VE will not install. Error is No plug-in: "org.eclipse.ve.cde" included at runtime... [message #29205] |
Sat, 03 April 2004 18:54  |
I've got
Eclipse installed (eclipse-sdk-2.1.3-win32.zip)
It works fine.
I downloaded VE 0.5 (ve-runtime-0.5.0.zip)
I unzipped into the eclipse plugins directory. Apparently restarting
Eclipse got it to realize there were no files and it updated the install.
Under installation configuration, there was an error flag for the install
and it said I needed EMF.
And I downloaded emf_1.1.1_20031120_1149WL.zip
I unzipped and folowed the same steps as the VE. Under installation
configuration, EMF seems to work fine.
I tried to disable VE by adding it to the updated tab and then repair it.
No luck.
So I downloaded the XSD bit and got it working.
But I still can't get VE to work. The error message under the "installation
configuration" pane is now:
No plug-in: "org.eclipse.ve.java.core" included at runtime.
No plug-in: "org.eclipse.ve.jfc" included at runtime.
Can anyone suggest how to get this working?
Am I installing these plug-ins correctly? (I can't find any coverage in the
help files, which talk about URLs for updates...but eclipse.org doesn't seem
to use the URL update model.)
Should I be using Eclipse 2.1 or 3.0?
Thank you
Scott
Re: VE will not install. Error is No plug-in: "org.eclipse.ve.cde" included at runtime... [message #29396 is a reply to message #29243] |
Mon, 05 April 2004 08:55  |
Jeff,
Thanks for your help.
Luckily I didn't have to start over -- just installed GEF and VE started
working automatically.
I don't know how I missed the "you must install these things before
installing VE" instructions :).
Scott
"Jeff Myers" <binarydreams@yahoo.com> wrote in message
news:c4pst7$pmr$1@eclipse.org...
> Sounds like you're making a relatively simple set up much more
> complicated than it should be. You need to install all the required
> plugins listed on the download page:
http://download.eclipse.org/tools/ve/downloads/drops/R-0.5.0 -200312051712/index.html
> Try starting again with a clean install of Eclipse 2.1.2. Unzip the EMF
> and GEF builds listed on that page onto your Eclipse directory. Unzip
> the VE build to the same location. Start Eclipse, and the Visual Editor
> should be activated and work correctly.
> - Jeff
> Scott wrote:
> > I've got
> > It works fine.
install.
install
it.
> > No luck.
"installation
the
seem
> > Thank you
> > Scott
Re: VE will not install. Error is No plug-in: "org.eclipse.ve.cde" included at runtime... [message #585721 is a reply to message #29205] |
Sun, 04 April 2004 17:03  |
- Jeff
Scott wrote:
> I've got
> It works fine.
> No luck.
> Thank you
> Scott
Re: VE will not install. Error is No plug-in: "org.eclipse.ve.cde" included at runtime... [message #585782 is a reply to message #29243] |
Jeff,
Scott
> - Jeff
> Scott wrote:
> > I've got
> > It works fine.
install.
install
it.
> > No luck.
"installation
the
seem
> > Thank you
> > Scott
FUDForum. Page generated in 0.08262 seconds
