Home » Eclipse Projects » Technology Project and PMC » Anyone ever successfully used org.eclipse.ui.IStartup
Anyone ever successfully used org.eclipse.ui.IStartup [message #29104] Wed, 02 October 2002 11:20 Go to next message
Originally posted by: nospam.nospam.nospam
Anyone ever successfully used org.eclipse.ui.IStartup ?
I am getting
java.lang.ClassCastException:
org.eclipse.core.internal.plugins.DefaultPlugin
at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:1114 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:831)
at org.eclipse.core.runtime.Platform.run(Platform.java:416)
at org.eclipse.ui.internal.Workbench$9.run(Workbench.java:1122)
at java.lang.Thread.run(Thread.java:536
Re: Anyone ever successfully used org.eclipse.ui.IStartup [message #29179 is a reply to message #29104] Wed, 02 October 2002 12:59 Go to previous messageGo to next message
Yes. Your plugin class must implement the IStartup interface and its method
(earlyStartup()), as well as defining the extension point in your
plugin.xml. I suspect that you have defined the extension point but not
implemented the interface (thus the ClassCast)?
-Andrew
"Alex" <nospam@nospam.nospam> wrote in message
news:anf1bu$khd$1@rogue.oti.com...
> I am getting
> at
> :831)
Re: Anyone ever successfully used org.eclipse.ui.IStartup [message #30246 is a reply to message #29179] Mon, 07 October 2002 11:32 Go to previous messageGo to next message
I have implemented the interface:
package ...;
import org.eclipse.core.runtime.IPluginDescriptor;
import org.eclipse.ui.plugin.AbstractUIPlugin;
import org.eclipse.ui.IStartup;
/public class MyPlugin extends AbstractUIPlugin implements IStartup{
public MyPlugin(IPluginDescriptor descriptor) {
super(descriptor);
public void earlyStartup()
//System.out.println("earlyStartup");
"Andrew McCullough" <mccull1@us.ibm.com> wrote in message
news:anf779$okp$1@rogue.oti.com...
method
> -Andrew
> > I am getting
> > at
> > :831)
Re: Anyone ever successfully used org.eclipse.ui.IStartup [message #30352 is a reply to message #29104] Mon, 07 October 2002 14:41 Go to previous message
Originally posted by: john_arthorne.o_ti.com
The stack trace shows you are using the DefaultPlugin. This means you
are missing the "class" attribute for your plugin definition.
>I am getting
>at
>:831)
Re: Anyone ever successfully used org.eclipse.ui.IStartup [message #583935 is a reply to message #29104] Wed, 02 October 2002 12:59 Go to previous message
-Andrew
> I am getting
> at
> :831)
Re: Anyone ever successfully used org.eclipse.ui.IStartup [message #584243 is a reply to message #29179] Mon, 07 October 2002 11:32 Go to previous message
package ...;
super(descriptor);
method
> -Andrew
> > I am getting
> > at
> > :831)
Re: Anyone ever successfully used org.eclipse.ui.IStartup [message #584283 is a reply to message #29104] Mon, 07 October 2002 14:41 Go to previous message
>I am getting
>at
>:831)
Previous Topic:update-manager & http-proxy
Next Topic:[ANN] AntView 2.2.8 Released
Current Time: Mon Jul 21 21:13:43 EDT 2025
Powered by FUDForum. Page generated in 0.03855 seconds
