Plugin install directory [message #290945] |
Mon, 05 September 2005 11:54 |
Originally posted by: dcorbin.machturtle.com
I have a plugin that needs to find the fully qualified path to a file that
is part of the plugin (it's for an external process). I can't quit figure
a reliable way to do this.
I can cover some cases, but parsing out the bundle location, but that only
works if the "current directory" is the eclipse install directory, which
it's not guaranteed to be. I've not been able to programmatically find the
Eclipse install directory, either.
So is there an approved way to find either a plugin's install directory, or
the eclipse install directory?
Thanks.
David
Re: Plugin install directory [message #290953 is a reply to message #290945] |
Mon, 05 September 2005 12:14 |
Originally posted by: ac.cashware.biz
You can check the system property "osgi.install.area" (
System.getProperties().get( "osgi.install.area")). It retrieves the
installation directory.
Re: Plugin install directory [message #290955 is a reply to message #290945] |
Mon, 05 September 2005 12:18 |
Originally posted by: sunil_kamath.nohotspammail.com
"David Corbin" <dcorbin@machturtle.com> wrote in message
news:dfhbkr$g2e$1@news.eclipse.org...
> the
> or
If the file is part of the bundle, then you should be able to call
getBundle().getEntry("/path/to/my/resource") to get the URL of the file.
The path should be relative to the bundle root. To get the bundle install
location, pass "/" as the path.
Once you have the URL, if it is a file: url, you can convert it to a File.
Sunil
Re: Plugin install directory [message #290972 is a reply to message #290955] |
Mon, 05 September 2005 14:20 |
>> figure a reliable way to do this.
>> only works if the "current directory" is the eclipse install directory,
>> which
>> the
>> or
> Sunil
When I call getBundle().getEntry("/").toString(), I get the terribly
unuseful "bundleentry://108/". (At least while debugging...)
Re: Plugin install directory [message #290976 is a reply to message #290953] |
Mon, 05 September 2005 14:23 |
> Cheers,
So it does. Unfortuately, that turns out not to help when the plugin is
being debugged.
> Álvaro
> "David Corbin" <dcorbin@machturtle.com> escribió en el mensaje
>> which
>> the
>> or
>> Thanks.
>> David
Re: Plugin install directory [message #290982 is a reply to message #290972] |
Mon, 05 September 2005 14:55 |
news:dfhk6j$rsg$1@news.eclipse.org...
>>> or
>> File.
>> Sunil
Do you actually need the path to the file or the file contents?
If you really need the file itself, try:
IPath path = new Path ("myfile.txt");
URL resolvedURL = Platform.find(MyPlugin.getBundle(), path);
if(resolvedURL != nul) {
URL realURL = Platform.asLocalURL(resolvedURL);
File file = new File(realURL);
Be warned that if you are deploying your plugin as a single jar, this may
not work.
Sunil
Re: Plugin install directory [message #290991 is a reply to message #290982] |
Mon, 05 September 2005 17:34 |
>>>> directory, or
>>> install location, pass "/" as the path.
>>> File.
>>> Sunil
I actually need the file. Well, I could get the contents and then write a
copy out to a temporary directory, but that seems wasteful.
> not work.
Not a problem yet.
FUDForum. Page generated in 0.04586 seconds
