Home » Modeling » OCL » Re: EMF + OCL
Re: EMF + OCL [message #29188] Thu, 21 June 2007 06:40 Go to next message
Fran,
You should ask on the OCL newsgroup, which I've added to the "to" list
of the reply, and hence you can continue to use this thread.
Fran wrote:
> Firstly, sorry if this are not the place to post it :-)
> I'm starting to work with EMF and eclipse, and now I want to make a small plugin that can execute ocl constraints using the API provided by EMF.
> I have found this code and I have been making changes in order to get it works, but I have problems with Factory.eINSTANCE which is not recognized. The code is this:
> public void ocl() {
> Map extents = new HashMap();
> Query query=QueryFactory.eINSTANCE.createQuery("self.allConnections- >forAll(r1,r2|r1.name = r2.name implies r1 = r2)",LibraryPackage.eINSTANCE.getBook());
> Book myBook = Factory.eINSTANCE.createBook();
> Collection result=(Collection)query.evaluate(myBook);
> System.out.println(result);
> If some of us have some example of this working, I would be grateful :-)
> Thanks a lot. Bye ;-)
Re: EMF + OCL [message #29264 is a reply to message #29188] Thu, 21 June 2007 06:54 Go to previous messageGo to next message
Hi, Fran,
"Factory.eINSTANCE" should be "EXTLibraryFactory.eINSTANCE"
This looks like a snippet from the OCL 1.0 tutorial. If you are using EMF
2.3 with Eclipse 3.3 (rather than EMF 2.2/Eclipse 3.2), then you should
probably be using the OCL 1.1 API. The on-line help documentation (the
OCL Developer Guide accessed by the "Help -> Help Contents" action in the
main menu bar) is vastly expanded, including an updated Tutorial, updated
Example, and lots of Programmer's Guide documentation.
For a working example of the OCL parser/interpreter, install the
Interactive OCL Console example plug-in in your workspace via the "File ->
New -> Example..." wizard (the "Interpreter Example" in the OCL category).
HTH,
Christian
Ed Merks wrote:
> Fran,
code is this:
>> public void ocl() {
>> Query
Re: EMF + OCL [message #29378 is a reply to message #29264] Fri, 22 June 2007 04:24 Go to previous message
Originally posted by: fjlucas.um.es
Thanks. I'll try it.
Previous Topic:stereotype's property
Next Topic:constraint's severity
Current Time: Fri Jul 25 10:21:57 EDT 2025
Powered by FUDForum. Page generated in 0.04926 seconds
