Home » Language IDEs » C / C++ IDE (CDT) » cdt on windows
cdt on windows [message #29195] Fri, 03 May 2002 14:04 Go to next message
Originally posted by: dominic.nospam.com
Hi.
Can anyone help me setup cdt in windows ? i tried running with the latest
eclipse dev build and i do not even see a project type. Just the normal
eclipse projects come out.
Re: cdt on windows [message #29233 is a reply to message #29195] Fri, 03 May 2002 14:18 Go to previous messageGo to next message
The latest CDT Build 20020408 was tested only with the 20020321 Stable Eclipse Build. Due to various changes between
Eclipse Builds it is definitely possible that our builds will not work on any Eclipse Builds other than those we tested
with.
Which Eclipse version are you using? If it is M5, then you have 2 choices:
1. Wait until next week when we make a new CDT driver tested with M5 available.
2. Check our code out of cvs and build it yourself. (If you decide to this and need some help..let me know).
Hope that helps,
Jeff.
We've tested the latest CDT driver 20020408 with the Stable Eclipse Driver 20020321.
"dominic" <dominic@nospam.com> wrote in message news:aauj9u$r0r$1@rogue.oti.com...
> Hi.
Re: cdt on windows [message #29310 is a reply to message #29195] Fri, 03 May 2002 16:01 Go to previous message
dominic wrote:
> Hi.
At the link below you should see which driver of ours goes with which
Eclipse driver.
Pick a matching pair, if you still have a problem, send us the .log file
from the eclipse/workspace/.metadata directory.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/downloads/main.html?cvsroot=Tools_Project
Robert.
Previous Topic:"libsrc.a" error (Was: "Am I dumb...?")
Next Topic:ERR[1]: GdbPicl
Current Time: Mon Jul 21 21:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.03271 seconds
