www.eclipse.org/dsdp/tm/development/rse-releng-anonym ous.psf
ViewCVS access:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tm.rse/ tests/org.eclipse.rse.tests/?root=DSDP_Project
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
Kar wrote:
> what I would like is to be able to create a fileservicesubsystem ... to
> be able to used cached object and remote file automatically so that I
> could easily handle editor and so on ...
> thanks
> "Kar" <carmeloscala@hotmail.com> wrote in message
> news:gepojv$8cc$1@build.eclipse.org...
>> Hi all,
>> But .
>> let's say it works.
>> the use of the remote view . what I would like is to be able to
>> manually connect to the subsystem and get the root so I can populate
>> my own view . (I did try something but it comes out the login dialog
>> and after that few error that internal structure has not been
>> initialized).
>> Thanks
>> Kar
>> test");
Re: connect manually to subsistem ... [message #29456 is a reply to message #29418] |
Fri, 07 November 2008 04:07  |
Thank a lot Martin
Kar
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:4911B5A7.2090402@windriver.com...
> Hi Kar,
> Given that your own systemType / subsystem implementation still appears to
> connections is done. I haven't tried it yet, but the RSE Unittests should
> ViewCVS access:
> Cheers,
>> thanks
>>> Hi all,
>>> But .
>>> say it works.
>>> the use of the remote view . what I would like is to be able to manually
>>> connect to the subsystem and get the root so I can populate my own view
>>> . (I did try something but it comes out the login dialog and after that
>>> few error that internal structure has not been initialized).
>>> Thanks
>>> Kar
>>> test");
Re: connect manually to subsistem ... [message #577822 is a reply to message #29230] |
Tue, 04 November 2008 11:57  |
what I would like is to be able to create a fileservicesubsystem ... to be
able to used cached object and remote file automatically so that I could
thanks
> Hi all,
> But .
> say it works.
> connect to the subsystem and get the root so I can populate my own view .
> (I did try something but it comes out the login dialog and after that few
> Thanks
> Kar
Re: connect manually to subsistem ... [message #577881 is a reply to message #29268] |
Hi Kar,
ViewCVS access:
> thanks
>> Hi all,
>> But .
>> let's say it works.
>> initialized).
>> Thanks
>> Kar
>> test");
Re: connect manually to subsistem ... [message #577904 is a reply to message #29418] |
Thank a lot Martin
Kar
> Hi Kar,
> ViewCVS access:
> Cheers,
>> thanks
>>> Hi all,
>>> But .
>>> say it works.
>>> Thanks
>>> Kar
>>> test");
Current Time: Fri Jul 25 23:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.41801 seconds
