Re: Why newsgroup and no "usual" forum? [message #290691 is a reply to message #290679] |
Tue, 30 August 2005 09:32 |
Originally posted by: joerg.von.frantzius.artnology.nospam.com
Ronny Priv schrieb:
>Hello,
>why is the eclipse-project using newsgroups and no "usual" web-forums?
>To me it seems to be a technique of the last century, maybe older:-)
Who says old is bad? You don't mind using TCP/IP as well, do you?
Personally I have yet to see a good web forum with threaded view that
doesn't roundtrip to the server for opening/collapsing threads.
>Old messages will be automatically deleted on the server (and from time to
>time in my newsreader too) and there is no easy possibility to search for
>old threads. I cannot even search in the archived threads on the
>eclipse-website.
The messages simply aren't deleted, as per configuration of the server I
guess. If there is a problem with searching through the web-frontend,
please tell the webmaster.
Some groups are mirrored in a more fancy web-frontend at
http://www.eclipsezone.com/java/forums/c5605.html
>This is bad, bad, bad. Or not?
Nope. Maybe your newsreader is?
>regards
>ronny
Re: Why newsgroup and no "usual" forum? [message #290695 is a reply to message #290691] |
Tue, 30 August 2005 11:29 |
Originally posted by: myersj.nospam.gmail.com
>> time to
>> eclipse-website.
You can also search the newsgroups and mailing lists via Google. Just
specify site:dev.eclipse.org when performing your search.
- Jeff
Re: Why newsgroup and no "usual" forum? [message #290699 is a reply to message #290679] |
Tue, 30 August 2005 12:10 |
> eclipse-website.
you can. just use the "search"-entry in the menu left.
it does not mean, that it is a very convenient search-interface -- a
really useful interface for the newsarchives would be highly appreciated.
i don't understand why eclipse.org does not provide a convenient interface
to search the news-archives (_without_ need to authenticate just to read
some of the searchresults) ...
regards
FUDForum. Page generated in 0.02785 seconds
