Home » Eclipse Projects » Eclipse Platform » Internationalization of eclipse plugins.
Internationalization of eclipse plugins. [message #291140] Fri, 09 September 2005 02:31 Go to next message
Originally posted by: sibinjosk.tataelxsi.co.in
Hi All ,
I need to know how the internationalization of eclipse workbench
can be done.
My requirement is as follows,
while installing my product user can chooose between different
languages.
if the user selects a particular language, the plugin should use the
apropriate plugin.properties file. ie suppose the user has choosen french
then the plugin should use the plugin_fr.properties file. How to make this
work.
Thanks in advance for any help.'
sibin.
Re: Internationalization of eclipse plugins. [message #291145 is a reply to message #291140] Fri, 09 September 2005 06:49 Go to previous message
Originally posted by: automatic.javalobby.org
Most of the internationalisation is handled automatically by the Java runtime libraries, which in turn are based on the user's settings. So the app will start up with whatever translation is set for the user automatically.
However, that may not be suitable in certain environments (such as when you're working in one at European companies which are typically bi- or tri- lingual). In this case, you can pass a flag to the startup of eclipse (or put it as a line in the eclipse.ini file)
-nl <locale> (OSGi)
equivalent to setting osgi.nl to <locale>
See http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/runtime-options.html for the list of options you can have.
What you could then have is this entry being modifed by your own hand-rolled startup script, or more likely, installer.
Previous Topic:Resource Event handling problem (bug?)
Next Topic:open view in specisfic perspective
Current Time: Fri Jul 18 05:55:25 EDT 2025
Powered by FUDForum. Page generated in 0.38700 seconds
