plugin customization to default update schedule enabled [message #290917] |
Fri, 02 September 2005 23:19 |
Originally posted by: pmac.nospam.tensilica.nospam.com
eclipse 3.0.2 question ...
Is it possible to use the plugin_customization.ini to default update
scheduling to be "check automatically, at startup"?
Looking at the prefs which are set, it seemed sufficient to define
org.eclipse.update.scheduler/enabled=true
but that doesn't seem to do the trick. Running a new eclipse application
with that, the preference is still switched off. I have other customizations
that are taking effect, so the file is definitely being processed (e.g.
org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=false)
If i enable automatic update checking, and export preferences, this appears
to be the only line that is added ... so i was hopeful?
THANKS
PMac
FUDForum. Page generated in 0.03070 seconds
