Problems migrating plugin to eclipse 3.1 [message #290998] |
Tue, 06 September 2005 04:28 |
Pravinsinh Messages: 16 Registered: July 2009 |
Junior Member |
I have developed a pluguin in eclipse 3.0.
The plugin is basically an xml editor that edits xml files with different
file extensions. I have three different editors and i open the file in the
respective editor based on the extension of the file. For this i have
defined a plugin project and three different fragment project which refer
the plugin project.
The plugin works perfectly in eclipse 3.0.
After migrating the plugin to eclipse 3.1 when i try to open the xml file
the i am able to get only two extensions of the three extensions present
in the extension point.
The code for the registry that i have used is as below:
IExtensionRegistry registry = Platform.getExtensionRegistry();
IExtensionPoint extensionPoint =
registry.getExtensionPoint("de.dpag.mail.tesa.serviceeditor.base.view ");
IExtension extensions[] = extensionPoint.getExtensions();
The above code works perfectly fine with eclipse 3.0.
Please suggest if there is something that i am missing.
Thanks & Regards,
Pravin.
FUDForum. Page generated in 0.03180 seconds
