hot code replacement during debug [message #290052] |
Thu, 18 August 2005 07:34 |
Originally posted by: mik.c-l-a-s-s-x.it
There are certain situations where Eclipse (since v3.0) does not
edit/replace java code during the debug phase.
Since this problem is not predictable I cannot make a serious test case. All
I can say is that this problem happens very often, expecially when the
application to debug has started a number of threads. But just take this as
an indication.
Also, when you write new code into a method (i.e. a System.out.println() )
you can put a breakpoint there and the debugger will stop there, but the
code will not be processed.
Mik
Re: hot code replacement during debug [message #290117 is a reply to message #290103] |
Thu, 18 August 2005 16:53 |
Kevin,
Sadly the beavior is not easily reproducible so filing a bug report is very
difficult for this issue.
The jvm I'm using is jdk1.5.0_04 (winxp).
I would like to know if I'm the only one facing this problem with Eclipse.
Mik
"Kevin Barnes" <krbarnes@ca.ibm.com> ha scritto nel messaggio
news:de2afs$k04$1@news.eclipse.org...
>> Mik
> Hot Code Replace is dependent on the VM that you are using. Not all VM's
> implement the same methods. Therefore you will see some cases where HCR
> succeeds on one VM, but fails on another. If HCR fails the reason that it
> failed is normally displayed in the error dialog that pops up.
> If you a specific reproducible failure, that you think is an Eclipse bug,
> you can file it against the Platform-Debug component.
> Kevin
FUDForum. Page generated in 0.03196 seconds
