Re: request: better message [message #290673 is a reply to message #290618] |
Mon, 29 August 2005 17:02 |
Originally posted by: eclipse3.rizzoweb.com
Dave Dyer wrote:
> "package does not match the expected package"
> Please tell me what package was expected!
> And no, it's not obvious. In the current case, I have a
> file in a folder named "test" with a package declaration
> of "test" and I'm mystified.
It should be telling you what the expected package is - it does for me.
If your folder is named test and the code declares test as its package,
then you would need to have the parent of folder "test" be a Source
Location on the project's Java Build Path. Generally, projects should
have a source or src directory and that is where source packages are rooted.
HTH,
Eric
FUDForum. Page generated in 0.04001 seconds
